11-18-2011, 09:30 PM | #24 |
Sak
Rep 26
Lotus, have another question.
I heard BMW doesn't recommend tire rotations, but I was always leaning that these are always good to do to extend a tires life. I see you also mention that you rotate your tires after you the winters/all seasons..so I'm assuming its good to do. Any further thoughts on why BMW doesn't reco this? |
11-19-2011, 10:52 PM | #26 |
Rep 8
Wheel Lock or 12-point Socket Bolt?
Thanks Lotus for the excellent instruction. So I just received the beautiful jack point tool and two wheel hangers, and I was ready to change the winter wheels. But I found this (the bolt closest to "B"). Is that just another kind of bolt? Do I have to buy a special tool to remove it?
11-20-2011, 12:07 AM | #27 |
Rep 8
Thanks Lotus, my respect to you has upped to a new level . There are indeed two of the same keys in that tool bag. I checked that tool bag a while ago and confirmed the hook and the tool you mentioned in another thread. But I didn't notice the keys as they were hidden in another pocket.
Thanks again. |
11-22-2011, 04:35 AM | #28 |
Rep 1
Question regarding jacking
Hi, Your write up is excellent - I have already sourced the Jack Pad tool and wheel hangers from Reverse Logic and was going to use a Trolley Jack under the Jack Pad tool but I see from the picture you have posted that you seem to have a round block (probably rubber!) between the jack saddle and the JAck Pad tool!
Is this addition really necessary - why are you using it? Your advice would be much appreciated. Regards, Phil |
12-05-2011, 08:33 AM | #29 |
Deckhand
Rep 389
I just received my USA mftr and shipped jack pad tool too and it is highly engineered and finished. Another commission cheque to Lotus must be on its way.
However, when I tried to order the nappa leather key cover fob from Amazon US I was declined as 'outside the ship zone' I have only seen lesser (non nappa) types on EU sites. |
12-05-2011, 05:30 PM | #30 |
Rider and driver
141
Rep 506
Lotus7, thanks for this thread.
I basically got two jack pads because of it. Might come in handy when putting chains on the tires up in the mountains here (rarely happens, but CalTrans sometimes wants chains on AWD anyway). Put them to use a couple of weekends ago after abusing the front tires in a remote part of Death Valley. One had a 2 inch gash on the sidewall, the other had a bubble on the sidewall. Getting two tires replaced meant the tire guys were going to lift the front of the car with floor jacks. "Hold it!" "I've got these things that go where you're supposed to lift the car". Quizzical looks, but things got done right. BTW, the run-flats are good for at least 40 miles of dirt roads (with 4 miles of snow) at 25-30MPH and 30 miles of paved at 45MPH.
2021 X3 MC
I work for Keyser Söze |
12-06-2011, 12:43 PM | #31 |
Deckhand
Rep 389
BTW, the run-flats are good for at least 40 miles of dirt roads (with 4 miles of snow) at 25-30MPH and 30 miles of paved at 45MPH.[/QUOTE]
Razel - at those speeds that's 2 hours drive to get out of the desert to a tire dealer? Did you sustain any damage to the wheels or undercarriage? |
12-06-2011, 06:46 PM | #32 | |
Rider and driver
141
Rep 506
2021 X3 MC
12-16-2011, 04:46 PM | #33 | |
Rep 3,855
Not sure if this is the best thread to post this in but I thought it might be useful:
F25 xDrive20d SE __ professional multimedia package | dynamic package | climate package | 309s | xline | xenons | electric seats | folding mirrors | business speakers |
12-17-2011, 06:59 AM | #34 |
Rep 29
Lotus, thanks again for your info on this subject and all the other members, not sure if anyone mentioned this but a little bit of anti-seize on the lugbolt threads and especially on the face of the hub & backside of wheel will help with future removal.
Little dab on spark plug threads is also a big help... Thanks again to all, haven't ordered my x3 m series yet, but LOVE ALL THE INFO I'M GETTING FROM THIS FORUM.... |
12-18-2011, 10:30 PM | #36 | |
18
Rep 274
12-22-2011, 02:40 AM | #37 |
Rep 15
Great guide.
Has anyone come across a bottle jack that has a similar cup that the jack pad will sit in. I really don't want to have to carry a trolley jack to replace a wheel when on the road. I understand I can use a suitable BMW scissor jack, but would rather go with a bottle jack. Cheers |
12-30-2011, 04:08 PM | #39 | |
Rep 42
I'm buying an aftermarket set of wheels (74mm centerbore) for my F25 and could use some advice as to the ring adapter I need. Thanks for your help. Last edited by renderfarmer; 12-31-2011 at 01:35 PM.. |
01-16-2012, 03:00 PM | #40 |
Rep 42
Hey Lotus. Thanks for the great guide! I just swapped out my wheels for some aftermarket ones using your guide after I acquired all of the recommended tools.
My rims came with 74mm>72.5mm hub centric rings. I've read that these are only to facilitate installation of the wheel on an undersized hub. Is this true or do they also serve some mechanical purpose once the car is rolling? If they really are just to ease installation, can I forgo them altogether in the future if I use the reverselogic lug bolt guides? Thanks again! |
01-16-2012, 03:50 PM | #41 |
Rep 42
I followed your instructions carefully regarding the gradual tightening sequence. I'll follow up and check the tension when I get home. I think that based on your reply I'll also splurge on a $35 set of Aluminum rings. The plastic ones are probably OK but they don't inspire confidence. Thanks again for all of your advice. So far it's proven sound.
02-13-2012, 03:21 PM | #42 |
22
Rep 87
repairs, tires, wheel and tire |
