ZPOST
Go Back   ZPOST > BMW Z4 Technical Talk > Suspension and Braking Chat
  TireRack
      02-02-2019, 10:10 PM   #89
dre99gsx
Drives: 1994 Toyota Supra
UPDATE:
Here is another option that I just tested. You CAN fit 355mm or larger Stoptech Z4M (yes, the M/S54) front kit on the 3.0si. Here is what you do:
- Purchase 6061-T6 spacers 12mmID x 28mmOD x 14.28mm long
- Purchase longer M12x1,5 bolts (I found M12x1,5x50 flywheel bolts part number 11222243051)
- The trick is to install the caliper bracket BACKWARDS (just flip the bracket). You will then bolt in from the front of the spindle, sandwhiching the 14.28mm spacers between the bracket and the spindle
And that's it. Install the rotor, slide on the caliper, perfect fitment. I'll have some photos soon to demonstrate.
Now you have two options: 355mm Stoptech (or 380 if you wish for Z4m), or 335 caliper+brass guides/z4m rotor swap. Both I feel are great track setups.
Yes, I jumped ship to the Stoptechs. The main reason? My favorite PFC08 pads are very hard to find for the 335i calipers.
wdb4732.00
      02-05-2019, 06:00 PM   #90
dre99gsx
As promised. Z4M 355mm Stoptech trophy on a 3.0si
Send all thank yous to my paypal please
wdb4732.00
AK72286.00
      09-25-2019, 07:48 AM   #91
Yapakanichi
Monkey Marshall
Yapakanichi's Avatar
635
Drives: 2005 Z4 3.0i
You know this thread is awesome and very informative for those with a 3.0si. However is there a difference for the pre-facelift 3.0i?
      12-22-2019, 11:41 PM   #92
Willy Sea
55
Drives: BMW M Coupe S54, E36 M3 Evo,
Originally Posted by dre99gsx View Post
UPDATE:
So going to do this conversion in early 2020. Just confirm that the calipers needed to suit for the front are P / N 34 216 769 101(L) and 104 (R). From 335i E9x series. And match to 345x28 rotors (F) Z4M spec. Going to refurb the rear calipers and invest in a set of standard sized slotted / drilled rotors to match whatever we end up with in the front.
Any suggestions for best bang for the buck in the rotor department? The car is for spirited road use only.
Need to fill out the space behind the Apex wheels haha........
Thanks for reading,
Bill
      01-11-2020, 01:27 AM   #93
Willy Sea
55
Thanks for reading,
Bill
So this project is going ahead, with the Z4M drilled discs 345x28 (P/N 34112282445 / 446) and 335i calipers, p/n 34116773201 (L) and 02 (R)
On the rear, upgrading to 294x19 drilled discs, and retaining the O/E calipers.
Would knowledgeable person please confirm that the front caliper number are correct before hit buy now, on my previous post the P / N listed were rear 335 calipers!
Thanks for reading
Bill
      03-02-2020, 12:35 AM   #94
Willy Sea
55
Ordered up, first delivery
Thanks for reading
Bill
So the calipers arrived today What colour to paint? Black gloss we are thinking.Remember our E86 is nightblue.
Quite a bit bigger than the original sizing for the front units Got a new set for the rear too, easier to prep and paint front and rears together rather than waiting with the car on the hoist getting things done.
New Z4M drilled rotors arriving with drilled rear rotors in the sizings posted above. Hope its all as easy to fit as it was to hit buy now
Other items to note: the aero skirts came last week too. And no we paid nowhere near the pricings that have been talked about on these forums.
And picked up a new magnaflow resonator from a member on the UK forum who also lives in Christchurch NZ. Thanks Shayne.
Still going down the road for a tune / remap, taking advice from some of the E90 boys with this.
The despatch date keeps getting pushed back for the Apex Arc8"s in hyperblack ordered on Black Friday 2019. March 20 now. Still, not too stressed we have a set of EC7"s in anthracite on the car.
And did I show you the rear diffuser?
Naturally, now unable to find the pix, till next post then,
Bill
      07-11-2021, 08:16 AM   #95
Ari Gold
Drives: Cupra Ateca
Are the 4 pot f30 brembo calipers compatible with the e86 3.0si? And by compatible i mean straight bolt on, or some kind of adapter.
I assume if the calipers for 340 rotors fit, the calipers for 370 rotors also fit?
How about the f30 rotors, do these fit?
Both these calipers (340 and 370 variants), these rotors (340x30 and 370x30) aswell as pads seems a lot more common to find
https://www.turnermotorsport.com/t-b...ke-Differences
      03-13-2024, 04:32 PM   #96
Mr. Monday
Drives: Z4C 3.0si 6mt
Bill
Did these end up being the correct front calipers? It's hard to tell since none of the previous images in this thread are working and no part numbers were mentioned.
zpost
