which is the most reliable e92
02-13-2023, 03:58 AM | #1 |
Rep 6
hey everyone so i was looking to buy a bmw e92 as my first car was wondering which model and year is the most reliable, power isnt my priority but reliability is. i have come aross a 320i mt but ive heard its quite unreliable any suggestion on which model e92 i should go for
ps:we dont get diesel once here :P |
02-13-2023, 11:57 AM | #3 | |
Rep 502
02-13-2023, 02:18 PM | #4 | |
Rep 6
02-13-2023, 02:20 PM | #5 |
Rep 6
i dont think we get 328i here but iam looking for 325i and 330i atm is there any major problems i can expect these models?
02-13-2023, 03:04 PM | #6 | |
Rep 502
- DISA Valves - PCV. You live in a warm climate, you shouldn't have problems 325i suffers from poor piston ring design and can start burning oil. |
02-13-2023, 06:15 PM | #7 |
Rep 3,645
Don't they have the exact same engine? To my knowledge, both use an identical N52b30 with a different intake manifold and tune, at least in the states. I think some parts of Europe got a 2.5 N52 at some point then switched over to the 3.0 for both applications.
02-16-2023, 08:43 AM | #8 |
Rep 502
That's a good point. I'm not sure. I just know the 06 "325i" develops issues with gunked up piston rings which lead to oil burn. It's pretty well documented on the internet.
02-16-2023, 09:43 AM | #9 |
27
Rep 34
Drives: BMW E90 325i 2012 B25
N52 is great, get the 330i for b30 or 325i for b25 especially 2011 and above.
02-16-2023, 01:58 PM | #11 |
4941
Rep 2,996
Drives: 2006 BMW 330i MT
Garage List 2006 BMW 330i [8.21]
2009 BMW 328i Touri ... [7.90] 2013 BMW X5 35i [7.63] 2011 BMW 528i [8.75] 2006 Mazda3 [5.50] |
Don't kid yourself, there will be a LOT of maintenance on a 15 year old BMW, regardless of the engine. Valve cover gasket, oil sump gasket, oil filter housing, accessory belt/tensioner, water pump, radiator/hoses, transmission filter and seals, alternator, starter, front suspension rebuild, rear window regulators, passenger door lock, interior door grabs, trunk wiring, rear subframe & guibos... that's not even everything! You should feel comfortable doing this work yourself, or prepared to pay a mechanic to do it. It won't all hit at once, or even right away, but everything up there will need to be done at some point.
02-16-2023, 04:07 PM | #12 | |
Rep 502
Here are some of my bigger expenses in USD, except Vanos solenoids and CV axle, nothing else was really broken. DISA Valves are a good preventative maintenance at 120k miles, they can break and pieces end up in the engine: Tires $700 DISA Valves $660 CV Axle $450 Vanos Solenoids $300 Vanos Check Valves $80 PCV $330 Coils/Plugs $150 Brake Booster Hoses $100 Power Steering Reservoir Kit, Differential fluids, Transfer Case Fluid, Manual Transmission Fluid, brake fluid, Serpentine belt kit, gaskets, seals, single use aluminum bolts and nuts, good torque wrenches, specialty sockets, specialty tools, pressure bleeder. These things add up FAST. I still have to do oil pan gasket and start budgeting for a clutch job. |
03-01-2023, 09:29 AM | #13 | |
Rep 6
StradaRedlands4940.50 |
03-01-2023, 09:31 AM | #14 | |
Rep 6
03-12-2024, 04:56 AM | #15 |
Rep 3
Tought id add.
1st year with my N52B30 MT e92. So far, starter motor failed and i had to do the usual, brake disks, pads, HB pads, all 4 shocks. I do have rough idle however and the car throws some VANOS codes here and there that i should look into. Oil change every 8k and she runs hella good. |
POBEP365.50 |
