BMW M3 Forum (E90 E92)
BPM
      06-23-2022, 08:09 PM   #573
BimmerRob08
BimmerRob08's Avatar
Drives: 2008 M3, Space Gray
Originally Posted by TX View Post
I really haven’t seen one in a few years or heard from the designer in as long.
If you are ok with just borrowing one, I’ll send you mine as long as you would be so kind as to return it after your job.
That would be very gracious of you and I'll for sure return it. I had to replace my original idler pulley (was making screeching noise) and the other two tensioner pulleys so next is to do my plugs. I was going to attempt to do without but if you are willing to send it to me, I'll hold off till then. Please pm me and I'll reply. Very much appreciated!!
RB
      06-23-2022, 09:23 PM   #574
TX
Drives: 2009 ///M3 E92 APW 6MT
RB
PM sent
      06-23-2022, 11:18 PM   #575
spammysammich
spammysammich's Avatar
1585
Drives: 2009 E92 M3 Dakar Yellow II
2009 BMW M3  [10.00]
I bought a windshield wiper puller from Amazon as suggested and a couple minutes with a grinder gave me an adequate coil puller. Coupled with a KoKen spark plug socket and I managed to get the job done.
      06-24-2022, 12:10 AM   #576
BimmerRob08
That's cool. I should build something for keeps. Do you have a link to that windshield puller you got on Amazon with the right size?
RB
      06-24-2022, 12:14 AM   #577
BimmerRob08
PM sent
Replied to your inbox with info. Thank a bunch!
BOOF-M34451.50
      06-24-2022, 04:10 AM   #578
spammysammich
1585
2009 BMW M3  [10.00]
RB
OTC 4676 Windshield Wiper Puller https://a.co/d/a2i7ocY
Keep in mind you will have to thin the arms down a little with a file or grinder. I think I took about a millimeter off
      06-24-2022, 10:07 AM   #579
TX
Can you check again? I don't seem to have a PM from you.
BOOF-M34451.50
      06-24-2022, 09:39 PM   #580
TX
PM Received. Loaner tool shipped out today. Best of luck man! I've changed plugs 3 times on this car so I'm no expert, but if I can help let me know!
      06-24-2022, 10:26 PM   #581
spammysammich
1585
2009 BMW M3  [10.00]
How do you go about extracting the driver side back coil? That hung me up for 30 minutes before I somehow got it right. I don't recall exactly what I did. Getting it back in was nearly as bad
      06-24-2022, 10:34 PM   #582
Frostynorth
Weirdo
Frostynorth's Avatar
433
Drives: 2011 e92 M3
I wrapped a shoelace around the top circle, and slowly pulled up.
      06-24-2022, 10:34 PM   #583
spammysammich
1585
2009 BMW M3  [10.00]
Oh my problem wasn't loosening it, I had trouble getting it out of there altogether to inspect it.
      06-24-2022, 10:35 PM   #584
spammysammich
1585
2009 BMW M3  [10.00]
Even with unclipping the fuel lines I had a hell of a time getting it in and out of the area
AndyW672.00
      06-25-2022, 12:03 PM   #585
Frostynorth
Weirdo
433
Drives: 2011 e92 M3
It took patience, but it does come out without moving anything out of the way, as far as I remember. Didn't remove the plenum either, it's definitely a tight fit.
      06-25-2022, 09:05 PM   #586
TX
It's a tight fit. I usually spin the pack until the connector is at an angle that allows it to clear and then rotate it to the proper position once clear. The rubber at the bottom has a little give to it which also helps for that last 1/4 inch.
      06-26-2022, 01:58 AM   #587
BimmerRob08
Keep in mind you will have to thin the arms down a little with a file or grinder. I think I took a out a millimeter off
Right on! Thanks.
      11-27-2022, 11:20 AM   #588
TxStig
Drives: 2008 E92 M3 Jerez Black
Rumor has it the Division M Coil Pulling tools will be back in stock in the very near future:
https://www.amazon.com/dp/B00J9P0TYE
https://www.amazon.com/dp/B01GZ3XZQG
Sorry for the hiatus....
m3post
