12-03-2019, 03:56 PM | #1 |
2921
Rep 21,727
▀▄ eas | ESS Tuning G1/G1+ Intercooled Supercharger Systems now released!
ESS Tuning is a name that has become synonymous with uncompromised performance in the BMW world. With over 2000 S65 supercharger systems sold since 2008, ESS's E9X M3 S65 supercharger kit is by far the most popular BMW supercharger system worldwide.
Kits ready to ship. Full sales, installation and dyno tuning available in-house. The ESS G1 intercooled Supercharger System produces a massive 150-180whp gain from stock depending on fuel used and exhaust system installed. It is supplied with both 91AKI/95RON and 93AKI/98RON pulleys as standard. ESS G1+ users can expect a 180-220whp gain over stock depending on fuel quality and pulley used, ESS's kit improves upon the OEM intake manifold, adding in a custom cast aluminum manifold with optimized runners flowing into CNC’d aircraft-grade 6061 aluminum velocity stacks to smooth out airflow and reduce disruptive turbulence entering the throttle bodies, and is centered around the market’s largest liquid intercooler system. This ensures the intake charge temps remain in check during prolonged use on the track, autobahn, or street. The manifold was designed not only for optimum flow, but to be both aesthetically pleasing while keeping weight to a minimum to not disrupt the iconic handling balance of the M3. The new ESS G1 supercharger head unit is by far the lightest high capacity supercharger in the industry weighing in at only 9.5lbs and offering unparalleled efficiency, build quality and ultra low noise levels. However, what really sets the S65 kit above all the others is ESS's software tuning. For over 22 years, ESS has lived and breathed BMW’s, and it becomes apparent the second you sit behind the wheel of an ESS tuned car. The kit will include the ESS E-Flash OBD2 cable and specific MSS60 engine software that has undergone over a decade of revisions to get perfected to where it is today. The E-Flash interface (include) allows the end user to upload the supercharger ECU software from any PC running Windows 7 or newer and includes full diagnostic and code clearing capability. Any future ESS software updates can be received by email and loaded directly to the car. The stock ECU software will be saved and can easily be restored in the future. ESS G1/G1+ system maintains all OBD-II functions and it is backed by a comprehensive 2 year, unlimited mileage warranty program. The G1 kit takes 6-12 hours (8-14 hours for G1+) to install using normal hand tools and no irreversible modification to the car is necessary. ESS G1/G1+ Supercharger systems are a reflection of their zero compromise approach to supercharging. Only the best quality components are granted a place in their kits and you can be sure it all fits with absolute precision. After development, ESS vigorously tests both the hardware and software, putting them through their paces on the street, track, and autobahn. Through this, we achieve reliability and quality that is on-par with the OEM themselves. This helps create the ever-desired OEM+ look for an appearance that says “take me out for a nice dinner, but don’t be afraid to use the back roads and let me loose on the way home.” ESS G1/G1+ Supercharger Components ESS G1 Supercharger System components - ESS Engineering G1 supercharger unit - Cast aluminum ESS intake manifold with integrated 6061 T6 velocity stacks optimized for boost - High capacity liquid intercooler system - Vortech Maxflow Race bypass assembly - High temperature cast plastic intake system for SC - Uni-belt drive system with additional ESS lifetime billet idlers - Heavy-Duty drive belt - CNC hard anodized brackets and hardware - High temperature silicone hoses with clamps - ESS oil breather assembly designed for boost - 8 larger Bosch Motorsport fuel injectors, G1 spec - 6PK S65/98mm (91AKI/95RON) and 6PK S65/94mm (93AKI/98RON) supercharger pulleys - K&N high flow air filter - ESS E-Flash reprogramming and diagnostic interface - Perfectly optimized, dyno tweaked MSS60 ECU software with removed top speed governor, calibrated for G1 spec injectors - Detailed, step-by-step installation manual - All installation hardware included - 2 year/unlimited mileage warranty ESS G1 Supercharger System Specs 6.5-7.5 PSI intercooled, 150-180whp gain over stock depending on fuel quality and pulley used, torque: 30-40% gain over stock depending on fuel quality and pulley used ESS G1+ Supercharger System Specs 7.5-9 PSI intercooled, 180-220whp gain over stock depending on fuel quality and pulley used, torque: 35-50% gain over stock depending on fuel quality and pulley used ESS G1+ Supercharger Systems The ESS G1+ Supercharger system is designed for 93AKI/98RON fuel or above exclusively, in order to use the included high boost supercharger pulley a methanol injection system (available separately) must be installed. We recommend the Snow Performance Stage 2 system using the #5 nozzle set to 3PSI start and 7PSI full gain. Torco or VP methanol is recommended. This G1+ system is based on the S65 G1 supercharger system and contains all of the same components with the exception of: - ESS S65 G1+ specific 7rib beltdrive system with all billet pulleys and idlers - ESS G1+ spec fuel injectors - Manifold pre configured for Snow Performance methanol injection system. - Perfectly optimized, dyno tweaked MSS60 ECU software with removed top speed governor, calibrated for G1+ spec injectors - 7PK S65/92mm (93AKI/98RON) and 7PK S65/88mm (93AKI/98RON + methanol) supercharger pulleys. Ordering: Phone: You can reach us directly by calling 866.669.0705 x31 to place your order over the phone. Payment: Credit/Debit Cards: Visa, Mastercard, Discover, PayPal, Google Checkout (available online & over phone) Other Payments: Money Order/Cashier's Check & Bank Wire Transfer are also available. Please contact us to pay with either of these methods. Shipping: All orders will be shipping via UPS. If you are interested in shipping to Hawaii, Alaska, or internationally, please contact us directly, as you will be charged additional shipping fees. Hours of Operations: Monday - Friday from 9AM to 5PM PST Saturday - 9AM-2PM PST Sunday - Closed Retail Location/ Installation Center: Come check out our 8000 square foot facility in Anaheim, CA. We install everything we sell! Contact Info: Phone: 866.669.0705 x 31 Email: Kevin@europeanautosource.com Website: http://www.europeanautosource.com Feel free to contact us via PM, email, or phone if you have any questions - or to schedule your install today!
