      07-07-2009, 11:41 PM   #89
Motorsports_3
E30 Addict
Drives: 2008 135, 1988 325
Wheels: VMR V713
Front: 19x8.5 +45
Spacer: none
Rear: 19x9.5 +45
Spacer: none
Tires:
Front Nitto NT555 Extreme 225/35/19
Rear Nitton NT555 Extreme 245/35/19
Suspension/Fender Mods/Camber:
-H&R Coilovers. Front all the way high, rear all the way low
-No Roll Front
-Had to cut some of the plastic out from the inner fender well in the rear
-Rear fenders are trimmed.
      07-08-2009, 12:49 AM   #90
Olivier_TFE
sport pilot
Spain
Drives: BMW 135i Alpine White
Please, if you can follow this model, better. Thanks.
Wheels: D-Force EmPower
Front: 18x8.5 +40
Spacer: none
Rear: 18x9.5 +43
Spacer: none
Tires:
Front Yokohama Advan Neova 255/40/18
Rear Hankook RS2 Z212 265/35/18
-KW V3 lowered ~1.5" front, ~1" rear
-Vorshlag front camber plates (brings the tires "in" more, away from the fender lip), ~2 deg neg camber front & rear
-slight roll front & rear
-had to cut some of the plastic out from the inner fender well
Notes:
Rubbed front fender where fender meets bumper (...)
      07-08-2009, 01:49 AM   #91
adrean8j
adrean8j's Avatar
121
Drives: SGM 135I
2008 135i  [10.00]
Wheels:
Vorsteiner V-302
Front 19x8.5 offset uknown
Spacer: none
Rear 19x9.5 offset uknown
Spacer: none
Tires:
Goodyear Eagle F1 Asymmetric
225/35/19 and 255/30/19
Suspension:
KW V1 Stock ride height due to rubbing issues in the rear
Slight roll on rear
Notes:
Rubs bad over big dips and potholes. Slight rub during hard cornering. Considering scrapping the rear wheels and going with different sizes because it is becoming expensive to get the current tires to stop damn rubbing...not to mention in this doggone area of the country every body shop or so-called tuning shop is scared to roll a damn fender..."we dont want to crack your paint and be held liable" GRRRRRRRRR!!!.......sigh.
Originally Posted by ptack View Post
SGM was God's color and has been recalled to heaven.
      07-08-2009, 01:50 PM   #92
Motorsports_3
E30 Addict
Originally Posted by adrean8j View Post
Wheels:
Vorsteiner V-302
Spacer: none
Spacer: none
Tires:
Suspension:
Slight roll on rear
Notes:
Wow that really sucks. Those wheels are supposed to be custom made. Hell, I could make some wheels with the right offsets to fit. I would make them fix that for the ammount of money you spent.
You may want to cut your fenders and go 245/35 for the rear tires.
      07-08-2009, 03:06 PM   #93
BMWeber
Drives: 08 135i
Dam that is hot I want thoes wheels.
Originally Posted by Motorsports_3 View Post
Wheels: VMR V713
Front: 19x8.5 +45
Spacer: none
Rear: 19x9.5 +45
Spacer: none
Tires:
-No Roll Front
      07-09-2009, 09:53 PM   #94
adrean8j
adrean8j's Avatar
121
Drives: SGM 135I
2008 135i  [10.00]
I have already had them sent back once due to centercaps not fitting. So 8 weeks for them to be manufactured, 6 months for me to get back from Iraq, another 3 weeks for them to look at the wheels and make sure that they have some centercaps for me....and now the rubbing issue (and one other semi-related issue...PM if you want to know about that). My small consolation is Nick and Ali@Jlevi have brainstormed with me about what I could do to fix the rubbing issue as well as given me an assurance discount on the soon to be released Vorsteiner Hood....
I want to cut the fenders but the shops around here a scared to do anything. I have to take an hour drive up to Charleston just to get someone that works "High-End" (Audi, BMW, Mercedes....LOL...makes me laugh cause in Germany, where I lived most of the last two decades, these are everyday cars) can LOOK at it...then make an appointment....and then drive up there AGAIN to hopefully get it fixed...and THEN do a complete alignment...sigh....LOL
      07-25-2009, 02:57 PM   #95
RaceTime
Auto X'er
Drives: 2009 Space Gray 135i
TT/Autocross set up
Wheels: Breyton GTS-R
Front: 18x8.5 +48
Spacer: 10mm
Rear: 18x8.5 +48
Spacer: none
Tires:
Front Dunlop Star Specs 255/35/18
Rear Dunlop Star Specs 255/35/18
-H&R Pro coil and springs- all the way up in front and lowered 1/2 in the rear
-Vorshlag front camber plates (brings the tires "in" more, away from the fender lip), 2.6 degrees in front (max)
-BMW strut brace
-Custom rear strut brace
-Dinan Stage 2 tune
-Injen Intake
-G-Force harnesses
-BMP Tow hooks (for track racing)
Notes:
Front rubs a little bit over bumps. Front tires are really wide, if you were to turn and go up a big bump...bye, bye fender. Set up is unbelievable for racing, not what I use on the street (that is what stock tires are for). Unbelievable amounts of grip and very little understeer, even with over 400 hp!
