BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > 2012-2019 BMW 3 and 4-Series Forums > General F30 Sedan / F32 Coupe / F36 Gran Coupe Forum > Comfort access stopped working after replacing external door lock cable
Studio RSR
      01-26-2024, 10:36 PM   #1
oklhr
Drives: f30 328i 2012
Hi there!
I have replaced external driver's door lock cable. After I assembled the door panel and exterior handle I checked that it works by opening and closing the door several times, exterior handle worked as it should and comfort access also worked. Then I left the car closed for couple minutes and after that comfort access stopped working. The door still opens and closes with the key though. Passenger door comfort access works fine.
Any thought on where to look?
Thanks!
      01-26-2024, 10:45 PM   #2
im_an_alien
im_an_alien's Avatar
1167
Drives: 2016 340i
Yes, look at the door handle that you was just messing with. Check connections again, something could be loose/pinched
      01-26-2024, 11:31 PM   #3
ashkanvafaee2
43
Drives: 2016 340i
All your answers can be found here: https://f30.bimmerpost.com/forums/sh....php?t=1952155
      01-27-2024, 12:03 AM   #4
oklhr
Yeah, I'll try to check connections tomorrow, although its such a pain to access it inside the door. Thanks!
      01-28-2024, 03:18 PM   #5
oklhr
Well, the next day comfort access magically worked fine for drivers door, I did not do anything to fix it. It's been a second day and it still works. Will update the thread if it stops working again, but so far everything looks/works fine.
328i, comfort access, door locks, f30
