05-10-2013, 09:20 PM | #45 |
Rep 869
So, Kaiv, did the fluid that showed up in the overflow catch can not drain back down into the main reservoir?
2008 M3 Coupe / DCT // StopTech BBK 380/355 / Pagid RS29 / Motul / Apex Arc-8 / BFG R1S / Ground Control / MS filter / Performance spoiler / BPM tune // Road Atlanta 1:39.70 / VIR Full 2:10.87 / Barber 1:42.20 |
05-10-2013, 09:44 PM | #46 |
Rep 1,470
Like I said earlier, the right way is the BMW Motorsports GT4 Power Steering Cooler. No leaks......
Stoptech 380mm/355mm | PFC08 / Pagid RS-29 | Akrapovic EVO - CF tips | Benvo Tune | MS UDP | AA air filter | MCS 2-way with 700/1000lb springs | Solid bushings and adjustable links | RD front swaybar | Apex EC-7 18x10 square 275/35-18 NT01 | Turner Race Studs | GT4 Brake Cooling | GT4 Power Steering Cooling | Alekshop Oil Cooler | Performance Steering Wheel | | CF Spoiler | Varis System 1 Full CF Diffuser | Extended Paddle Shifters | Schroth Quick Fit Pro | Turner Steering Rack Stops | Vorshlag Camber Plates
05-14-2013, 02:56 PM | #48 |
Rep 121
Tom, #1 in diagram, is it all I need to prevent such leak. Any other parts needed? I went to my dealer and they said its a part from the 335. They checked and showed me that 2012 & 2013 m3's have the same PS reservoir.
05-14-2013, 03:14 PM | #49 | |
8260
Rep 18,848
Drives: BMW
There is an adapter that is needed for the bottom nozzle since it is slightly larger (about 1 size) than the M3 hose. This can be purchased at any auto parts store.
06-24-2013, 07:16 PM | #51 | |
IG: limited.slip
335
Rep 1,922
You could also run a reservoir that's 2 feet tall, I'm sure the fluid will have a hard time getting out up there The cooler is the upgrade to get if you're killing pumps. In my case everything is working fine and I'm happy to save the $2k. |
Assimilator1594.00 |
06-24-2013, 07:20 PM | #52 | |
IG: limited.slip
335
Rep 1,922
Catch can as seen on the ALMS Z4 GTE
Couple kits I put together for local friends: I edited/added details to the parts list for this kit if anyone wants to replicate Quote:
s0ldats53.50 Assimilator1594.00 |
06-24-2013, 07:40 PM | #53 |
Rep 9,034
kaiv, thanks for listing everything.
06-24-2013, 10:30 PM | #54 |
Rep 869
I just installed my "kit" and will check it out at Barber in a couple of weeks. I think this is a brilliant and cheap fix for this problem. Hopefully no more splish-splash in the engine bay for me.
Thanks, kaiv!
06-24-2013, 11:28 PM | #55 |
78
Rep 684
Unless you are addressing the root cause of the problem (which appears to be the overheating of steering fluid), why all the trouble when you can do this?
06-26-2013, 01:35 PM | #56 |
Rep 869
^ I did this too, but it would soak thru and was still a messy situation. Was not acceptable to me. And the project was no trouble at all, kinda fun, and only 25 bucks. Compare that to the auxiliary PS coolers.
06-27-2013, 01:50 PM | #57 |
IG: limited.slip
335
Rep 1,922
Not acceptable for me either.
And you posted a pic of a clean cloth. After an event or two it gets absolutely disgusting and have fun cleaning it. Unless you replace it each time in which case it'll quickly get more expensive that our $30 "kit" |
06-28-2013, 01:07 AM | #59 |
78
Rep 684
I've since switched to a black wristband and it hides stains very well. But point taken
06-28-2013, 10:01 PM | #60 |
Rep 1,718
Drives: 2011 M3 Jet Black:ZCP, ZCV, ZP
do you recall the length of the m6 bolt? So it screw directly into the silver thing?
08-07-2013, 12:40 PM | #61 |
***Major MammelToe
159
Rep 1,139
Tom, can you pm me the price to do the swap including parts.
E92 M3 SG DCT - AA Filter, Verstraβe Paddles, ECS SS, MH race stud, Stoptech BBK, MR Exhaust,RE Pulley, BPM Tune,Euro bumper and GTS lip, Euro MDM & DCT, KW CS, Recaro PP, TMS Soild Diff Mounts, MRF solid subframe mounts, GTS aero, RPM track built motor.
08-07-2013, 12:46 PM | #62 |
***Major MammelToe
159
Rep 1,139
Kaiv, any way you can put one of those kits together for me?
08-07-2013, 02:15 PM | #63 |
Rep 1,470
I think people will be good to go if you also gave them the ID of the tubing. Nice work though.
08-07-2013, 03:16 PM | #64 |
***Major MammelToe
159
Rep 1,139
Done, I got it ordered. The tubing ID is 4mm. I got the 4mm silicon hose from amazon.
08-14-2013, 04:16 AM | #65 |
IG: limited.slip
335
Rep 1,922
06-11-2014, 11:55 AM | #66 |
292
Rep 2,898
Apologize for being a bit late to the party.
I have a heavily tracked 1M -- with the updated ps reservoir -- but still lose quite a bit of fluid on track. What needs to be done to adapt Kaiv's kit to work with the updated reservoir? Thanks. Neil |
