BMW M3 Forum (E90 E92)
      01-13-2021, 10:09 PM   #221
Jbishaw
Drives: N/A-looking
Bump for the helpful DIY!
      01-17-2021, 06:54 PM   #222
Genes1s
Genes1s's Avatar
32
Drives: 1997 E36 M3/4/5. 2011 E82 135i
Did you guys re-use the 14 Torx bolts when installing the pan or get new ones?
1997 Artic Silver E36 M3/4/5
2000 Sunlit Sand Nissan Maxima 5 SP
2011 Space Gray E82 N55 DCT.
      01-17-2021, 10:56 PM   #223
Audioslave686
Audioslave686's Avatar
Drives: M3 E90/X4 F26
I reused mine
      08-06-2021, 02:28 PM   #224
E90Freedom
Drives: 2011 E90 M3 ZCP
Thanks for the DIY!
      08-18-2021, 05:22 PM   #225
Mimmer
Mimmer's Avatar
57
Drives: E92 13'
2013 e92 m3  [0.00]
Jw what milage you have all done it at.
Hitting 83k no track days .... Just DD ...
Plan doing it closer 90k mark if not 100k
      09-02-2021, 11:46 AM   #226
Ximian
Ximian's Avatar
Drives: E92 M3
2011 BMW M3  [0.00]
2021 BMW M3  [0.00]
I think me was around 88k when I got the Slon pan. You should be able to see smoother shifts with fresh fluid, that's a great benefit for a daily driven car. I would do it sooner than later.
Engine oil change, DCT fluid, diff fluid, and spark plugs replacement is the ultimate tune up for a smooth daily.
Mimmer57.00
      09-02-2021, 09:31 PM   #227
AndyW
Supreme Galactic Commander (one galaxy over...)
AndyW's Avatar
Drives: '08 E93, '12 E82, '13 E93 M3
I did new.
Best,
Andy
'12 E82-PS2,Stoptechs,Clubsports+M3 bits,Accusump,Wagner DP+EVO III FMIC,ERCP,BMS Intake,Mason Strut Bar,Wedge Tune
      09-24-2021, 09:32 PM   #228
Andryuha
21
Drives: '06 Z4M '00 Z3M '11 S212
I had a shop do this service (should have DIYd it) and I'm not sure it was done correctly because my transmission now shifts like dog $#!7. What's the easiest way to reset the adaptations? What's the best way of verifying the fluid level (open the fill plug and see if any fluid will come out?
      08-31-2022, 10:19 PM   #229
Binary420
Binary420's Avatar
9
Drives: 2008 E92 M3 DCT
2008 BMW M3  [9.33]
Can you describe the issue with shifting you were or are experiencing?
I did this service, including the pan and filter, and now every time after starting from a complete stop, and only in 1st gear, (doesn't happen starting in 2nd gear) the car jerks forward as if I drove over a speed bump at 15 mph..
Then continues on driving fine, other than the fact it is also shifting hard... -like old crusty dog s%%t- hard
You can reset the adaptations by putting key in ignition, and turning on ignition without starting the engine.
With car powered on( gas Guage is up) hold down the gas pedal for 60 or so seconds, and with gas pedal still depressed, power off ignition and remove key.
Let car sit for 2-3 minutes then start engine
I know those directions definitely reset engine adaptations, not sure about transmission adaptations but worth a try
      10-06-2022, 01:33 PM   #230
Tommysalami
Tommysalami's Avatar
564
Drives: E92 M3
Did this recently using the oil balancing procedure in ISTA. Just want to add that ISTA has a few menus that will read out the transmission temp, but the first couple pages' readings aren't updated live and will leave you there thinking the temp isn't going up even though you've got the engine on.
The first live updating temp reading will be when you get to the later menu that says there's max transmission cooling enabled. Once you've done the initial fill, just know to continue through the menus till you get to that page.
      02-08-2023, 03:27 PM   #231
Mimmer
Mimmer's Avatar
57
Drives: E92 13'
2013 e92 m3  [0.00]
jw do you need to replace this? my shop was rec to doing it..
BMW Dual Clutch Transmission Oil Pump Filter - Getrag 28107850148
https://www.fcpeuro.com/products/bmw...ag-28107850148
      02-12-2023, 08:09 PM   #232
GORDON.M3
GORDON.M3's Avatar
1423
Drives: E92 M3 • F25 X3 M-Sport
Yes, replace this. The filter is old and replacing it would improve the filtration.
INSTAGRAM: GORDON.M3
North American Mr12Volt Carplay/Android Auto Distributor
DINAN | EVOSPORT | VAC | ARP | RD SPORT | NEEZ | EIBACH | CSF | IND | BILSTEIN | KLASSEN | BREMBO | ENDLESS | BBS | BPM SPORT | PROJECT MU | EVENTURI
Mimmer57.00
      03-18-2023, 07:30 PM   #233
spammysammich
spammysammich's Avatar
1585
Drives: 2009 E92 M3 Dakar Yellow II
2009 BMW M3  [10.00]
Tip: never re-use the filter cap, the o-ring will eventually harden up and go flat. The pressure filter was leaking bad enough that I would drop about three tablespoons of fluid at startup and God only knows how much I dribbled all over creation before I parked it in October.
