What is the best method for cleaning the Intake Manifold
01-12-2018, 04:13 PM | #1 |
Rep 1,473
I am sure that the best method is Ultrasonic, but other than that what is next best. I figure that I will clean my manifold while in the process of installing my EGR Race pipe and Swirl flap delete .
I am also curious if the valves and the head runners needs to be cleaned at 61k miles. I guess that I will know when I remove my Intake, but I am wondering if it is common. |
01-12-2018, 04:28 PM | #2 |
Rep 1,157
Very common on the 335d to need this. Not so much on the X5. You'll know when you see it. Ultrasonic is best, some part houses(NAPA, AutoZone, O'Reilly's) have ultrasonic cleaners that they can use. I'd call around. Next up is soaking the intake manifold for a few days in Purple Power degreaser.
01-12-2018, 05:25 PM | #3 |
170
Rep 328
Another member here (socale39) had mentioned he used acetone with good results. He's got a DIY somewhere (x5) for the manifold and swirl flaps and that's what he used.
01-12-2018, 06:26 PM | #4 |
Rep 3,558
Along with the purple power, a long a$$ bristle brush from Walmart did me well. I recall sleeper saying he used gasoline and it ate it right off. I have no direct experience here (with gas).
01-12-2018, 11:02 PM | #6 |
54
Rep 238
01-12-2018, 11:05 PM | #7 |
196
Rep 291
Get a kilogram of caustic soda crystals.
Get a plastic container big enough to contain the inlet manifold in (bare) Fill with the caustic soda crystals, and the fill with warm water. Leave it overnight, in the garage or such and let it soak. It should dissolve the Carbon and gunk right off. Rinse off with water hose thoroughly. |
01-13-2018, 10:37 PM | #9 |
BRR tuned
220
Rep 646
Have you seen the cost of a new one? Last I looked I think it was near 1000$
I soaked the intake while I was at work then pressure washed it... That seems to be the best method for That. The best for the head is to walnut blast it. ... I half added mine and used a long brush with a little degreaser and a vacuum to suck the junk out.. It worked out just fine for me |
01-14-2018, 07:59 AM | #10 |
Rep 1,579
Just did CBU on my X5d last month. I took the intake to a machine shop who made it look new for $50. I have no idea what they did but they said something like "we will put it in with the aluminum". Keep in mind the last 3" of the upper intake runners are formed into the valve cover. That part needs to be cleaned by hand and you can't let it fall into the cylinders. In my case, hitting it with a blast of walnuts to break apart the tar balls, was the only way to vacuum it out.
I also hand cleaned the swirl flaps after soaking them in citrus based de-greaser for 2 days. The black crud stains everything it touches and is tar like in consistency. It was easier to buy cheap wire brushes and throw them away rather than clean them. It is that bad. My X5 intake was a complete mess at 75k miles. My 09 did not get the 2011 software update that helps with CBU until 2016. My valves were not that bad but I walnut blasted them anyway. The intake runners up to the valves were a mess all the way down. The software update really did help preventing the CBU. I cleaned the EGR after the software and after 25k miles the EGR CBU was not as bad when compared to the first time I saw it. |
