      09-10-2008, 12:16 PM   #23
vone
Drives:
Beyern Multi 18"
Wheels: Beyern Multi
Front: 18x8.5 ET40
Spacer:
none
Rear:
18x8.5 ET40
Spacer:
none
Tires:
Front
Yokohama S drive 225/40 R18
Rear Yokohama S drive 225/40 R18
Suspension/Fender Mods/Camber:
none - Spec recommended by beyern ppl
Notes:
TIres and rims almost flush, just had them, will update if there are any rubbing issues. Currently waiting for tires to rub in before taking corners harder.
      09-11-2008, 01:49 PM   #24
Monaco35Dream
Monaco35Dream's Avatar
Drives: 08' 135i, 96' Talon Tsi AWD
2008 135i  [0.00]
Wheels: Velocity VB3 CSL (Hyperblack)
Front: 18x8.5 ET40
Spacer: None
Rear: 18x9.5 ET45
Spacer: None
Tires:
Front Pirelli PZero Nero 225/40/18
Rear Pirelli PZero Nero 255/35/18
None
Notes:
Fits and looks great!!
      09-18-2008, 06:06 PM   #25
mikeo
Santa Fe Concorso
mikeo's Avatar
Drives: '11 M-sport 328i, '13 X1 28i
Attempt #3
Wheels: Breyton GTS-R
Front: 18x8.5 et48
Spacer: 5mm
Rear: 18x8.5 et48
Spacer: none
Tires:
Front: Dunlop Direzza Sport Z-1 Star Spec 245x40-18
Rear Dunlop Direzza Sport Z-1 Star Spec 265x35-18
We have minor 'rubbage' at all four corners even with stock suspension. Stock but will require moderate fender rolling front and rear with possible camber plates in front for extra negative camber. There is just enough front inside clearance to the strut.
Notes:
Different brand tires may not be as much of an issue as the Zed 1s are noticably wider than most other brands in the same size. The 245x40 fronts are too tall, I should have gone with 225x40 and 245x40 in this tire with this fitment. Or better yet, since the Star Specs are not available in this size, another brand tire in 245x35-18 all around for proper rotation.
Santa Fe Concorso - The Southwest's Premier Automotive Gathering.
      09-23-2008, 09:59 PM   #26
pkcormier
15
Drives: 135i
Perfect Fit
Front: 18x8.5 et48
Spacer: 10 mm
Rear: 18x8.5 et48
Spacer: none
Tires:
Front: Kumho Ecsta v700 245x35-18
Rear Kumho Ecsta v700 245x35-18
Vorshlag camber plates at about -2 and above mentioned spacers. No fender rolling.
Notes:
Perfect fit. No rubbing. Could probably shoehorn a 255 in front. 255 would fit easily in back. Great track package. I can swap front to rear and flip tires on wheels if necessary to extend tire life. I'm using 15mm spacers up front with stock wheels to fill in the fenders because of -2 camber.
Can't find my camera cord to download pics. Here is a pic from a recent track event.
http://hart-photography.com/photocart/index.php?do=photocart&viewImage=522717
      09-28-2008, 04:41 AM   #27
Cris
What's FWD?
10
Drives: Former E82, current E39
^^^ Linky no worky.
      09-28-2008, 09:39 PM   #28
pkcormier
15
Drives: 135i
Works when I hit it. Try this
http://hart-photography.com/photocar...ewImage=522717
      10-05-2008, 08:07 PM   #29
stunn2night
no tire gaps
Armenia
Drives: 135
AC TYPE II im not sure of the offsets but i only tried them on and they stick out to much I really like these wheels i can see it in a flat balck,
what do youi guys think?
      10-05-2008, 11:14 PM   #30
BerkTechnology
BerkTechnology's Avatar
223
Drives: Fast
Looks a little odd with those offsets. Can you even drive it like that? The simple spoke design doesn't look too bad on the 1er though.
      10-06-2008, 12:46 AM   #31
professor
Drives: Z4 M40i
Tires:
Front Yokohama S drive 225/40 R18
hmmm...i am interested in your choice. you say beyern recommended this setup for you? interestingly, ACS also suggests a square 225 setup. can anyone venture an explanation as to why this might be?? my knee-jerk reaction is that they are possibly just attempting to create a neutral handler and find that it is easiest to do so with a 225 rather than work at something larger...
      10-06-2008, 02:09 PM   #32
stunn2night
no tire gaps
Armenia
Drives: 135
I felt like i was driving a tank LOL and tires were LOUD! it has a very authenic bimmer look with these wheels, I wish they fit perfect cuz these wheels are hard to find.
      10-09-2008, 03:54 PM   #33
Nemizis
Drives:
Wheels: Raplica, M6 m325
Front: 8,5 x 19" ET 35
Spacer: none
Rear: 8,5 x 19" ET 35
Spacer: nonce
Tires:
Front Budget 235/35R19
Rear Budget 235/35R19
Orignal M-sport (15mm)
Notes:
rubbing in back while taking a speedbumb with 30kmt+
Note that I dont have backseats in the car, so it is lightweight.
I have allready sold them because off the rubbing. To spring i might but them again, and get them drilled a little, or might go with somw 20"
      10-26-2008, 08:07 AM   #34
WAY
Australia
458
Drives: Fast ones
Wheels: BBS RS-GT forged 2 piece wheels
Front: 18x8 et35
Spacer: none
Rear: 18x9 et45
Spacer: none
Tires:
Front: Bridgestone RE55s R-compound 225/40R18
Rear: Bridgestone RE55s R-compound 225/40R18
KW Clubsport lowered but can't remember how much/ No fender mods/ Negative 2.8 at the front and negative 2.4 at the rear. Rear camber was adjusted using factory adjustments available for the car. Front camber is achieved through KW's racing mount which is part of KW Clubsport coilovers.