      07-25-2009, 04:44 PM   #96
Justin(OKC)
Justin(OKC)'s Avatar
Drives: 1988 M3, 1990 M3, 1998 M3/4
1998 BMW M3/4  [10.00]
2011 BMW M3 Sedan  [9.28]
1988 BMW M3  [9.40]
1990 BMW M3  [10.00]
2008 BMW 135i - sold  [0.00]
2003 BMW M3 - sold  [0.00]
Front: 18x8.5 +48
Spacer: 10mm
Rear: 18x8.5 +48
Spacer: none
Tires:
-BMW strut brace
-Dinan Stage 2 tune
-Injen Intake
-G-Force harnesses
Notes:
I'm a little confused. If it rubs up front like that, how is it ideal for racing? Can you eliminate it by adding more camber up front? I'd be more concerned about damaging the fenders on the track.
1988 BMW M3 - Hennarot/Black
1990 BMW M3 racecar - Diamond Schwarz/Black
1998 BMW M3 - Alpine White/Mulberry
2011 BMW 328i racecar - LeMans Blue/Black
      07-27-2009, 09:02 AM   #97
RaceTime
Auto X'er
It rubs just a little bit...it is certainly not ideal. I would like more camber, but with the sways and the coilover set up that is max camber. I am looking for more grip and to loose the understeer. The tracks in Colorado are quite smooth, so no worries about damaging the fenders as long as you stay on the black stuff...
      08-08-2009, 03:53 AM   #98
yophop
yophop's Avatar
Luxembourg
Drives: bmw 123d coupe pack M
Hello,
Here are photos of my current one
Wheels: BMW performance
Front: 18x7.5
Rear: 18x8.5
Tires:
Front: Bridgeston potenza runflat 215/40/18
Rear: Bridgeston potenza runflat 245/35/18
And my ancient
Wheels: Répliques bmw style M6
Front: 19x8.5
Rear: 19x8.5
Tires:
Front: Dunlop sp sport maxx 225/35R19
Rear: Dunlop sp sport maxx 225/35R19
      08-14-2009, 05:34 PM   #99
Rudedog
Drives: 128i
what offset were you running on your M6 reps?
I'm new to 1series and have a good deal on a set of M6 reps in 18x8 ET35, I know the offset is quite low... just want to make sure it is doable before i pull the trigger.
let me know, thanks!
      08-18-2009, 01:46 PM   #100
hellrotz
Drives: 00 Z3 clown shoe
Originally Posted by jurrian @ eas View Post
Can't believe I didn't post this before, but better now than never. Here's the set up on our 135i:
18" VMR Gunmetal CSL Style Wheels:
Fronts
18x8.5" ET40
225/40-18
Rears
18x9.5" ET45
255/35-18
Car is lowered on KW Coilovers
so hot
      09-02-2009, 05:13 PM   #101
neilisthestig
Lack of charisma can be fatal
Drives: BMW 120i SE
my new wheels!
Hey Guys, first post! I'd like to thank you all for the information on here that helped me buy my wheels (hope pic has uploaded correctly).
they are 18x8 with an offset of 38, tyres are 225/40 all round and as yet have had no rubbing.
sorry pic isnt great car needs a clean and it was taken on my phone! car is sydney blue 120i SE everything standard bar wheels!
      09-18-2009, 10:49 PM   #102
Raflekt
Raflekt's Avatar
20
Drives: 2009 AW 135i fully loaded
I bought Potenza RE 11 225/45 , tomorrow i will track the car, do you think im going to rub on the front?
Stock rims and stock suspension
Tnx!
2009 AW 135i
CP-E CATLESS DPS, AFE EXHAUST , OIL COOLER KIT,FORGE DVV,,BMW PERFORMANCE SIDE SKIRTS AND BMW P . PEDALS, BMW PERFORMANCE SPOILER , BMW PERFOMANCE KIDNEY GRILLS, CODE 3 IC, DIREZZA Z1 STAR SPEC
      09-22-2009, 02:13 AM   #103
Olivier_TFE
sport pilot
Spain
Du you are in 17 inches?
The RE11 225 R18 no rub front/rear. I think in 17 no rub...
Y have RE11 225 front with Bilstein PSS10 + camber plates Vorshlag: NO rub.
      09-25-2009, 03:12 PM   #104
Macca916
Macca916's Avatar
England
Drives: X6 XDrive35D
Summer rims
18x8 et40 front (225x40)
18x9 et42 rear (235x40)
The fronts rub the wheel arch liner joint on full bump, suspect some minor trimming will solve it.
