Coby Wheel
BMW 3-Series (E90 E92) Forum > BMW E90/E92/E93 3-series General Forums > Photo/Video/Media Gallery > Official APEX Wheels Showroom Gallery Thread
      11-26-2012, 02:34 PM   #67
Expert@ApexWheels
Expert@ApexWheels's Avatar
3530
Drives: M3
Looking good jck996! The wheels compliment the car very well!
      12-06-2012, 07:03 PM   #68
Expert@ApexWheels
3530
Drives: M3
Here is a track setup that one of our clients have done with the ARC-8s:
  • Satin Black 17x9.5" ET35 ARC-8s
  • 255/40/17 Nitto NT01 R-compound tires
  • TC Kline Coilovers with camber plates
  • -2.8 F, -2 R camber
  • 5mm front spacer to clear struts
      12-10-2012, 09:34 PM   #69
Javier
Javier's Avatar
Puerto Rico
80
Drives: 335i E92
^droool
2007 328i Crimson Red *SOLD*
2010 335i MSport AW E92
      01-15-2013, 12:29 PM   #70
nitehawk
nitehawk's Avatar
102
Drives: e92 335i 6MT
Anyone have pics of the Arc-8's in hyperblack on an e92 335i?
      01-15-2013, 12:31 PM   #71
hellrotm
Drives: F80
Why can't a company make a hood that doesn't have sh*t fitment?
      01-15-2013, 01:18 PM   #72
ApexWheels
ApexWheels's Avatar
1429
Drives: M3
Unfortunately we do not have any pictures of that set up on an E92 but we do have photos of it on an E90.
  • Hyper Black 18x8.5" ET38 and 18x9.5" ET35 ARC-8's
  • 235/40/18 and 265/35/18 Continental tires
lab_rat394.50
      01-18-2013, 02:03 PM   #73
ApexWheels
ApexWheels's Avatar
1429
Drives: M3
  • Apex ARC-8 in Hyper Silver
  • 18x8.5" ET38 Front, 18x9.5" ET35 Rear
  • 235/40/18 and 265/35/18 Dunlop Star Spec tires
  • This is a direct fitment. Wheel spacers, fender rolling, and additional negative camber are not needed
      01-18-2013, 03:21 PM   #74
meza0531
Drives: 08 Jerez E90 M3
You guys need to go more aggressive! I can't wait to mount my Hyperblack ARC-8's on this summer ! Kept the setup off my E46 M3, and am going to make it work on my brand newish 335i! Had to downgrade the tires a bit to make it fit, but still close to OEM tire specs. Will have pics as soon as it warms up.
18x9.5 +22 fronts (235/40 Hankook V12's)
18x10 +25 Rears (255/35 Hankook V12's)
      02-08-2013, 10:49 AM   #75
nitehawk
nitehawk's Avatar
102
Anyone running the ARC-8's 18" in 9" width up front, which I think has a 42mm offset. What would I need to do to make that fit? It would be nice to see that concavity both front and rear.
      02-08-2013, 11:07 AM   #76
MonacoBlueE90
MonacoBlueE90's Avatar
Finland
163
Drives: BMW E90 320D Half-LCI
Spacer is needed to clear struts inside, but go with 9.5 fronts if you want concave. I have 18x9.5 et35 front.
I don't really see much concave on 9 inch wide
http://www.e90post.com/forums/showpo...6&postcount=58
      02-08-2013, 12:17 PM   #77
nitehawk
nitehawk's Avatar
102
Got it, yes only the 9.5's are concave on 18s. I was thinking of the 17s. A 9.5 up front would be tough to pull off on an e92.
