04-15-2011, 10:46 AM | #1 |
Supreme Allied Commander
3857
Rep 54,416
Drives: F80 M3
HP Autosport || Swift true coilover conversion for your KW V series
The basic front only kit consists of a custom upper spring perch, Swift springs, and Swift thrust sheets.
The complete kit will come with rear Swift springs, Swift thrust sheets, and a pair of rear height adjusters. For those who wish not have to mess with machine work on the front lower spring adjusters, we also have a kit with machined adjusters included. The bottom photo is he front kit mounted on KW struts, one with the stock upper mount, and the other with Vorshlag camber plate. ***Slight machine shop work is required for the front lower spring perch, which can easily be done at a local mahine shop. Alternatively, you can purchase new machined KW adjusters from us as well.*** A wide variety of spring rates are available to choose from or we can make a recommendation for you. Camber plates(Vorshlag) is optional but recommended if you are attending HPDE or track days. https://hpautosport.com/product/kw-s...-and-m-series/ Last edited by HP Autosport; 07-02-2023 at 01:16 PM.. |
02-13-2012, 05:20 PM | #2 |
ti fan
67
Rep 273
Drives: 14 12C | 17 X5 50i | 19 M2C
Garage List 2014 McLaren 12C Sp ... [0.00]
2017 BMW X5 xDrive50i [0.00] 2019 BMW M2 Competi ... [0.00] 2008 BMW 535xi Touring [10.00] 2008 BMW 135i [10.00] |
What exactly has to be done to machine the adjusters?
02-13-2012, 06:03 PM | #3 |
3857
Rep 54,416
Drives: F80 M3
02-15-2012, 01:41 PM | #4 |
ti fan
67
Rep 273
I actually have 2 new adjusters that I bought from KW. Would it be possible to send them in as cores for some discount?
02-15-2012, 01:58 PM | #5 |
3857
Rep 54,416
Drives: F80 M3
09-17-2012, 05:38 PM | #6 |
3857
Rep 54,416
Drives: F80 M3
Swift spring coilover conversion for KW V series
Best kit out there to upgrade your KW V series to a true coilover system with linear rate springs.
This kit fits the BMW 1M and M3 with V series as well. |
