Tirerack
The Tire Rack
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > Wheels and Tires Forum Sponsored by The Tire Rack > change tires on how many miles.
      02-13-2012, 10:07 PM   #1
F30_APSL
10
Drives: 2014 328i sedan sprt line
hi,
i have 19300 miles on my car. i still have stock tires. when i was driving in rain today, during a u-turn, i felt a little drift. and back end was coming out just a bit .. and i was doing only 25-35 mph not fast.
so question i want to ask is , is this the correct time to replace tires ? / what is the normal time/ miles expected from tire ? / when did you change tires ?
harsh
      02-13-2012, 10:18 PM   #2
Kolyan2k
Drives: 2006 S2000
cant you look at the thread ?
      02-13-2012, 10:25 PM   #3
ChuckBMW3
ChuckBMW3's Avatar
Drives: f30 335i
Originally Posted by harshmehta View Post
hi,
harsh
Normal. Changed my run-flats around 20k, as I was experiencing similar symptoms. RFTs are expensive and wear very quickly
f30 335i: Current
e92 335i: Sold 10/29/2015
e90 328i: Sold 12/7/2013
      02-13-2012, 10:27 PM   #4
Doctor///M
Doctor///M's Avatar
Drives: 2023 AUDI RS6
2023 Audi RS6 Avant  [0.00]
BMW M2 Competition   [10.00]
2009 BMW 335i  [0.00]
2015 M3  [9.52]
just bought the car? I'm doing 23k on my 09 stock RFT's and the tread is fine. If it's a 335, it takes a little time getting used to throttling all that powwerrrrr! maybe the tread can be low if it was driven hard. Typical life is 25k miles.
Llep6418.00
      02-13-2012, 11:47 PM   #5
JS82
JS82's Avatar
Drives: '08 E92 328i 6MT Jet Black
+1
Seriously, it can't be that hard to measure the tread on your tires.
      02-14-2012, 12:07 AM   #6
F30_APSL
10
Originally Posted by JS82 View Post
+1
is there a wasier way to find it out ? other than the measure thing itself ? atleaset for now till i get it.
Harsh
      02-14-2012, 12:09 AM   #7
driverman
Drives: 2008 328i 6MT - SOLD
19K miles on rear RFT's sounds like they are probably worn out.
I suggest you check the depth of the tread on the rears. 2/32nds (1/16") is supposed to be the minimum. I replace mine before then.
      02-14-2012, 12:12 AM   #8
mike3000fl
138
Drives: 06 330i
Harsh
not sure if you are trying to get one of us to come over and measure it for you or what.
anyway, here
http://www.tirerack.com/tires/tirete....jsp?techid=51
now get off the computer, find some coins, report back.
      02-14-2012, 12:47 AM   #9
F30_APSL
10
anyway, here
haha, no i do not know how to measure it.
anyway i have a pic with penny in the wheel and again i don know what to interpret from that. if you guys can help...
      02-14-2012, 01:00 AM   #10
VTECaddict
Where'd my VTEC go?
VTECaddict's Avatar
Drives: 06 330i 6MT
25-35mph is pretty fast for a u-turn...
AW/Terra | ZSP | ZPP | ZCW | iDrive | CA
Mods: BC BR coilovers | Blacklines | M-tech rear | dual exhaust | M3 steering wheel | BMW SSK | ZHP shift knob | High-kick CF spoiler | NBT Retrofit
M3 front control arms | M3 rear guide rods | Manzo rear toe and camber links | Monroe rear shock mounts | Varrstoen ES1 19x9.5+20 Front, 19x11+25 rear
      02-14-2012, 01:07 AM   #11
mike3000fl
138
Drives: 06 330i
click the link i put in that post. don't be scared, it won't bite.
it explains everything you will want to know about tread.
teasers....
find that change jar... read more here....
also, look for the part about "wear bars" they are built into the tire to help you determine if the tread is worn and look like this....
see the horizontal line running left to right? thats a wear bar, when it is flush with the tread you need tires.
      02-14-2012, 09:08 AM   #12
axis
Drives: 2019 430i Gran Coupe
That's exactly what I was going to say lol. A u-turn over 3-5 MPH you are gonna lose traction! Plus on a wet road, even with brand new tires it's really easy to step the back end out.
      02-14-2012, 09:40 AM   #13
Bavarian13
Drives: E90 335, E36 M3
Seriously... I'm guessing the OP totally overestimated how fast he took it.
By the way, is this your first RWD car? If so, when it's wet you do have to drive a little bit slower on a turn like that.
      02-14-2012, 11:03 AM   #14
CWS335
CWS335's Avatar
Drives: 2022 G22 (Ordered)
Based on your pic, you still have sufficient tread.
      02-14-2012, 11:09 AM   #15
Myriad
Drives: E92 335i 6MT
my rears went for 20k on the stock tires. Fronts had tons of tread but I swapped all four because I was sick of the runflats.
ZPP / ZSP / Navi
      02-14-2012, 11:39 AM   #16
achien
AC
95
Drives: E90 Post Members Crazy
your tires are still good...
Your Supreme Leader
      02-14-2012, 11:50 AM   #17
wrickem
Big Beaver Smile
wrickem's Avatar
2101
Drives: What he wants to
When your car stops giving you a safe and confidant feeling when driving in the rain.
I'd rather buy new tires earlier rather than later. I don't care that I have "some" tread left, I don't feel the need to squeeze every last drop out of a tire if my car is not handling well. I don't mind being wasteful when it comes to safety.
______________________________________________
Current- '21 430 , '19 911, 07 M6 ,'17 Jeep Wrangler, "23 Bronco OBXluxsquatch
      02-14-2012, 08:54 PM   #18
username604
username604's Avatar
Drives: bmw
2008 BMW 335i  [10.00]
Learn to drift: Only change tires when threads are visible.
      02-14-2012, 08:59 PM   #19
mike3000fl
138
Drives: 06 330i
my personal best...
      02-15-2012, 12:31 AM   #20
chromisdesigns
Drives: 2008 BMW 335i sedan
To the OP -- make sure you have sufficient tread all the way across the tires. Our cars normally wear out tires on the edges first, it's possible for a tire to be all the way into the cords on one edge and not be down to the wear bars on the other.
Get down there and LOOK AT THE TREAD on all your tires.
      02-15-2012, 12:31 AM   #21
jvsxn
jvsxn's Avatar
Drives: e-ninety
^ Now that's scary.. Your "Worst" sounds more appropriate!
I've done mountain runs on (F:Neova ~6/32 R: Potenzas ~3/32; Yes, rears had less tread ) and even though it gripped, I will never consider doing stuff like that with my tires looking like that.
my personal best...
Negative camber ftw
Hiatus
      02-15-2012, 01:53 PM   #22
F30_APSL
10
thanks.
i just looked at front left. i dont think it says anything. maybe i should check all ... specially rear tires.
Harsh
tires
