BMW M3 Forum (E90 E92)
      04-29-2012, 09:47 PM   #23
1MOREMOD
1MOREMOD's Avatar
Drives: Race car->
Originally Posted by zhouzitao View Post
We have one in the rear.
yep only one. its a 3 wheel brake system weird.
02 Tiag e46 M3|6MT|GC plates|MCS c.o.|GC bars|GC race control arms|GC bushings|BW eng. & tran. mounts|subframe kit|BW race shifter|BW Jaffster|Euro header|BW exhaust|K&N c.a.i.|Epic race tune|Rouge pulleys|Seibon CF hood|CSL bumper|apr gt 250 & splitter|ST-40|XR-2|SS lines|half cage|Recaro profi|Profi 2 harness|BMWpedals|BW studs|
      04-30-2012, 12:06 AM   #24
Zzhou
Zzhou's Avatar
Drives: 2012 E92 SSII ZCP DCT
Did you do anything to the rear one? I plan just leave it there...lol
AA Green Filter/AA Pulley/AA catless X-pipes/AA signature exhaust/AA TUNE/TMS studs/Project Kics R40/R888/VOLK ZE40/ST60,ST40 BBK/MCS 2WAY NR/Vorsteiner GTS5 Bumper/APR GT250/APR SPLITTER
      04-30-2012, 09:30 AM   #25
1MOREMOD
1MOREMOD's Avatar
Drives: Race car->
I didn't do anything to any of them yet. I'm wondering if a coding would be able to fix this so you no longer get the countdown at all. I pay enough attention to my pads I don't need the car to pretend its doing it even when the indicators arent attached.
      05-31-2012, 12:59 AM   #26
TomElektro
To drift is not a crime
TomElektro's Avatar
Germany
73
Drives: BMW M3 (E92)
Originally Posted by OzStriker View Post
Thanks VictorH.
I have researched the procedure for resetting the service intervals, available here:
http://www.e90post.com/forums/showthread.php?t=51049
However, for a successful brake wear/service interval reset you must replace the brake wear indicator assembly with a new one or you will get a warning saying the pads must be replaced, regardless of previous pad wear.
Does anyone know if the above procedure results in the same signal to the car as you would get when fitting a new brake wear indicator cable?
You can use used indicators for this mod. Did it last week and after a reset of the brake service indicator everything is fine.
      04-09-2014, 02:57 PM   #27
REP1KRR
My other car is a Scooter'ia
REP1KRR's Avatar
85
Drives: M3 Saloon
Originally Posted by JuniorM3 View Post
Cut the connector ends and nice rubber thingies off, twist the two wires that you have now stripped, together and if you have some time solder 'em together.
Sorry, cant tell from the photos. Question.
Which side of the clip is the splice done? Meaning, is the splice done before the box, or after? I wouldn't want to mess with the wires before the box, only if it's after, meaning, between the box/connector and the pad sensor (the "replaceable" section).
Thanks for the clarity!
A91 Edition Supra | Armytrix | Rays
M3 Saloon | Akrapovic EVO | B&G Sport
M3 Saloon | VF540 | Klässen ID M52-R | Akrapovic | Vorsteiner GTS5 | KarbonWerke CSL [SOLD]
      10-09-2014, 02:27 PM   #28
jdamore
jdamore's Avatar
433
Drives: 2008 e92 M3
I think I'll be doing this tonight on my front!
Not because I have aftermarket pads but, because I only have 22k miles and my yellow Brake indicator is on. There is PLENTY of meat on the pads!
According to this, the brake sensor is a Normally closed circuit and Open circuit on Alarm. So, in order to find which sensor has tripped, I should be able to take a multimeter and read 0ohm (or about) across it to find if its ok. Is this correct??
This is for all years of e9x? I have an 08..
EDIT:
Can this just be coded out? I would rather do that!
-- 08 JB e92 6MT ///M3 ESS VT2-625 --
      10-09-2014, 02:39 PM   #29
jdamore
jdamore's Avatar
433
Drives: 2008 e92 M3
Better late than never but to answer your question, you would be modding the sensor cable (between the box and sensor). On the sensor cable, just cut a few inches down from the connector and splice the two wires together..
      10-09-2014, 02:50 PM   #30
Atomicteal_M3
Atomicteal_M3's Avatar
Drives: E90 M3 AW
2007 335i  [9.00]
Great info!
ModeCarbon V1 CF lip/PF AG CF SS ext./ARKYM CF Diffuser/OSS AE's/B&G Springs/CF Performance Spoiler/V2 Led Performance SW/Meisterschaft GT exhaust
      10-09-2014, 03:59 PM   #31
jdamore
jdamore's Avatar
433
Drives: 2008 e92 M3
EDIT:
Well to answer my own question..
I pulled off the front wheels, measured the resistance of both sensors and I got 0ohms on both so I guess that's not my issue..
      10-22-2017, 11:46 PM   #32
MPower7
MPower7's Avatar
90
Drives: 11' e92 M3
Hello, just so I understand this right. If I keep the connector plugged in and zip tied out of the way I will get no lights on dash until the mileage counts down?
Rught now both sensors are out of the car. Once I reinstall them with the OEM pads the light will be off in dash if zip tied or if actually connected to pads?
m3post