Notes:
We started the exercise by putting a 265/35R18 on the rear, but these don't even come close to fitting. Then we put on 245/40R18, but they just rub slightly. Bear in mind this is a R-compound tyre and they are very square shouldered like most R-compound. In fact a 225 probably has a foot print of a 245 on a normal tyre. Also I think a 245/35R18 would have fitted, due to it's smaller (and factory spec) overall diameter. Unfortunately not many R compound come in that size! Btw, a non R-spec 245/35-18 will fit quite comfortably I would say (but I haven't tried it) due to much more rounded shoulders. Have a look at the picture below of the tyre I used and see how aggresive the shoulders are.
Not sure how the 225 rears will hold up on the track given my mods...find out next Friday.
Edit: I can now confirm that my 225 R Compound tyres are as wide (in fact slightly wider) as the factory 245. Hence you should be able to have 245 all round with a normal tyre no problem on this wheels with the same set up as me.
      11-14-2008, 03:42 AM   #35
BerkTechnology
223
Drives: Fast
Wheels: D-Force EmPower
Front: 18x8.5 +40
Spacer: none
Rear: 18x8.5 +40
Spacer: none
Tires:
Front: Dunlop Direzza Z1 Star Spec 255/35/18
Rear: Dunlop Direzza Z1 Star Spec 255/35/18
-KW V3 lowered ~1.5" front, ~1" rear
-Vorshlag camber plates (front)
-slight fender roll front & rear
-had to cut some of the plastic out from the inner fender well
Notes:
These Dunlops run quite a bit wider than the Toyo R1R's that were previously mounted on there. The rears would rub when going up driveways. At the track event we just ran, there was zero rub.
      11-15-2008, 11:45 PM   #36
twinturbo135i
twinturbo135i's Avatar
34
Drives:
Here's my setup:
Wheels:
Breyton Race GTS-R (bright silver)
Front: 18x7.5 +45
Spacer: none
Rear: 18x8.5 +48
Spacer: none
Tires:
Front: Yokohama S-Drive 215/40/18
Rear: Yokohama S-Drive 245/35/18
Suspension: stock
former 135i owner - ditched it for a new Camaro SS
      12-12-2008, 08:23 PM   #37
mchaskell
Traveler
Drives: 135i
Wheels: Rial Como
Front:
17x7.5 35mm
Spacer:
none
Rear:
17x7.5 35mm
Spacer:
none
Tires:
Front
Yokohama Avid W4S 225/45-17
Rear
None
Notes:
Fronts rub on bumps.
135i SGM, Grey w/Grey Poplar interior.
      12-15-2008, 03:00 PM   #38
emongoose
emongoose's Avatar
Drives: '08 135i
For those interested in tires for winter performance:
Wheels: Stock
Front: 18x7.5
Spacer: none
Rear: 18x8.5
Spacer: none
Tires:
Front: Bridgestone Blizzak 225/40/18
Rear: Bridgestone Blizzak 255/35/18
Suspension: Stock
Notes: Zero rubbing. Excellent street traction (experienced 14 deg F so far).
Now back to our regularly scheduled program...
      12-16-2008, 10:21 AM   #39
randomquickness
Drives: 996tt
Wheels: DPE R-16
Front: 19x8
Spacer: none
Rear: 19x10
Spacer: none
Tires:
Front: Kumho Ecsta SPT 235/35/19
Rear: Kumho Ecsta SPT 265/30/19
Suspension: H&R Sport Springs and Sway Bars
Notes: rubbing at all 4 corners...final solution TBD
GBE827.50
      12-22-2008, 01:46 PM   #40
trfortin69
Drives: 135i Convertible
215/40/18 front 255/35/18 rear Any issues
Would there be any issues with this set up on Stock 264 rims?
Jet Black/Savvanah Beige - Premium Package, Cold Package, Ipod, Style 142 Winter Wheels w/ All season runflats, Style 264 Summer Wheels w/ Ventus V12 evo K110 225/40R- 18 Front 255/35R-18 Rear
Prior Vehicles: 2002 Porsche Boxster, 2004 A-4 Ultra Sport Stage II software/injectors w/ stasis street sport suspension, 2006 e90 w/ sport, premium, cold.
      12-26-2008, 01:40 AM   #41
deeb
boss.
19
Drives: 135i
No.
.:08::black::135i::6speed::stick:.
      12-26-2008, 09:44 AM   #42
mikeo
Santa Fe Concorso
mikeo's Avatar
None other than aggravating the already present understeer. Try 225x40 in the front.
      12-26-2008, 10:52 AM   #43
trfortin69
that's what i was wondering, so the smaller the tire in the front the more understeer is created?
set up with 225 in front instead of 215.
      12-26-2008, 11:12 AM   #44
ZIPNBYE
Let's save military ranks for those who earn it!
ZIPNBYE's Avatar
45
Drives: ...on the Ragged Edge
Setup
Wheels: Sport Edition F10 - Machined with Black accent and BMW centre caps
Front: (17x8) (+40 offset)
Spacer: (none)
Rear: (17x8) (+40 offset)
Spacer: (none)
Tires:
F & R (Nokian) (studded Hakkapeliitta 5) (205-50-R17)
none
Notes:
Handles winter with aplomb!
Richard
2013 BMW M3 Individual -- Fire Orange (sold)
2013 BMW X1 xDrive35i M-Sport -- Valencia Orange (sold)
2011 BMW 1-series M Coupe (#205/220) -- Valencia Orange (sold)
2009 BMW 135i M-Sport Coupe -- Space Grey (sold)
