03-18-2016, 03:12 AM | #1 |
65
Rep 156
Small piece of cardboard fell into the heater vent. What to do?
Today as I was cleaning my car of documents/papers on the dashboard
A small piece of card roughly the size of a calling card fell into the heater vent in front of the dashboard/windshield. Pls see photo below. I tried to get it but it totally went in!! What should i do?? Will it damage the car? Last edited by bmwstve; 03-18-2016 at 03:21 AM.. |
03-18-2016, 07:18 AM | #3 |
Rep 3,203
Is it making noise? If not I wouldn't worry about it at all. I removed the AC evaporator from my E30 once, inside of the case I found portions of two business cards, a paper clip, and 2 AAA batteries.
03-18-2016, 08:07 AM | #4 |
65
Rep 156
as of now it doesn't seem to make any noise. I'm just concerned that it might get lodged onto something or worse get burned due to heat of engine/wiring etc.. cause i don't know how deep it fell
03-18-2016, 08:16 AM | #5 |
Rep 5,577
I think things falling into those vents are so common they're designed with that in mind.
I'm not sure the design of the blower fan and filter in these cars, doubt they're channels are designed that items would drop into the filter housing, but you could access the HVAC filter and see if the card appears. |
03-18-2016, 08:43 AM | #6 | |
Rep 3,947
03-19-2016, 07:57 PM | #7 |
Rep 8,942
If you want to pull the vent just grab it, it pulls right out. Can remove the cardboard then pushes back in place. Pulled mine to run wires for proclip phone mount. Very very easy.
2022 Macan S
2016 F31 328i xDrive Sport Wagon 2006 E46 330ci ZHP Convertible |
03-24-2016, 01:52 AM | #8 |
65
Rep 156
03-24-2016, 07:38 AM | #9 | |
Rep 8,942
2022 Macan S
03-24-2016, 07:50 AM | #10 | |
Rep 5,577
03-24-2016, 08:17 AM | #11 | |
Rep 8,942
For the vents up by the windshield, I would use a vacuum or shop vac and tape the end so there is only a small opening to maximize suction then run it up by the vent and see what happens. I would then assume I got the piece of cardboard and not give it a second thought. |