Kevin S. | european auto source (eas)
email: kevin@europeanautosource.com · web: https://europeanautosource.com· tel 866.669.0705 · ca: 714.369.8524 x31 GET DAILY UPDATES ON OUR BLOG · FACEBOOK · YOUTUBE · FLICKR · INSTAGRAM Last edited by kevin @ eas; 01-09-2020 at 06:36 PM.. |
12-05-2019, 06:36 PM | #2 |
2921
Rep 21,727
Thanks for the inquiries
Now taking orders for G1 kits PM today to get yours
email: kevin@europeanautosource.com · web: https://europeanautosource.com· tel 866.669.0705 · ca: 714.369.8524 x31 GET DAILY UPDATES ON OUR BLOG · FACEBOOK · YOUTUBE · FLICKR · INSTAGRAM |
12-18-2019, 04:56 PM | #3 |
2921
Rep 21,727
Now taking orders for the NEW ESS G1 supercharger
PM today for details
01-06-2020, 06:03 PM | #4 |
2921
Rep 21,727
ESS G1 and G1+ kits now shipping
01-09-2020, 04:37 PM | #5 |
2921
Rep 21,727
01-21-2020, 06:05 PM | #6 |
2921
Rep 21,727
576WHP on 93 octane
ESS G1 kits ready to ship PM today to get yours
02-05-2020, 06:46 PM | #7 |
2921
Rep 21,727
ESS G1 kits now shipping out!
02-24-2020, 06:27 PM | #8 |
2921
Rep 21,727
Another G1 kit being installed at EAS
Sirius Black18.00 |
02-27-2020, 05:00 PM | #9 |
2921
Rep 21,727
03-09-2020, 05:20 PM | #10 |
2921
Rep 21,727
ESS G1 kits ready to ship out
03-24-2020, 06:31 PM | #11 |
2921
Rep 21,727
ESS G1 kits ready to go
PM today to get yours!
04-08-2020, 06:33 PM | #12 |
2921
Rep 21,727
05-17-2020, 12:35 AM | #13 |
Rep 999
Howdy.
Sorry for the dumb question I have been away from the platform for a few years. What's the difference these kits and the old 625/650 kits?
Performance ESS 625 VT2 Supercharger - CAE Shifter - Revinora race+ axle back - Macht Schnell down pipes - SOSI X-pipe Looks M colors grill - CF trunk - Sapphire Blue Forgestars F14 |
05-21-2020, 06:26 PM | #14 |
2921
Rep 21,727
PM today to get yours Same hardware but different supercharger unit. The G1 unit is more compact and quieter.
email: kevin@europeanautosource.com · web: https://europeanautosource.com· tel 866.669.0705 · ca: 714.369.8524 x31 GET DAILY UPDATES ON OUR BLOG · FACEBOOK · YOUTUBE · FLICKR · INSTAGRAM Last edited by kevin @ eas; 05-21-2020 at 06:33 PM.. |
06-04-2020, 05:35 PM | #15 |
2921
Rep 21,727
ESS g1 kits ready to ship out
06-29-2020, 06:01 PM | #16 |
2921
Rep 21,727
ESS G1 supercharger kits now shipping
07-08-2020, 10:24 AM | #17 | |
Rep 822
Thank you
Previous - '11 E90 M3 6MT Stripper Full Cloth
Current- GT3RS,MR e90 and SG E92 Comp |
07-08-2020, 12:27 PM | #18 |
2921
Rep 21,727
Tried responding twice to your PM but both days said your inbox was full.
07-08-2020, 12:28 PM | #19 |
Rep 822
Thank you. Cleared now!
12-08-2020, 03:29 PM | #20 |
2921
Rep 21,727
ESS G1 kit in stock and ready to go
12-14-2020, 05:35 PM | #21 |
31
Rep 69
Hi! Can you cast some light on the difficulty level of installing this kit for DIY'ers. Like many, I can do some basic maintenance on my e93 m3 but, for example, I don't own a lift. What level of tinkerer can self-install this? thanks.
12-14-2020, 06:42 PM | #22 |
2921
Rep 21,727
PM coming your way
Johnr352463.50 |
