BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Wheels and Tires -- Sponsored by The Tire Rack > BMW F30 on 20inch rims
Extreme Powerhouse
      05-29-2014, 02:28 PM   #23
dtn
Prince of Zamunda
dtn's Avatar
Drives: '13 AW F30
Originally Posted by roundel335 View Post
Just keep in mind that:
a. 20" wheels with very low-profile tires will be more likely to get damaged by potholes and other road hazards
b. They increase ride harshness because there's less sidewall to absorb bumps
c. The tires cost more to replace than 18" versions
d. They're heavier than 18" wheels (unless you buy super-expensive lightweight versions), which can have a negative effect on handling
Be really careful with wheel offsets, or the tires will rub the fenders/suspension.
a. What do you consider low profile for a 20" wheel?
b. Yes the ride harshness increases but the F30 already rides really soft (too soft in my opinion); with non-runflats, the ride softens as well.
c. Of course.
d. Increase in tire width with larger wheels can positively affect handling. A larger wheel is more rigid which can positively affect handling as well.
e. Lowering the car positively affects handling.
IMO 20" wheels on a F30 is a no brainer. Add a drop and you transform the car's aesthetics and handling.
      05-29-2014, 02:29 PM   #24
dtn
Prince of Zamunda
dtn's Avatar
Drives: '13 AW F30
Originally Posted by TAGMS View Post
I think the F30 NEEDS 20" wheels. but thats just me.
      05-29-2014, 02:46 PM   #25
RoundelM3
RoundelM3's Avatar
Drives: 15 F80 M3, 22 G01 X3 30i
2022 BMW X3  [9.83]
2015 BMW M3  [6.50]
c. Of course.
a. 35 section and below is very low-profile. Avoid potholes and other road irregularities.
b. My F30 doesn't ride "really soft" or soft in any way, but then I have DHP on an M-Sport line.
c. Not only are they more expensive, but are sometimes harder to find.
d. I did not mention increase in width, but rather increase in diameter; more metal is required for a larger wheel, resulting in higher unsprung weight. The same is true when increasing wheel width unless you purchase lightweight forged wheels (around 20lbs each), which are generally significantly more expensive than standard cast wheels.
e. Lowering can have a positive effect if you track your car; on the street, it's a tossup, as you now have less ground clearance and are more susceptible to the aforementioned road hazards, especially speed bumps. Screwing with the car's suspension, especially if you have DHP, can affect warranty as well as handling, and not necessarily in a positive way.
I agree - 20" wheels on an F30 could be indicative of a lack of brains -I'm just messin' with ya . Depends on what kind of image one is attempting to project. 20" wheels on a 5, 6, or 7-series? Sure...suits the bigger, heavier car, same as on an X5 or X6. For an F30, it's sort of like "Fernando" (Billy Crystal) used to say about how it was "better to look good than to feel good, you know what I'm saying to you?"
2015 F80 ///M3 Sedan 7DCT Tanzanite, 2022 X3 sDrive30i 8AT Brooklyn Grey
      02-20-2015, 11:48 PM   #26
cmonter3323
20
Drives: 428i GC
what offset should I run on my f36 428i if the wheel measures 20x8.5 and 20x10. also what size tires do you recommend as well, thanks guys
      04-09-2015, 11:46 PM   #27
cmonter3323
20
Drives: 428i GC
Originally Posted by AMJAM View Post
They fit with no problems I have 20x8.5 front and 20x10 rear a seen in pic below
what tire sizes are you running?
      04-11-2015, 12:18 AM   #28
obriennathaniel
@obriennathaniel_f30 on Instagram
obriennathaniel's Avatar
Drives: 582whp/596wtq '13 335i
These pics are a little old, but the wheel and tire specs are in my sig, this is while i was on H&R super sports. Im on coilovers now and about 1/4" lower.
CG Precision VS-1 Exhaust\DR-1 DownPipe | PS2 Turbo\Inlet | PDU PI w/Fuel-it platinum kit & E sensor | GFB DV+ Diverter Valve | BM3 w/AIC2-V|Tune CaryTheLabelGuy | Full E85 | ATM FMIC | ER Chargepipe Inlet/Outlet | AFE Intake | BC Coilovers | PSS 255/40-275/35 Velos Designwerks S3 two piece 19x9/19x10 | Osram Xenarc | LED retro | AWRON digital AC gauge|
      05-17-2017, 01:20 AM   #29
Vg6o6
Drives: 320i
these look awesome
328i, f30, rims
