BMW M3 Forum (E90 E92)
Mporium BMW
      03-31-2015, 08:39 AM   #133
vincE92M3
vincE92M3's Avatar
Drives: ///M
'11 E92 M3  [0.00]
I've read conflicting results... Does the 2011 MY benefit from this spring removal?
      03-31-2015, 11:19 AM   #134
thekurgan
Bad Lieutenant
thekurgan's Avatar
Drives: E90M3
2008 BMW M3  [0.00]
The ultimate clutch pedal with the 3-way spring adjustment is the best benefit
02 E39M5 | TiAg/Schwartz | Tubi Rumore | Ultimate Ti Pedals | E60 SSK | Jim Blanton 3.45 40/100% | Coby Alcantara | StrongStrut STB
      03-31-2015, 12:03 PM   #135
vincE92M3
vincE92M3's Avatar
Drives: ///M
'11 E92 M3  [0.00]
Could you tell me more? Is it a replacement pedal?
      03-31-2015, 12:12 PM   #136
thekurgan
Bad Lieutenant
thekurgan's Avatar
Drives: E90M3
2008 BMW M3  [0.00]
100% replacement.
      04-08-2015, 07:22 AM   #137
vincE92M3
vincE92M3's Avatar
Drives: ///M
'11 E92 M3  [0.00]
For 2011+ models, I would recommend just removing the outer spring.
Then getting a UCP.
http://www.m3post.com/forums/showthread.php?t=1109768
      01-08-2018, 05:22 PM   #138
Loki Motorsports
Loki Motorsports's Avatar
13
Drives: 2008 A30 E92 M3 6MT
Just removed this last weekend on my '08.. HOLY S***... Night and day difference. Clutch feel and feedback makes the car so much more enjoyable and smooth to drive. It's no longer a mystery where the clutch will begin to bite on each shift. The clips were a pain to remove, as I didn't have a dental pick. I ended up using a tiny shorty flathead screwdriver to pry them off. Still managed to do it in less than 30 minutes though! 10/10 DIY mod.
-GARAGE LIST-
1: 2008 Interlagos Blue E92 M3 6MT
2: 400 WHP Turbo M52 E36 (Drift car)
      04-20-2018, 05:31 PM   #139
motion732
39
Drives: E92 M3, F30 335 M Sport
So far, so good with removal. Finally able to shift smoothly 1st to 2nd. Only thing i'm not thrilled with is the lateral movement of the pedal. Has anyone done anything to remedy this?
      05-13-2018, 10:53 PM   #140
SwanRonson
Drives: E92 M3
Just did this today - huge difference!
As a tall, gangly dude, it was a pain in the arse trying to get to the clips and pins, and probably took me longer than it should have haha. Totally worth it in the end though!
      03-02-2019, 02:45 PM   #141
S14turbo
Drives: 320is Stock 320is turbo E90 M3
Ummagwd bought the car 2 Werks ago against my e30 italoM3 i thought what a s***t of a clutch. Read this did it love it.
Thank u so much.
Btw anyone solved the issue with the horizontal play of pedal after removing this Part?
      06-29-2019, 09:14 PM   #142
yoslow
yoslow's Avatar
56
Drives: SSII E92 M3
Just removed this on my car, night and day difference - tool tip, one can bend a small screwdriver to serve as a dental pick in a haste
      09-24-2019, 04:50 PM   #143
Johal E32
Drives: 91 M5, 98 M3, 08 M3
1991 BMW M5  [0.00]
1998 BMW M3  [0.00]
2008 BMW M3  [0.00]
I removed this from my 08 M3 about 6 weeks ago.. I wanted to drive the car for at least a month before I formulated my opinion, and I must say, DO IT!
Seriously, I removed the spring and installed a clutch stop from eBay and it feels like a proper sports car now. The clutch pedal throw is short, it grabs quickly, it is consistent and doesn't feel "springy" anymore. There is some movement in the clutch pedal itself, while it is all the way up (not depressed), you can move the clutch pedal about half an inch left or right. This could definitely be annoying for some, but it has not been an issue for me.
Overall this is a nice touch, and I am a fan. If you have any reserves, just do it, you can always put the spring back in..
5 month update: I added bronze AKG clutch pedal bushings and it fixed all of the movement I had previously described. The bushings are $15, I highly recommend them.
jvictormp881.00
      02-13-2020, 04:31 PM   #144
NekMinnit
NekMinnit's Avatar
Australia
9
Drives: BMW M3 E92
So I read the whole thread and there seems to be plenty of pre 09 cars doing this and loving it, and seems there isn't much of a consensus for post 09 cars, I feel the response seems to be about 50/50 for removing the spring. Regardless, i'm going to do this mod over this rainy weekend and see how it goes, I've always thought the clutch needs more feel and is inconsistent in depression force and engagement feedback.
I will report back if I'm not wrapped around a tree...
      12-19-2020, 01:17 PM   #145
Banma
52
Drives: 2017 F80 M3
Just did this on my 08 e90. Initial response is fantastic. Glad I did it. Easily worth the 10 minutes
      09-07-2021, 07:52 AM   #146
Sublivion
Sublivion's Avatar
Drives: 2008 E92 M3
Thank you for this! Car feels so much better for only 15minutes of work
      07-15-2022, 11:38 PM   #147
kooolaid
Drives: e93 M3 Lexus GS300
08 e93 m3 6MT
Just removed springs and installed AKG clutch bushings. Removal of spring definitely improved 1st to 2nd gear change. It's more smooth. SKG bushings also reduced a lot of lateral movement, but installation was super AIPA as it was nearly impossible to reach bolts, nuts, and clips for removal with tools and hands. Someone in this thread recommended installing SKG bushings but one thing you have to know ahead of time is that end clip that's holding the clutch pedal wouldn't go back in unless bushings were grinded. I had to grind about 0.4mm (total 0.8mm) on both sides of bushings in order for the end clip to slide in to lock. Eventhough this job took me a few hours, I'm happy with spring removal and bushing replacement.
m3post
