12-06-2020, 07:02 AM | #1 |
Rep 553
E70 X5 Motor mount question
As my X5 is approaching 70k miles, I've been contemplating on doing the motor mounts as more preventative maintenance since they are likely getting worn. As I searched the forums I haven't found any posts about people doing them. I am curious if anyone has attempted or has accomplished this tasks. From a quick glance in the engine bay it doesn't look terrible, but I could be wrong. My X5 is a late 2013 build which may make a difference.
12-07-2020, 08:08 AM | #5 |
Rep 1,721
I would suggest doing them, it cant hurt. I've been meaning to do mine for last few months but haven't found time. I have a 35d and can definitely feel some vibration through the cabin due to engine mounts being worn. I did attempt to do them once a couple months ago but didn't have enough time or clearance. Some people have said its straightforward, and others have said its a PITA. I am with the latter from just inspecting it.
2016 F31 328iX | Alpine White | Black | ///MSport | iND | Eventuri | AC Schnitzer | MPerformance | 513M | Michelin PS4 |
2005 | 330CiC | Sparkling Graphite | Black | 6MT | ZHP Purchase your W///AGON Stickers Here: https://f30.bimmerpost.com/forums/sh....php?t=1930190 |
12-07-2020, 04:15 PM | #6 |
Rep 46
Not a fun job on the 35d, especially if you still have dpf. Def started and stopped a couple times before actually doing it. Tight spaces, guessing where the bolts are, having engineer up and down. Had to drop the subframe, kept it in place with the bolts turned in 1-2 turns. Again, don't know how much of this applies to N55.
12-12-2022, 10:03 AM | #7 |
Anxious!
Rep 35
Replaced Motor Mounts and Vibration Increased?
I'm not aware if the OP ended up replacing the motor mounts on their N55, I just replaced mine when replacing the oil pan gasket and found the rubber bottom of the right passenger side motor mount completely split with barely any fluid left inside. I figured this was most likely the cause of the vibration I was having when stopped at a red light with my foot on the brake and in Drive waiting for the light to change. However, the vibration problem actually became worse. Does anyone know what might be causing this vibration problem if the motor mounts were replaced and should be ruled out of the equation?
01-10-2023, 07:05 PM | #8 |
Anxious!
Rep 35
Update: problem solved, the vibration is gone. While replacing the oil pan gasket I also replaced the front right axle. The brand new GKN axle was the culprit. My indy diagnosed the problem and found the axle was defective. Luckily I still had the original BMW axle and it was swapped back in and all the vibration issues disappeared.
StradaRedlands4953.50 |
01-30-2023, 01:38 PM | #9 | |
Rep 553
02-07-2023, 11:33 AM | #10 | |
Rep 61
My car has 90k miles and when I drive over a bump, I can hear a clunk sound on the driver side below/near the wheel well. I could be axle, control arms, etc. |
02-07-2023, 11:43 AM | #11 |
Rep 553
I would check the front tension strut first. If you’ve never replaced them you’re likely overdue to change them out. If you X5 has X drive, then the passenger side mount is an absolute PIA. The passenger side will require the axle to be removed and the out put cover for the differential on that side to be removed to access the last bolt for the engine mount bracket. If you don’t have X drive then it’s likely much easier. However, at 90k miles and now control arm bushing replaced, then they are likely suspect to me or the struts.
04-22-2024, 12:00 PM | #12 | |
83
Rep 131
The 2013 X5 I purchased is in extremely good condition even with 116K miles. |
04-23-2024, 08:29 AM | #13 |
Rep 553
Is it X-Drive? If it is you’ll need to pull the passenger side axle. You’ll need the special tool to pull the axle in through the hub.
04-24-2024, 08:03 AM | #14 | |
83
Rep 131
I likely will hold off on this for a while but I like to gather as much information before hand as I can. I just did a front and rear diff fluid change, trans fluid and pan/filter, and the transfer case fluid change. I changed the transfer case/trans mount as well. Bought the mount just in case and glad I did. The original mount was completely sheered. Everything else mechanically looks great. I am actually quite shocked at how good and nearly new looking everything is. |
