      12-15-2009, 03:09 PM   #1
HP Autosport
Supreme Allied Commander
Drives: F80 M3
HP Autosport Adjustable Swaybar Endlinks
When you lower the vehicle, the swaybar is moved from the ideal factory geometry to an offset that decreases the ability of the swaybar to perform. The swaybar frame mount and the end of the bar should be on the same horizontal plane. The factory end links are a solid piece. When the car is lowered, the OEM links cannot compensate for the longer length needed to keep the swaybar in its ideal location. Get immediate response from your sway bar and precise control over your suspension. What this means to you is tighter, more responsive handling.
HP Autowerks is happy to introduce adjustable end links. With adjustable end links you can return the bar to its ideal leverage point while lowered. They also afford the peace of mind that the links or shock link mount will not fail as is common in factory units, as they will now be adjusted properly. The links are adjustable in length up to an additional 1.25" over stock. HP Autowerks end links are adjustable while on the vehicle.
These end links will fit the following vehicles:
E9x 3-Series and M3 Front (no-xi)
E82 3-Series Front
https://hpautosport.com/product/hp-a...ybar-endlinks/
$159.99 pair
Is your jam nut constantly coming loose on you? Apply this wicking thread locker will keep the jam nut from coming loose on you:
https://www.amazon.com/gp/product/B0...d57dbfab1b5a93
      12-21-2009, 07:50 PM   #2
BerkTechnology
BerkTechnology's Avatar
223
Drives: Fast
With cars that are lowered a decent amount past stock like ours we need this to correct our geometry! I'll be ordering soon!
      04-07-2011, 08:50 PM   #3
HP Autosport
Drives: F80 M3
If you have lowered your car or using other after anti roll bar with cheap endlinks, you need these!
      04-14-2011, 10:03 PM   #4
HP Autosport
Drives: F80 M3
FK length adjustable endlinks kits are now in stock. No waiting!
      08-11-2011, 11:23 PM   #5
HP Autosport
Drives: F80 M3
All lengths except for FK's are good in stock.
FK's should be back in stock in a week.
      08-12-2011, 03:33 PM   #6
Georgeku035
Drives: 135
Good
      08-12-2011, 03:37 PM   #7
Georgeku035
Drives: 135
Bump
      09-03-2011, 02:15 AM   #8
HP Autosport
Drives: F80 M3
Originally Posted by Motion View Post
Please PM on availability of E36 and E46 lengths endlinks.
PM sent.
Most BMW applications are good in stock!
      09-19-2011, 11:14 PM   #9
nordique14
53
Drives: SGM 135i 'vert
What is the proper length for a car with a 1.5" drop?
      09-20-2011, 12:22 AM   #10
nordique14
53
What you want to do is get the bar as parallel to the ground as possible. And depends on your setup, you may need something that is 1" or longer...Shoot Harold a PM to confirm though.
I plan on putting on a setup that would drop the car 1.5" in front. I am running the E93 front bar (bought from Harold of course).
I have run aftermarket adjustable end links in the past and all end up becoming noisy at some point. I would love to keep the stock for that reason but it is not good to pre-load the bar. I hope (and expect) the ones Harold sells to be noise-free even after they are on the car for a while.
      10-01-2011, 10:50 AM   #11
HP Autosport
Drives: F80 M3
Our adjustable endlink kits use oem style joints. When installed and adjusted properly they will last a long time. I have seen them break when the installation wasn't proper and too much pre-load were put on them.
      10-17-2011, 11:31 PM   #12
romak47
romak47's Avatar
Drives: like a bat out of hell
these hook up to the stock sway bar correct?
Also, if i have a 1 inch drop, the proper adjustment for the adjustable end links will be a setting longer than stock correct?
If i have a 1" drop should i get the 12" endlinks (min length) ?
JB4, DCI, Digi boost, CSL eyelids, 5% tint, KW v2's. Bastuck 85mm quad w/ berk resonated mids, LED int ltg, Perf SSK, CF int trim, 19" SF-71 rims, CDV mod, BMS OCC, ER+tial charge pipe. AR DP's, Helix IC,meth, drilled slotted rotors
      10-18-2011, 12:10 AM   #13
HP Autosport
Drives: F80 M3
Yes to the first two questions. On the third you can iether get 11.5"(adjustable up to 1.25" longer) or 12"
      10-31-2011, 04:24 PM   #14
HP Autosport
Drives: F80 M3
Adjustable sway bar end links
FK coil over owners...If your FK end links are shot, these are an excellent replacement for them!
      05-14-2012, 03:56 PM   #15
HP Autosport
Drives: F80 M3
FK style links
FK coil over length replacement links are back in stock!
      01-17-2013, 07:03 PM   #16
HP Autosport
Drives: F80 M3
In stock! $159.99
      02-26-2014, 06:11 PM   #17
HP Autosport
Drives: F80 M3
In stock!
      06-12-2014, 04:36 PM   #18
HP Autosport
Drives: F80 M3
in stock!
      08-10-2014, 12:50 AM   #19
Greg FEightytwo
Greg FEightytwo's Avatar
Drives: BMW GT4 M4 and X5M
Hey Harold. I got a set from my friend Marco. I have springs 1.5 drop stock dampers for now. Can you tell me what length I should adjust them to be ideal for my current setup ?
Thanks, g
      08-11-2014, 11:39 AM   #20
HP Autosport
Drives: F80 M3
Thanks, g
From center to center of the joints should be 11.5", you can adjusted for another 1" longer, that should be all you need.
      08-11-2014, 08:03 PM   #21
Greg FEightytwo
Thanks, g
Perfect. Is there a left or right or are they interchangeable ?
      08-13-2014, 01:25 AM   #22
HP Autosport
Drives: F80 M3
There is no left or right, they are the same both sides.
