02-24-2017, 07:10 PM | #1 |
Rep 1,485
Drives: 2011 Frozen Grey E90 M3
MPE Exhaust Tips - Is There a Fix or Do I Just Replace???
Hey All
Let me start out by saying that I need some direction or advice on a path forward. My current MPE exhaust has approximately 60,000 km (37,000 miles). I decided that it was time for a little TLC as the tips have seen better days. Here are some pictures from the exhaust as it came off my car. My initial approach to cleaning them was a wash and rinse followed by Chemical Guys Clay Lube and Sonus Clay Bar to remove tar and contaminants. Once this was done I did a once over with Chemical Guys V34 with an Orange Pad. I attempted a second time to help improve the results. The results are seen here. Needless to say, not what I was hoping for. The top of the exhaust appears have almost brush or matt finish to the metal. My fear is that any degree of polishing will eliminate the laser etching of the ///M on top. Meanwhile, the bottom of the tip appears to be oxidized or the finish is marred by carbon. At this point in time I am looking at potentially taking the tips off and having them ceramic coated black and having the ///M redone. Alternatively, if there is anything I can do to refinish to the original condition, I would consider that too. Based upon my research it appears that replacement MPE tips are not available. I have looked at various options out there such as EAS 80mm tips, as well retrofitting Akropovic ones. I don't necessarily wish to go down the retrofit route, but I NEED to do something. The current state is deplorable and I have to rectify it. I am open to suggestions......
02-24-2017, 08:38 PM | #2 |
Stop the hate, get a V8
3851
Rep 8,625
Frankly, I think the M logos looked kinda dumb. The car has enough M logos on it already. I'd just polish the tips and call it a day.
Now: 2017 Corvette Grand Sport, 2021 AMG C63 S sedan
Past: 2011.5 M3 sedan ZCP |
02-24-2017, 09:38 PM | #3 | |
Rep 1,485
- I do appreciate the honeycomb inside as it feels as though it gives it an added dimension to the tips that I find stylish. - normally I would agree with the comment regarding the ///M etching and the exorbitant use around some cars. More so when we see the likes of more and more BMW's adorning the '///M' Performance moniker. M235i, XM40i and the ghastly ///M badging plastered on a riced out 335. However, I do think the MPE tips are subtle enough to not be over the top. The intricacy of the laser etching is fairly subtle and adds a nice touch to the finished product. I think it works for Akrapovic, while certainly doing it for the MPE.
02-24-2017, 09:55 PM | #4 | ||
Rep 1,485
02-24-2017, 11:24 PM | #6 | |
Rep 1,485
Thanks for the input
02-25-2017, 01:21 AM | #7 |
266
Rep 349
P21s soap is good stuff and may help. Based on the photos polishing is your only option. The ///M logo should be fine. Use a less aggressive pad and compound combo and exercise a bit of patience to protect the logo.
FMLYSDN1181.50 |
02-25-2017, 02:04 AM | #8 |
279
Rep 204
I would try Flitz polish and a foam polishing pad, should not hurt the logo. While Neverdull is a great product I have used for over 20 years. Unfortunately from my experience with it, don't think it will be enough to get the desired results.
E90 2011.75 M3
E92 2007 328I Rover Vitesse 1989 (BMWs are to easy to work on) Nissan Xterra 2002 (Illinois + Winter = SUV) |
FMLYSDN1181.50 |
02-25-2017, 08:44 AM | #9 |
Rep 1,485
Thanks for the direction. I will definitely consider it and give it a try.
02-25-2017, 08:44 AM | #10 |
Rep 1,485
Thank you. Perhaps this will be one in many steps towards success.
02-25-2017, 08:56 AM | #11 |
Rep 1,930
I just polished my mpe tips. The black paint was coming off so I polished everything out. There was a lot of oxidation too.Used autosol metal polish and it works wonders
02-25-2017, 09:03 AM | #12 | |
General
63414
Rep 24,687
BPM DEV-Tune & DCT Software-Tune & Servotronic & coding ///Alpine HID Angeleyes ///Oem.exhaust mod. |
PACarGuy683.50 |
02-25-2017, 09:39 AM | #13 | ||
Rep 1,485
///M Power-Belgium63413.50 |
02-25-2017, 09:41 AM | #14 | |
Rep 1,485
I think that I will refinish the inside too however, I will probably look at painting it black again.
02-25-2017, 03:16 PM | #15 |
Rep 1,930
02-25-2017, 04:10 PM | #16 | |
3851
Rep 8,625
I use Nevr Dull for any soot or grime that's really caked on (rare). The polishing soap is usually adequate for my car wash routine.
02-25-2017, 04:28 PM | #17 |
Rep 1,485
Interesting. Thanks for the pic. I'd really like to see the finished product.
02-25-2017, 04:38 PM | #18 | ||
Rep 1,485
I ended up taking home the P21S soap polish, #000 & #0000 steel wool and some Sonus metal polish. My initial attempt at using the P21S proved to be a futile exercise. I think that everything has been baked on so long as well as oxidized that it didn't make a difference with the P21S. I'll try again during the summer season when I need to clean the finished tips regularly. Next up was the steel wool.... I am still wondering about the weird finish on top of the tips near the ///M laser etching. This gets interesting. ...
02-25-2017, 04:45 PM | #19 |
Rep 1,485
Next step I took is the steel wool. Initially focusing on a fine #0000 steel wool and then worked on the bottom of the tip away from the ///M.
Initial results looked good. The carbon was beginning to come off albeit a little more force than I thought was necessary. ...
02-25-2017, 04:52 PM | #20 |
Rep 1,485
I moved over to the #000 steel wool and the results started to come quickly.
Any of the areas that appeared 'polished' from my previous work, began to haze and appear 'brushed' I carried on until I was satisfied with the results. This was working but it looked as though It would take some time. I wish I had some #00 steel wool!!! As I moved to the top of the tip where the ///M etching was located, I carried on with the #000 steel wool. The oxidization was extremely hard to remove. I truly wish I had a slightly more abrasive one. Especially for the inside of the tip. However, progress can be seen! And the etching is proving to be very resilient. No signs of wear or thinning. ...
02-25-2017, 05:37 PM | #21 |
Rep 1,485
02-25-2017, 05:41 PM | #22 |
Rep 1,485
After continually working at the top, I finally am happy at this point. It's a good start and the ///M looks great. The inside of the tip is another story. We will tackle that later.
///M Power-Belgium63413.50 jeff@autocouture965.50 |
