05-25-2014, 10:34 AM | #1 |
Rep 508
Finally installed my LED headlights
Finally, with all of the information in hand and long weekend ahead, yesterday at 5:00 am in the morning I decided it was the right time to put my LED headlight in on my 2011 X6M. Something I have been planning to do for almost six months now. What a difference in looks, brightness, performance and overall appearance it makes. Finished by 6:00 pm. If anyone wants to attempt this or has any questions regarding the retrofit (or wants to buy my old lights ) feel free to ask. I will be glad to share every bit of my experience. By the way, local BMW dealership refused to do it - too complicated of a job for them
05-25-2014, 12:50 PM | #4 |
Rep 36
That looks sick! Well done
2010 BMW X6 35d | Alpine White | Black Nevada | 21" Ferric Grey Style 215 Wheels | Colour Coded | Media | Dynamic
Done: 2014 Map Update To Do: Lux Angels | LCI Tails | Remove Running Boards | Remove Roof Rails | Reverse Camera Retrofit | Spare Wheel Retrofit |
05-25-2014, 08:34 PM | #6 |
Rep 508
For LED tail lights, its a simple unplug old, remove, install new and plug them back. Should not take more than 1 hour for all four pieces. Fender lights are held in place by three nuts each (inside of a trunk). Trunk lid lights are held in by one nut each, to access it you will have to remove two small access doors located within trunk lid trim. No coding required. I also changes my license plate lights to LED. Those had to be coded to remove warm and cold checks (FRM3 module). Real project begins when you decide to replace your headlights. That's when it gets a bit tricky and times consuming. I will be more than happy to assist with any questions or coding issues since I have just finished it all
06-14-2014, 04:40 PM | #8 |
17
Rep 122
Great job & nice looking,
could you tell me how much are the LED head lights? what are the parts that i need to replace the headlights? i think you need new harnesses , does it needs coding? |
06-14-2014, 05:05 PM | #9 |
2020 Mineral White 30d MSport
523
Rep 2,146
Drives: 2020 Mineral White 30d MSport
Congrats it is not an easy job for sure!
My retrofit was installed by the local dealer, I think I made a great deal, paid retail price with installation included. I'm still thinking in retrofitting the rear lights, but not decided yet....
....Life is too short to drive boring cars
06-14-2014, 07:30 PM | #10 |
Rep 508
Original BMW LED headlights with both control modules should run between $900 - $1300 US$, harness approx $100, new FRM3 module approx. $300. If you source it all from BMW dealership, expect to pay more. There is very minimal coding that's required for this retrofit. Mainly remove two items from VO, add LED lights to VO and then re-code FRM, KOMBI and CAS modules with new VO. Coding is the least difficult part of this retrofit.
06-14-2014, 07:35 PM | #11 |
Rep 508
I wanted to let my local BMW dealership perform this retrofit, they refused to do it. Told me they do not have enough technical knowledge to get it done. Apparently this retrofit is not available in USA, only Europe from what I understand. Basically, what BMW dealership told me is that BMW of NA will not support them with this retrofit and provide any technical information in case something does not go 100% during the installation / coding. Therefore, I attempted to do it myself and glad that I did. Saved close to $1K by doing it myself, gained great experience and spent all day outside, working on my X6M (which is much more enjoyable that letting dealership perform the operation )
06-17-2014, 10:32 AM | #13 |
Rep 508
No cutting or modification required. As long as you use original BMW wire harness and original BMW LED headlights, it is all plug-n-play. Just take your time and double-check every connection while doing this to avoid having to take it all apart again to figure out why something is not working correctly. Like I mentioned, for me it was one full day; however, all worked 100% from the start, no issues at any point of retrofit. If you are planning to do this one, feel free to PM me for any questions
07-03-2015, 12:47 PM | #14 |
Chief Warrant Officer 4
53
Rep 726
Drives: 335I, E46 M3, X5M
bump for more info or a DIY guide
07-09-2015, 06:54 PM | #17 |
Tanzanite Blue II X5M Pilot
1041
Rep 2,020
Drives: M3, M4, X3 M40i, X5M
Apparently Xenon projectors are no longer the rage...LED headlights are now the latest, fashionable high end upgrade for BMW. They do not use Xenon projectors in LED headlights at all; LED emitters are used instead.
07-10-2015, 07:38 AM | #19 | |
31
Rep 188
Drives: 2012 BMW X6 50i
This looks sick! Great job on the retrofit! Could you share where you purchased the LED headlights and exactly how much you paid for them please? =) I was looking into purchasing LEDs to upgrade the halogen angel eyes on my 2012 X6 but this looks muchhhhh sexxxxier! If it was a perfect fit on your 2011 X6M then it should fit on 2012 X6 50i right? |
07-12-2015, 11:12 PM | #20 | |
Rep 508
07-13-2015, 12:16 PM | #21 | |
31
Rep 188
I appreciate your input though. Thank you! |
07-24-2015, 02:08 PM | #22 |
BeastM3r
1286
Rep 1,657
There is possible to do this retrofit on my 2012 x5 M-Sport ?
Thanks
MORR WHEELS - VORSTEINER HOOD - FRONT LIP-CF REAR DIFFUSER - LED HEADLIGHTS - BREMBO BRAKES - Kw SUSPENSION - EISENMMAN - JB4 - SPORT STEERING WHEEL..!
coding, frm, headlights, led, retrofit |