      10-01-2009, 11:17 AM   #105
Eddy@ApexWheels
Eddy@ApexWheels's Avatar
445
Drives: E30 M3, F10 M5
The following is results of prototype wheel test fitments. I'll be trying many different configurations so I'll post those up as well.
Wheels: APEX ARC-8
Front: 18x9" et42
Spacer: none
Rear: 18x9.5" et62
Spacer: none
Tires:
Front Nitto NT-05 245/40/18
Rear Nitto NT-05 265/35/18
Suspension/Fender Mods/Camber: 100% stock 135i
Notes:
zero issues in the back. the tire is close to the inner noise dampening mat, but not touching. looks like there is room for a 275/35/18. I will test that out, and on a lowered car as well. This is the only wheel that allows for this much rubber in the rear, and it weights in around 18lbs~.
The front was purely an experiment to provide the forum data. the tire is 0.5-1mm away from the strut tube. This would need a 3mm spacer for me to feel comfortable when actually driving around. rubbing did not need to be tested as it was clear on a stock car this would not work. with camber plates and around 3 degrees negative camber this wheel would work.
The intended wheel for the front is an 18x8.5" et38, which will be tested this week.
      10-12-2009, 10:12 PM   #106
goldn
goldn's Avatar
30
Drives: 2010 E91 328i xDrive 6MT
hi, not a user of 1addicts...
looking for some help.
will any of these fit a '09 128i?
TIA
Originally Posted by kol View Post
FS: 4x 16" Bridgestone Blizzak LM-22 Runflat RFT w/steelies & BMW hubcaps
Tire details
used: less than 3K
tread remaining: 10/32 (orig started with 11/32)
Even wear
Made in Japan RUNFLATS
Wheel details
OEM BMW 16" steelies - will fit 2006 323, 325 for sure and should fit 328
OEM Silver BMW hubcaps
Mounted and balanced and ready for pickup (NO TPMS)
Pickup in Markham
$550 (costed me $1200+)
others sets of similar tires w/o steelies are asking for more and have less tread
Reason for selling: mounting 17" winters
Originally Posted by FKhanro View Post
Gauging interest. Thinking of selling my winter set up. They have 3 months of use on them. Here is a link to when they were on the car:
http://www.e90post.com/forums/showthread.php?t=197281
The tread is probably 95%. Three of the rims have started getting some minor clear coat damage but the fourth wheel looks like it needs a refinish on the lip.
The tires are 225/45/17 Polaris 2 (?). Got them from Steelecase. They said they were made by Continental.
Center caps not included. Looking for $600.
Originally Posted by pelichrons View Post
Hi there just got this set of 17" - 8" BMW 158 Alloy Wheels and basically new (probably not even one season) Bridgestone Blizzaks LM-22 Studless Runflats 225/45/R17 from Budds BMW in Oakville as a "customer satisfaction" gift.
I am going to be winter storing my car so i wont be needing these. Wheels are in amazing condition and tires look basically new... very deep tread.
Please no low balls, we all know what BMW charges for this setup up so here is a chance to save some big bucks!!!
Serious inquiries only
Thanks
PM or E-mail: pspirou86@gmail.com
sis-in-law needs a winter set up.
      10-13-2009, 11:19 AM   #107
Flat Out 32
Flat Out 32's Avatar
Drives: my feet.
Originally Posted by yophop View Post
Hello,
Front: 18x7.5
Rear: 18x8.5
Tires:
And my ancient
Front: 19x8.5
Rear: 19x8.5
Tires:
Those BMW Performance OEM wheels are hot!! It would be even nicer if they could make the 19" from the 3 series fit.
On another note, BBS CH pics would be nice!
Georgie Vazquez
Mayaguez, PR
R.I.P. 335i, 010 135i here!
      10-30-2009, 03:19 AM   #108
bankerkys
bankerkys's Avatar
Drives: 2022 BMW M340i
Fronts
18x8.5" ET40
225/40-18
Rears
18x9.5" ET45
255/35-18
Looks fantastic. What brand tires are you running? Did you have to roll the fenders?
      10-30-2009, 12:03 PM   #109
tom @ eas
General
tom @ eas's Avatar
Drives: BMW
2018 BMW i3s  [5.00]
2010 BMW M3  [6.50]
2015 BMW M4  [6.20]
We are using 255/225 Dunlop Direzza Star Spec in that photo, a minimal amount of fender rolling was needed in the back due to the KWs.
email: tom@europeanautosource.com · web: https://europeanautosource.com· tel 866.669.0705 · ca: 714.369.8524 x22
GET DAILY UPDATES ON OUR BLOG · FACEBOOK · YOUTUBE · FLICKR · INSTAGRAM
      11-07-2009, 04:18 AM   #110
smudge74
Drives: 1 series M Coupe
Prodrive GC-014i forged
Front: 18" x 7.5
Rear: 18" x 8.5
Front: Michelin Pilot Sport 2 225/40/18
Rear: Michelin Pilot Sport 2 255/35/18
