BMW M3 Forum (E90 E92)
Go Back   M3Post - BMW M3 Forum > M3 Marketplace > SPONSORS Classifieds/Groupbuys/Specials Area > Suspension | Brakes | Chassis | Handling
      05-05-2021, 03:57 PM   #1
IND-Distribution
IND-Distribution's Avatar
9588
Drives: G82 M4 / G87 M2
IND | Fall-Line Motorsports E9X M3 Lower Coil Over Camber Arm + Shim Set
*NOTE: ONLY FOR CARS WITH TRUE REAR COIL OVER CONVERSION*
Best of the best. Fall-Line Motorsports has taken everything they've learned in manufacturing over the last decade to create an ultra high-end interpretation of the F8X / E9X lower camber arm.
Fall-Line's bespoke version discards the deformation-prone stamped steel arm that includes a provision for the rear coil spring in favor of 5-axis CNC machined, billet aluminum that eliminates the rear coil mount. This pair has been gorgeously crafted and pocketed (to save weight without compromise to rigidity) and is hard coat black anodized for ultimate resistance to wear. So too has the hardware been given an upgrade—10.9 grade corrosion-resistant extended bolts are included to replace the inferior factory pieces.
These arms represent another exciting entry into the often neglected F8X / E9X suspension arm market and add valuable peace of mind for street or motorsport duty from the undisputed champion within the BMW realm.
Product Details:
  • For all F8X and E9X M3 cars using TRUE Rear Coil Over Conversion ONLY
  • DMG Mori 5-Axis CNC machined, billet aluminum construction
  • Hard coat black anodized
  • Includes Camber Shim Set
  • Sold in pairs
The Fall-Line Motorsports F8X M3 / M4 Lower Coil Over Camber Arm + Shim Set may be viewed at the following link to our online store:
https://ind-distribution.com/product...r-arm-shim-set
Please contact IND by phone or email for more information or to place your order.
866.963.4520 | info@ind-distribution.com
IND DISTRIBUTION | 866-963-4520 • INSTAGRAMYOUTUBEFACEBOOKFLICKR
m3post
