ZPOST
Go Back   ZPOST > BMW Z4 Technical Talk > Suspension and Braking Chat
  TireRack
      12-08-2022, 07:00 PM   #1
dre99gsx
Drives: 1994 Toyota Supra
2.5" springs on 62mm KW V3 body
I'm looking at some springs but most are 2.5" ID (Hyperco, swift, etc). I know BC has Swift in 62mm, but the rates I need are not in stock.
Has anyone run the 2.5" ID springs on KW shocks (or any shock that is made for a 62mm ID spring) without issues on the track?
I have tried a set I have laying around for fit, and it feels looser than I would be comfortable with.
      12-09-2022, 06:41 PM   #2
CTMP4me
28
Drives: '08 Z4MC, '71 240Z with S54
How tight are the tolerances on the original KW springs? From experience, 60mm springs measure ~1-1.5mm over and perches/couplers are ~0-0.5mm under. 2.5" ID is nominally 63.5, not that far away from 62mm all things considered. Your spring perches should have enough room for either. Going with a "62mm" odd size spring might also limit what you can get for a helper spring setup.
      12-09-2022, 07:13 PM   #3
dre99gsx
Spring perch is 61.40mm, and the 62mm spring is 63.30mm, so roughly 2mm tolerance.
The 2.5" spring I have here 65.25mm, which would increase the gap, now 3.85mm. So, it's an increase of 1.85mm.
I can move the 2.5" spring a good amount within the perch.
OD of the perch is 80mm. OD of the 62mm spring is 85.6, so ~2.8mm overhang on each side of the spring.
The 2.5" spring OD is 89.3, which would be ~4.6mm overhang on each side. I'm afraid too much of the spring mass is outside of the perch. I tried looking for 62mm to 2.5" adapters but can't find anything.
I'm looking at 2.5" for better sizes, so if folks have run 2.5" springs on a setup that normally uses 62mm, would be interested
      12-09-2022, 08:09 PM   #4
Steeler
Steeler's Avatar
2429
Drives: Built not Bought 04 Z4 VF
I may be way off base but, is it feasible to machine up a top hat that would take up the slop between id of spring and od of perch and also create a shelf to increase the diameter of the perch where the bottom of the spring sits?
Am I understanding your dilemma?
W2A Intercooled Vortech V3Si, custom ducting, Alpha N, 60# Bosch,2.62 pulley, multi port WMI, Severn Tuning(pokeybritches), Tial, magnaflow,SS race muffler, 42 design,3.91LSD, H&R, Hotchkis,ST coils,Konis, Megan camber arms, AKG SS, Nylon mounts, Poly bushings, Carbon interior, CF Aero.APEX
      12-10-2022, 08:24 AM   #5
dre99gsx
That's correct, both the top and bottom would need one. I've seen those around but they are usually for 60mm -> 2.5" and they are tough to find, and usually made from ABS plastic.
I may also be overthinking this and it may be no problem to run this larger ID spring. I just don't know to expect if I do...
      12-11-2022, 11:01 AM   #6
maupineda
Drives: E86 Z4MC
You can use this. All European coils use 52mm struts
https://3dmmotorsport.com/products/o...d-spring-perch
zpost
