BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > 2012-2019 BMW 3 and 4-Series Forums > General F30 Sedan / F32 Coupe / F36 Gran Coupe Forum > Force Neutral Testing
proTUNING Freaks
      09-14-2013, 06:45 PM   #1
SomeRandomer123
SomeRandomer123's Avatar
England
306
Drives: F30 328i Luxury - Sport Auto
Question Force Neutral Testing
As we AT owners know all to well, the transmission cannot be placed from P to N with the engine off. This means you must start the engine when you could otherwise just roll the car forwards/backwards and this is annoying.
Now, SamS said the following would work when carzaddict's transmission buggered up and left him stuck in P:
WITH FOOT ON BRAKE
With ignition on:
Hold top (release) button on the gear stick while doing
- put gear stick one step forwards and hold 2 seconds,
- then one step back again
- then one step forwards again
Then the car is in neutral for 15 minutes
I tried this out on my UK 328i and it didn't work. So my questions are, does this work on your US cars?
Is it exclusive only to the ActiveHybrid 3 like SamS has?
Is this possible on UK (EU) F30's?
Can anybody else force neutral from the selector lever in the EU and/or UK?
Maybe if we could find some definitive answers, a Sticky could be produced to hopefully prevent other members being stuck by the side, or even worse, in the road if their F30 decides it would rather not function as intended.
Unfortunately, I don't hold out many hopes on this one, but worth a try!
Gone: 2006 BMW E60 520d SE 6MT
Gone: 2009 BMW E90-LCI 330d SE 6MT
Current: 2012 F30 328i Luxury 8AT
On Order: 2015 Audi A6 Avant Ultra, Black Edition (sorry!)
      09-14-2013, 10:53 PM   #2
elistan
Drives: F30 328i, AP1 S2000
Nope, didn't work for my US spec 2013 328i.
      09-15-2013, 02:16 AM   #3
Frogman
Drives: 2012 F30 328i
Apparently this procedure only works when you crank the engine without it actually starting (good battery, bad engine). If the car won't crank (i.e. the battery is dead), you are SOL.
If the engine is able to start, there's already a procedure for getting it into neutral. It's the "car-wash" mode:
From the manual:
Before driving into a car wash
In order to ensure that the vehicle can roll in a car wash, take the following steps:
Automatic transmission:
1. Release the parking brake, refer to page 63.
2. Drive into the car wash.
3. Depress the brake pedal as needed.
4. Engage transmission position N.
5. Switch the engine off. In this way, the ignition remains switched on, and a Check-Control message is displayed.
When the ignition is switched off, position P is engaged automatically. When in an automatic car wash, for example, ensure that the ignition is not switched off accidentally.
      09-15-2013, 06:46 AM   #4
SomeRandomer123
England
306
Hm, must only be with the starter motor turning, as mentioned above...
      09-15-2013, 08:53 AM   #5
bavarianride
Drives: bimmer
Then if the battery is dead, how to put the AT into neutralfor pushing onto towing flatbed?
      09-15-2013, 10:18 AM   #6
elistan
Jumper cables to supply electricity, perhaps?
      09-16-2013, 06:50 AM   #7
SomeRandomer123
England
306
I believe there is a physical force neutral a BMW engineer can access underneath the car.
automatic, f30, force, neutral, transmission
