Coby Wheel
BMW 3-Series (E90 E92) Forum > BMW E90/E92/E93 3-series General Forums > General E90 Sedan / E91 Wagon / E92 Coupe / E93 Cabrio > 3 Series Convertible Seats
      04-29-2012, 05:28 PM   #1
plaidboyo
Drives: 3351 Convertable
I have recently bought a new 335I convertible which I am loving. Only issue is I'm 6'4" (which I think is 193cm's) and I am struggling with the seat adjustments.
The problem is my shoulders hit the head rest and I am unable to adjust the headrest height to allow my back and shoulders to fit into the seat and then my head to rest against the headrest.
When I test drove the car I thought this would be tolerable, however I would like to be able to raise the headrest 2 or 3 inches.
In the manual it points out that the convertible seat has no height adjustment for the headrest. However if you look at the "bracket" that attaches the headrest to the seat (along with the seatbelt) it appears to have the ability to slide up and down but the whole bracket is a solid plate of steel.
Can anyone help? I am hoping I can get BMW to solve the problem in the workshop. Has anyone had a similar problem and solved it...
      04-29-2012, 05:54 PM   #2
gatoman39
gatoman39's Avatar
Drives: 2011 E92 335 M-Sport
I'm confused. Do you have power seats or manual?
      04-29-2012, 07:49 PM   #3
M-Steep
23
Drives: 2009 E93 M Sport
Yeah, I'm a little confused as well; the headrests in the convertible *do* adjust up and down. Maybe you're saying they don't adjust enough?
      04-29-2012, 08:11 PM   #4
E90Company
E90Company's Avatar
194
Drives: Car
I don't understand.
      04-29-2012, 08:49 PM   #5
Dark_Knight_335
Came to the N55 Darkside
Dark_Knight_335's Avatar
Drives: 2011 335 E93 M-Sport
Mine work just fine here
Blew a fuse maybe?
      04-29-2012, 08:50 PM   #6
BAYsic
9
Drives: 335i
If you have power seats, you can adjust the headrest by pushing the backrest button "up."
Push the vertically placed button that controls forward/back tilt (the button immediately to the left of the memory controls) straight up (not forward or backward) and it will lift the headrest up. Push it straight down to bring the headrest back down.
      04-29-2012, 10:01 PM   #7
Dark_Knight_335
Yeah that gets a lot of my passengers- not sure what BMW was thinking with that one...
      05-01-2012, 07:06 AM   #8
Thunder Dump
That tickles
Thunder Dump's Avatar
Drives: '09 328i E93 SGM/CR
I'm 6'4" and had the same problem. As others have stated, you *can* move the headrest up and down with the power button on the side of the seat. However, what I had more of an issue with was the headrest moving in and out. Because the headrests are active (for collision mitigation purposes) they no longer tilt like they did on older cars, but they do *manually* go in and out (closer/further from the front of the car). There is a button on the inboard side of the headrest. Press and hold it and while doing so you can move the headrest in and out.
I've noticed that the headrest seems to move forward (it powers down as well) when you tip the seats forward to access the back seat so I find myself adjusting it quite a bit after moving the seats.
      05-01-2012, 09:16 AM   #9
smallseafishie
110
Drives: AW 07 e92 335i + AW 11 X5 35d
2007 E92 335i  [0.00]
I'm not a vert owner so I can't say I'm right...
But I believe that the reason the headrests don't go up and down is that the headrest serves as a roll over protection device. When the car "senses" that it's in a roll-over situation, the headrest pops up.
      05-01-2012, 11:17 AM   #10
understeer
Usual Suspect
understeer's Avatar
Drives: 2009 BMW M3
The headrests themselves do not serve as rollover protection. The pop up rollover protection is located behind the rear seat headrests.
335i, convertible, headrest, headrest adjustment, seat