      03-18-2023, 11:50 PM   #234
drwankel
drwankel's Avatar
1049
Drives: 2012 E92 M3 ZCP, 2021 M340i
That is one flat o ring!
      10-17-2023, 06:36 AM   #235
rated_m3
28
Drives: 2011 BMW E92 M3 ZCP
Can someone please explain why people are changing the filters? Also, people are mentioning that there really is no distinguishable differences in shifting from before vs. after. My other question is related to the fluids color. Does the fluid color change really affect the quality of the fluid? The fact that someone swapped black fluids out after 2k miles of just putting in fresh pink colored fluids indicates that it’s normal for it to change color. On engine oil it turns brown because that means it’s doing it’s job and it doesn’t necessarily mean that the oil needs to be changed because it’s the filter which is the main part that needs to be changed. It just seems like over kill especially when all these Blackstone results are coming back virtually the same. I understand gaskets being changed with fresh fluid due to leaks, but why not just leave everything else and save some money? Someone mentioned here that there is a fine line between preventive maintenance and wasting money. It seems like people are having problems by even changing these parts out like weird shifting as someone has mentioned here and another thread. I’m at 123k miles and the car shifts fine. I feel like I’ll just end up with the same Blackstone results like everybody else lol
      10-17-2023, 09:17 PM   #236
bigjae1976
bigjae1976's Avatar
1571
Drives: 11 E90 M3 Individual
2004 BMW M3  [4.50]
2011 BMW E90 M3  [5.25]
2013 BMW 328i  [5.00]
I just did the 3rd DCT service. I used the method here for the previous 2. Always had to add more fluid. I started to get a judder when going into reverse.
For this one, I cold fillled then used an Autel MX808 to do the oil balance and THEN I hot filled. I used every bit of 7 liters of fluid. Then I cleared the adaptive values. The car shifts much smoother and no judder when going into reverse.
The bad news, the head on the fill plug came off. The fill plug is soft aluminum which prevents over-torqueing. Being this is the 4th time this plug has come out...should have been prepared.
The drain plug is M18x1.5...I was able to get a volvo oil drain plug which is working. Waiting for the new plug to come in so I can replace it. Whoops.
The fluid came out relatively clean with 30k on it. So I'll probably wait until the pan leaks to do another service.
2018 F30 320iX Melbourne Red
2011 E90 M3 Monte Carlo Blue
2004 E46 M3 Imola Red
2000 E36/7 Z3 Steel Blue
      10-17-2023, 09:23 PM   #237
bigjae1976
bigjae1976's Avatar
1571
2004 BMW M3  [4.50]
I've done 3 services at 50k, 75k and 105k. The oil was pretty nasty and thick at 50k, the oil pan was leaking so I was replacing the pan anyways. The oil came out pretty clean at 75k and 105k.
I'm inclined to say do at least one service and then plan to do the next when you have a leak. You will have a leak at some point from either the mechatronics cover or oil pan. I tightened all of the bolts on my mechantroics cover once but it is leaking. I need to do rod bearings and engine mounts soon. So I'll tip the engine/trans back so I can replace the cover gasket. I might lose some oil but I'll just top it off.
The oil pan is probably going to be leaking by the time it hits 130k to 140k...so it will be time for a service.
      10-18-2023, 12:16 AM   #238
0-60Motorsports
0-60Motorsports's Avatar
Bahrain
792
Drives: BMW M3 JB 04 Coupe
IS there no way or replacement parts that stop the leaking Like viton gaskets maybe and better made side cover and pan?
Current Mods:
2004 E46 M3cs JB/CSL
2010 E70 X5M AW/BLACK
2011 VW Golf R DSG White/Black
IG: @060Motorsports
      10-18-2023, 12:38 PM   #239
bigjae1976
bigjae1976's Avatar
1571
2004 BMW M3  [4.50]
No idea.
      10-18-2023, 12:48 PM   #240
spammysammich
1585
2009 BMW M3  [10.00]
There used to be a company that made a viton gasket set for like 700 usd. Not sure if they are still available. I ended up just installing a Fall Line lower pan with a viton oring style gasket. The side cover is metal and should hold up better than the plastic pan but the rubber gasket is still a failure point. As is the top mechatronics cabling seal.
      10-18-2023, 12:52 PM   #241
spammysammich
1585
2009 BMW M3  [10.00]
bigjae1976 you might want to order that fill plug from fcpeuro so you can get a fresh one every service. I’ve begun replacing that full plug and the motor oil drain plugs every service rather than risking breakage or stripping of the Allen sockets.
      10-18-2023, 07:45 PM   #242
bigjae1976
bigjae1976's Avatar
1571
2004 BMW M3  [4.50]
I got two, one spare.
m3post
