BMW M3 Forum (E90 E92)
      08-20-2021, 06:28 PM   #67
icanturn
icanturn's Avatar
Drives: e90 m3
Anyone? Bueller? Ayone?
      08-20-2021, 07:11 PM   #68
Gossypiboma
Drives: 13' M3 6MT 18' M3 CS
So much simpler to use one of the coding apps such as protool.
nah dude237.00
      08-20-2021, 11:44 PM   #69
icanturn
icanturn's Avatar
Drives: e90 m3
I don't have an android device. So I cant use protool.
      05-09-2022, 08:28 AM   #70
VAleksov
Drives: BMW E91
Hi. Anyone know how is work tyre reset button (under the hazzard switch) on M3. And can i use one on non-m car. No have wiring in newtis for this button... Thanks
      05-21-2022, 01:07 PM   #71
SWO Daddy
SWO Daddy's Avatar
Drives: 11 E90 M3
Bumping this thread. Anyone in the San Antonio Texas area that can help me with this coding?
      05-26-2022, 02:35 PM   #72
Tommysalami
Tommysalami's Avatar
564
Drives: E92 M3
Is it possible to code out TMPS without adding in FTM? Would you just change the options to nicht_aktiv and ignore those that change to aktiv? Or will the car flip out if neither is available?
      05-26-2022, 02:44 PM   #73
derbo
Derbo Tuning
derbo's Avatar
3610
Drives: BMW M3
This should be possible. Just leave anything RPA nicht_aktiv and/or remove $265 from the vehicle order.
Edit: I updated the original post with the parameters that would enable FTM as optional.
IG:ruhrohz_m3
Journal: Link
E9x ZCP Suspension Info: Link
Track Chat Discord: https://discord.gg/VsKbTyqBVj
SF Bay Area: DM For coding services
      06-09-2022, 12:00 PM   #74
LandoT
Drives: 2011 E91 328xi
So I had my RDC fail and am having problems getting the FTM to work. I was able to get TPMS coded out without issue. I have everything coded properly from what I have seen using Protool. Deleted 2VB. Made sure the RDC components were all not active, and all the RPA options are enabled in Kombi, DSC, and CIC menus. FTM shows up in my CIC but reset is greyed out. After driving I get a 60AD code. I can clear the code but it comes back after driving more and the reset remains greyed out. I have no other codes that should have an impact. The only other code is for transmission fluid deterioration (which is getting done soon). Any suggestions?
      06-09-2022, 01:26 PM   #75
derbo
Derbo Tuning
derbo's Avatar
3610
Drives: BMW M3
Try adding $265 VO and coding defaults on KOMBI, DSC, CIC. Is the RDC module unplugged?
IG:ruhrohz_m3
Journal: Link
nah dude237.00
      06-09-2022, 07:13 PM   #76
LandoT
I did add $265 and coded them to default as well as tried removing $265 and coding each module manually. Both resulted in the greyed out reset button, FTM System Error in idrive, and code 60AD. For now I just coded them out so I don't get the dash error.
Picanha28.00
      06-09-2022, 07:30 PM   #77
derbo
Derbo Tuning
derbo's Avatar
3610
Drives: BMW M3
Something must be missing to be greyed out.
Since you are a non-M what are the exact parameters you changed?
IG:ruhrohz_m3
Journal: Link
      06-10-2022, 05:56 PM   #78
LandoT
I changed all the settings in Kombi, CIC, and DSC as listed in the first post. The only difference was the DSC module is just DSC and not M3DSC.
      06-10-2022, 06:04 PM   #79
derbo
Derbo Tuning
derbo's Avatar
3610
Drives: BMW M3
In one of the posts the non M one has a different parameter to change. It's like C0F_RPA or something, was that changed too?
IG:ruhrohz_m3
Journal: Link
      06-12-2022, 08:37 AM   #80
LandoT
All I saw was RPA which I set to enable in DSC, I will have to comb through the options again to double check it was the only one.
      06-12-2022, 09:14 AM   #81
derbo
Derbo Tuning
derbo's Avatar
3610
Drives: BMW M3
What version of DSC module do you have? MK60_87.Cxx? This is a non-M right?
In MK60_87.C0F, there is a parameter called C0F_RPA - wert_00 = !direct_RDC
IG:ruhrohz_m3
Journal: Link
      06-21-2022, 08:13 PM   #82
LandoT
All I have seen in the DSC menus on Protool is "variante: DXC_90_16" it's a 2011 E91 328 xDrive.
The RPA options I found:
Ausstattung_RPA, which I have disable for now but it was enabled when I was getting the FTM error.
RPA_Warnschwellwert_1 set to value 2
RPA_Warnschwellwert_2 set to value 1
RPA_Warnschwellwert_3 set to value 04
RPA_Warnschwellwert_4 set to value 09
There is also US_Variante: enabled in the expert mode of Protool under the Tire puncture warning (RPA) threshold value menu.
The only other RPA setting I've found was in JBBF which is RPA_Switch. I set that to active but I am still getting the error with a greyed out Reset button in the CIC
      06-22-2022, 12:22 AM   #83
derbo
Derbo Tuning
derbo's Avatar
3610
Drives: BMW M3
I never tried this with protools so sorry. But in ncsexpert it should show something to enable RPA.
IG:ruhrohz_m3
Journal: Link
      07-29-2022, 06:10 PM   #84
spammysammich
spammysammich's Avatar
1584
Drives: 2009 E92 M3 Dakar Yellow II
2009 BMW M3  [10.00]
I can confirm that the car does not flip out if neither tire monitoring system is active. I removed the RDC module and coded tpms out and had a couple week gap until Alex coded FTM active for me. No adverse behavior from the car in that time. I forgot to have him activate FTM in my display so I can reset it in idrive but that can be done later.
      08-24-2022, 01:15 AM   #85
san40k
21
Drives: 2008 E90 335i N54 6MT
I'm trying to enable FRM on my non-M manual E90 without i-drive and coded KOMBI, don't need to code CIC/CCC and don't know what do I do about DSC module. I do have this in my DSC, should I change it to wert_00 to enable FRM?
C0C_RPA
wert_01
The only other "RPA" option in my DSC is:
C0C_RPA_SCHWELLE
wert_00
wert_02
      08-24-2022, 10:38 AM   #86
derbo
Derbo Tuning
derbo's Avatar
3610
Drives: BMW M3
C0C_RPA
wert_01
C0C_RPA_SCHWELLE
wert_00
wert_02
Change C0C_RPA - wert_00
You should be able to leave C0C_RPA_SCHWELLE alone. That is the threshold to trigger the flat.
IG:ruhrohz_m3
Journal: Link
      08-24-2022, 10:41 PM   #87
san40k
21
Thank you! I should be good to test then (deflate a tire).. TPMS reset is available in the menu but it's unclear if it works or not, no confirmation on reset success or failure is given..
Off to new a new adventure how to get rid of bmw assist
      08-25-2022, 04:54 PM   #88
derbo
Derbo Tuning
derbo's Avatar
3610
Drives: BMW M3
It should say FTM (flat tire monitor if that is enabled instead of TPMS).
BMW Assist is related to $639 VO if you want a hint
IG:ruhrohz_m3
Journal: Link
m3post
