BMW M3 Forum (E90 E92)
European Auto Source (EAS)
      02-23-2009, 04:11 PM   #23
rzm3
Moderator
rzm3's Avatar
673
Drives: E92 M3
Originally Posted by JuniorDee View Post
if an alignment is not done, what kind of tire wear would we see?
Do the alignment. The toe will be completely off after the drop. What's the point of having an M3 if it doesn't handle well?
      02-24-2009, 12:46 PM   #24
JuniorDee
JuniorDee's Avatar
74
Drives: the speed limit
the toe. OK thanks
EDC.....viagra for your car
      03-11-2009, 08:26 AM   #25
tonggi
is FTW!
Philippines
9
Drives: E46 M3 FTW
nice DIY. but 6 hours. ouch!
RIP: 01.5 Santorin Blue 2+ S4, 01.5 Nogaro Blue Avant Stage 3- S4
      03-17-2009, 05:47 AM   #26
isabayo
44
Drives: G05 X5 50i M Sport
great pictures! but 6 hours? ouch! The rear is very simple compared to cars where the rear spring sits on the shock absorbers like the front does.
      03-17-2009, 03:31 PM   #27
MDCTFTW
Drives: E92 DCT
Is any shop equipped to do an alignment on our cars? An alignment at BMW runs $200+
MDCT ... so you can drive and eat a hamburger at the same time.
      03-17-2009, 04:19 PM   #28
GregW / Oregon
Commander-In-Chief
2122
Drives: 2023 M2 Coupe, 2020 GLE 450
Most independent alignment shops can do it. Are you asking about Norcal tuners in particular?
Greg Lake Oswego, Oregon, USA
2023 M2 Coupe - Brooklyn Grey/Cognac/CF, 6MT; 2020 MB GLE 450
      03-17-2009, 06:02 PM   #29
rzm3
Moderator
rzm3's Avatar
673
Drives: E92 M3
Yes, but they may not have the latest specs, procedures, etc.
      05-24-2009, 03:50 PM   #30
michaeldorian
Drives: M2 CS
Does anyone know where I can get the torque specs for the bolts? I'm looking to start the install, but wary to do it without the torque specs.
      05-24-2009, 04:22 PM   #31
chris s
chris s's Avatar
1250
Drives: 2022 Dravit G80 M3
Aren't they all in here:
Torque specs: http://www.m3post.com/forums/showthread.php?t=183005
2022 Dravit/Fiona M3cx - Dinan midpipe w/VC, NW Carbonhaus CF, AST Springs, FC Spacers...more to come!
2016 Indi F80 M3 - SMB|Amaro | Mode Carbon | ESS | Akra EVO | KW HAS...SOLD
2012 MR e92 M3 DCT, ESS SC, Brembo BBK, BBS FI... GONE but not forgotten!
2008 AW e92 M3 6MT, ESS SC, BBS LM's...SOLD!
      05-27-2009, 11:24 AM   #32
MrAdams
do a wheelie!!!
MrAdams's Avatar
Mexico
156
Drives: E46 M3 - '72 2002 - '65 Impala
It did not take me 6 hours. I started at about 11:00 AM and was done by 2:00 PM and we ate lunch after we did the fronts and then started the rear. (following this DIY of course...)
but there was 2 of us.
~Adam
      06-11-2009, 11:49 AM   #33
MVEED3
Drives: '16 GT4
Your pics show a removal of the upper spring hat before wrestling the front shock/spring assembly out of the fender. This must have been a pain. Didn't the shock rod extend out?
I followed the approach outlined in the first link by keeping the assemblies intact while removing them from the car. Unbolted the entire shock from the car to avoid any contact with the body.
The Autozone in my area charges for the spring compressor value but refunds the whole amount when you return them.
Allen
2021 ZR2 Airborne certified
2019 GTS PCCB 5x130 Slick
2016 Agate Grey GT4 PCCB LWB
2013 HP4 Competition
      06-14-2009, 11:39 AM   #34
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Drives: 2006 Honda S2000 TT3
Just finished the front. I removed the three nuts at the top and dropped the whole spring/shock combo and then compressed the spring to give me more room to work. Took me about 3 hours for the fronts. The backs will be after lunch and rehydration.
King Tut
2012 BMW M3 Individual: Sold lsb.ridedomain.com
1987 BMW 325is SpecE30: spece30.ridedomain.com
2009 BMW M3 Coupe: Sold e92.ridedomain.com
      06-14-2009, 11:54 AM   #35
chris s
chris s's Avatar
1250
The rears are a breeze compared to the front. Should take an hour tops!
      06-14-2009, 01:45 PM   #36
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Yeah it should except I was finishing up the 4th quarter after just torquing the bolts, and I notice that the H&R logo is upside down. God damn it, I put the spring in upside down. So now I get to tear it back down and do it again. It was the side with the leveler sensor too so that is even more work. I'm taking a break before tackling it again. Note to others always check and make sure your spring is in correctly before reassembling everything.
King Tut
      06-24-2009, 12:23 AM   #37
doba_s
doba_s's Avatar
Drives: X7 l Cayenne l 997.2RS
yep ... it took us 2h to get it done ...
      07-29-2009, 06:00 AM   #38
isabayo
44
how tight are the bolts? Will I have some trouble loosening some of them?
      07-29-2009, 12:19 PM   #39
MVEED3
Drives: '16 GT4
Depends on the size of your muscles and the tools you have to work with. It's a pretty typical suspension install.
I helped a friend do his springs recently and we left the front assemblies connected at the bottom while swinging the top hats out. This is much easier but requires two people. Someone needs to hold the assembly while the helper compresses/decompresses the spring. I still recommend undoing the hats once the assemblies are pointed away from the car.
Allen
      12-08-2009, 08:34 PM   #40
Crydaddy
pin up model
Drives: E92 m3
thanks again! took me 4 hrs to do it myself. boy was i sore! bump for those that might need it.
      01-01-2010, 07:46 PM   #41
leeor
Drives: 2010 Blue Prius III
is it really that easy? Last time i saw a thread it was like 1800 bolts to remove and shit..
this is pretty easy..
      01-03-2010, 04:24 PM   #42
rzm3
Moderator
rzm3's Avatar
673
Drives: E92 M3
updated...
      03-26-2010, 04:59 PM   #43
VictorH
Drives: '09 M3
" BMW recommends replacing all nuts and bolts"
Where are people buying the nuts and bolts from? Is your friendly dealer the best place?
      03-26-2010, 09:23 PM   #44
Dieselino
Dieselino's Avatar
47
Drives: 03 LSB M3 06 M coupe 08 M3 SG
You dont need to replace the bolts. Give me a break, just put loctite back on the 3 bolts that hold the strut brace and on the main center bolt that holds the hat to the strut.
m3post