      02-08-2013, 01:14 PM   #78
MonacoBlueE90
Finland
163
Not really, 235/40/18 tyre to front and if you have coilovers small spacer to clear the struts, but if you want 17 inch even though you asked 18 inch. 17 inch have et30 at 9 wide.That's direct fit and it seems to be concave too.
http://www.e90post.com/forums/showthread.php?t=800243
      02-11-2013, 02:46 PM   #79
ApexWheels
ApexWheels's Avatar
1429
Drives: M3
If you would like to do the 18x9" ET42 flat face front wheel on your car a 5mm front wheel spacer would be needed to clear the front strut. If you were looking to use a 255 width front tire and you have the required negative camber obtained through adjustable camber plates than you would need a 12mm front wheel spacer to clear the strut.
      02-11-2013, 02:49 PM   #80
Toyo
Toyo's Avatar
Drives: 335d Titanium Silver LCI E90
      02-12-2013, 09:34 AM   #81
nitehawk
nitehawk's Avatar
102
Hmmm, so basically an overall ~ET30 offset with a 18x9" will allow me to fit a 255/35 FR? Or 17x9" ~ET30 255/40? I believe your EC-7s come in that offset as well as the 17" arc-8s correct? I will have camber plates and KW coilovers but want to avoid the spacers.
      02-12-2013, 12:37 PM   #82
ApexWheels
ApexWheels's Avatar
1429
Drives: M3
That is correct. The EC-7's do come in an 18x9" ET31 size and the ARC-8's do come in a 17x9" ET30 size but the ARC-8 in 18" at this time only comes in at an 18x9" ET42 size which does require a wheel spacer in the front when using 255 and wider front tires. The ET30 offset is also ideal in the rear of your car where you would not need any wheel spacers at all unless you were looking for a slightly more aggressive and flush wheel fitment.
      02-23-2013, 10:39 PM   #83
jjellyneck
9
Drives: 2008 335i MT
Your car is stunning with those wheels.
Originally Posted by curryNrice004 View Post
Just got back from Sonic MS who did my EC-7 and KW v2 installation over the weekend and boy oh boy....i LOVE how the car came out! These rims are amazing and I could not be more happier with how it came out!! Thanks again Apex team!!
I only have one pic for now, but will take more in the morning
Specs:
18x9 +31 Profile 2 wrapped in 255/35 Hankook v12
18x9.5 +22 Profile 3 wrapped in 265/35 Hankook v12
rear fenders are rolled and aggressive camber out back...no rubbing!
      03-09-2013, 01:42 AM   #84
Lshaw
Drives: 09 335i 6mt
Hey im looking at the same set up. Do you have any rubbing issues?
Originally Posted by lcix View Post
I just put these on & here's a quick dirty pic. My car is a 2010 e90 335i xDrive.
EC7s in F:18x9 et 31 and R:18x10 et 25
Tires are Vredestein Ultrac Sessanta
F: 235/40/18 / R: 265/35/18
I'm running Koni sports with Swift coilover springs (7kg/12kg) on TCK sleeves up front & AST height adjusters in the rear. 6" springs up front are set tad under 1" from lowest setting. There's about .75-1" gap above the tire all around. The rears will rub but just slightly only over occasions when the shocks compress beyond 2".
The rears fit to my taste perfectly. I plan to roll the rear fenders & go another 1" lower on a different set of coilovers with 3-5mm spacers up front.
      03-10-2013, 02:54 PM   #85
meza0531
Here are a few of my Apex's
Front 18x9.5 +22 235/40 Hankooks
Rear 18x10 +25 255/35 Hankooks
Bilstein Pss10's, and no other work. No Rubbing
      03-10-2013, 03:13 PM   #86
Route 16
I got lei'd
Route 16's Avatar
Philippines
844
Drives: '10 E90 M3
Very well done, COLA for each wheel!
      03-10-2013, 03:16 PM   #87
meza0531
Nicely said Sir , COLA is nice, but not enough to cover the Apex's
      03-10-2013, 03:51 PM   #88
mikegh
mikegh's Avatar
Drives: 2009 TiAg e90 328xi
I've never seen a more perfect bimmer. Can I see more pics of this car?
