The Tire Rack
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Powertrain and Drivetrain Discussions > N54 Turbo Engine / Drivetrain / Exhaust Modifications - 335i > Tow hook thread size?
      03-01-2021, 12:52 PM   #1
iqraceworks
iqraceworks's Avatar
2002
Drives: 2007 335i
Question Tow hook thread size?
I'm getting ready to replace the oil pan gasket on my 07' 335i coupe. I went to thread in the factory tow hook to the threaded hole next to the oil filter that's used to lift the engine. Not sure what tow hook the guy gave me when I bought the car, but the thread diameter is way to big to thread into the threaded hole in the block.
Anyone know what size threads are in that hole in the block? I might just fold a bolt that's the right size locally, and weld a loop on the top to lift with.
Thanks!
2007 335i, BMS DCI, BMS Chargepipe w/Tial BOV, ARM Catless Downpipes, silicone inlets, Bilstein B12 Prokit Suspension, Whiteline subframe bushings, Front/Rear M3 control arms, G-Plus FMIC, Stage 2 LPFP, Custom E40 tune by Justin (V8Bait), xHP stage 3 transmission flash, RB Two Turbos....10.90 @ 128mph
      03-01-2021, 04:34 PM   #2
ewicky
Drives: '07 335xi 4D AT
Just take your engine into the local hardware store and test fit all the different bolt sizes they offer.
Honestly I doubt any normal hardware store would have heavy duty bolts with that thread. It's thicc
      03-01-2021, 04:38 PM   #3
relative4
Drives: '08 335xi E90 MT stage 1+
Those threads are not machine threads per se. You need a BMW tow hook. $15 on eBay.
A pic of the hook you have would be good. Inspect it carefully for a part number.
      03-01-2021, 04:59 PM   #4
ewicky
Also, did you try threading the tow hook into the bumper, F&R?
Just as a sanity check. Like, maybe the tow hook is correct and it's the hole in the engine that's not right.
      03-01-2021, 05:23 PM   #5
Tyc0
Drives: BMW e92 335i
Yeah I would be surprised if the hook was too big, the one I have is already massive, maybe your using wrong hole?
      03-01-2021, 06:51 PM   #6
relative4
OK gentlemen, remember this is a family website.
Vivek.1367.50
      03-01-2021, 07:13 PM   #7
iqraceworks
2002
Drives: 2007 335i
It's not like there is a lot of options as far as threaded holes in the N54 block right next to the oil filter housing.....
      03-01-2021, 11:04 PM   #8
Tyc0
Ur not wrong, guess your only option is to order a new hook
      03-02-2021, 12:31 AM   #9
stewbets
Drives: '08 335xi, '04 545i
Pics or it didn't happen.
I had to grind down the shoulder of my tow hook so it's would clear the valve cover.
      04-20-2024, 11:14 AM   #10
Kenneykickin
///Kenney
Kenneykickin's Avatar
Drives: 09 335i / 06 330xi
More info on this? Using my tow hook but it only threads in like 1/2 rhe way. Prob be fine but meh
