10-08-2018, 08:53 PM | #23 |
#LSBM3
1420
Rep 1,973
Drives: 2016 BMW M3
Garage List 1984 BMW R65 [0.00]
2020 Ford F-150 XLT ... [0.00] 2003 Mitsubishi Evo ... [0.00] 2016 M3 Competition ... [10.00] |
That turbo is huge!
/// M3 |
10-08-2018, 11:42 PM | #24 |
Rep 4,551
Drives: 2015 328d xDrive
I would assume OP had a budget to stick to. You can obviously buy used F30s for a lot less than F8X's. That means more money available for crazy projects like this.
ceedawg467.50 |
10-09-2018, 01:11 AM | #25 |
Rep 605
This question always comes out. People should pay attention to peoples location. From what I hear, F8x's in eastern countries are way overpriced. Even with this big project you're still way under of what an F8x would cost over there.
10-09-2018, 02:44 AM | #27 |
1078
Rep 2,358
What happened to your crank shaft? Looks like it got way too hot at the journals or is it tempered like that from the factory? Where do you get the octane from? Dual CM5 100% meth does not sound like much on 91.
cookiesowns How is the tuning going? Cool you are onboard here also
M135i 8AT PWG, MHD, Pure Stage2, WMI via Torqbyte CM5-LT, Custom tuned by PureBoost
(A Dane in China) |
10-09-2018, 03:06 AM | #28 |
140
Rep 216
Drives: F30 335i PWG
Well to answer the F8x question, here in Egypt it would be much cheaper for me to mod my 335i than buy an F8x, since the customs to import a car is close to 150% it just makes more sense for a lot cheaper plus I like being different and having a sleeper of sorts
2013 335i BSM ~ Stage 3 turbo, forged internals and more check out my build thread https://f30.bimmerpost.com/forums/sh...7#post23789807
AndrewC198910931.00 Logicoeur992.50 |
10-09-2018, 03:09 AM | #29 | |
140
Rep 216
10-09-2018, 04:21 AM | #31 |
140
Rep 216
Sorry didn't see that, I went with stock compression ratio and no to the stroker as I didn't want to go through any machining as I don't trust machine shops here in Egypt.
10-09-2018, 04:46 AM | #32 |
1078
Rep 2,358
Low comp pistons not available? With only 91 and such a big turbo you should definitely have gone low comp!
(A Dane in China) |
10-09-2018, 04:59 AM | #33 | |
140
Rep 216
10-09-2018, 08:36 PM | #36 | |
3179
Rep 2,577
Stroker have many benefits - 1) reduced boost for same flow so less octane required, 2) improved off/low boost power/torque response, and 3) lastly and the most importantly less turbo lag at any rpm. If you have enough octane, stroker don't necessarily add peak power, but benefits above can justify give you're already installing new rod and piston.
Lemania 2320
10-09-2018, 09:16 PM | #37 |
Rep 969
sub'd. This is badass!
10-09-2018, 09:43 PM | #38 |
17504
Rep 8,427
UGE !!
10-09-2018, 11:17 PM | #39 | ||
140
Rep 216
10-10-2018, 03:03 AM | #40 | |
587
Rep 898
Should easily be at PS2 93 octane power levels for a similarly tuned car, at just "stage 1" levels of boost on 91 With just a few tweaks, turbo is making target boost ( 13psi ) by 4200rpm. Can probably have a spool a bit earlier if we wanted to. For now waiting for a good base map to dial in some basics before we start adding fuel and turning it up.
BM3, MHD, ECUTek Calibrator | N55/S58 specialist | 2023 X5 45e Frozen Marina Bay Blue
Dfahmy139.50 |
10-10-2018, 04:07 AM | #41 |
1078
Rep 2,358
Thought about adding MILV now that you are at it?
https://f30.bimmerpost.com/forums/sh....php?t=1451059
(A Dane in China) |
10-10-2018, 05:33 AM | #42 | |
Rep 1,348
Finally what are the hp goals ? Appears we are looking at a motor build that should be capable to exceed 700whp easily. This motor will be equivalent to a built S55 motor equipped with the same pistons and rods you are using. Love this! I would suggest the TFFS high volume fuel pump while you are at it. [/url]
2k15 335i Msport xdrive 6spd
Wagner Comp2 FMIC,FTP CP,stock exhaust. Fabspeed Sport catted DP, KW V2 coil overs,FBO BM3 Stg 2 Last edited by ceedawg; 10-10-2018 at 05:46 AM.. |
10-11-2018, 05:30 PM | #43 | |
Rep 1,230
N55 GENERAL
David Shoup Tuned Fully Built By Miami Engines/Project Motorworks Precision 6266 On Steroids |
ceedawg467.50 |
10-12-2018, 07:36 AM | #44 | |
140
Rep 216
ceedawg467.50 |
bigboost, built engine, custom tune, forged internals, methanol injection, n55, port injection, stage 3 |
