BMW M3 Forum (E90 E92)
Go Back   M3Post - BMW M3 Forum > M3 Marketplace > SPONSORS Classifieds/Groupbuys/Specials Area > Suspension | Brakes | Chassis | Handling
European Auto Source (EAS)
      01-11-2022, 02:24 PM   #1
IND-Distribution
IND-Distribution's Avatar
9588
Drives: G82 M4 / G87 M2
IND | Fall-Line Motorsports E9X M3 Lower Trailing Arm Bearing - Outer
MADE IN THE USA.
From years of competitive race experience, Fall-Line has become synonymous with producing not only championship caliber race cars, but the finest suspension components that help propel them to victory.
Rubber bushings found in the latest M Cars' rear suspension arms are the last weak link in an otherwise rigid suspension. Fall-Line's new lower tension/trailing arm outer bearings yield a significant improvement over the factory bushings; as motorsport parts, both strength and longevity were priorities—to do just that, Fall-Line boasts the largest FK spherical bearings on the market—by eliminating rubber from a critical feedback area of the car, you gain control over the tire’s behavior and thereby confidence behind the wheel at the limit. To adequately cope with competition-level load, Fall-Line bearings feature stainless steel spiral locks that offer 360 degrees of clamping force to secure the bearing from any potential movement.
As an added benefit, the spherical bearings will outlast the OEM rubber variants, saving the headache of repeated replacement over your ownership. As with any elimination of suspension bushings, more direct feedback can equate to a slight increase in noise, vibration, and harshness after installing these parts.
Product Details:
  • Fits E9X M3 / E82 1M
  • DMG Mori 5-Axis CNC machined
  • Full stainless bearing assembly (hats, bearing, housing, spiral locks)
  • Sold in pairs; designed to replace the rear tension/trailing arm outer bearings (BMW Part Number: 33-32-6-763-092)
  • Made in USA
Fall-Line Motorsports E9X M3 Lower Trailing Arm Bearing - Outer may be viewed at the following link to our online store:
https://ind-distribution.com/product...-bearing-outer
Please contact IND by phone or email for more information or to place your order.
866.963.4520 | info@ind-distribution.com
IND DISTRIBUTION | 866-963-4520 • INSTAGRAMYOUTUBEFACEBOOKFLICKR
m3post
