BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Cosmetic and Lighting Modifications (exterior & interior) > Heated Steering Wheel Function Retrofit discussion and sharing
Extreme Powerhouse
      01-30-2017, 10:26 AM   #45
larry_bml
larry_bml's Avatar
Romania
194
Drives: BMW F30 Sport Line 320ded
Yes, here is a picture with it, but I think was remanufatured and the man hwo did it, didn't know about heating.
      01-30-2017, 10:36 AM   #46
doughboy
doughboy's Avatar
1546
Drives: 2018 M2 Comp 6MT
Do you have a picture with the trim removed to show the wires and connector?
      01-30-2017, 10:40 AM   #47
larry_bml
larry_bml's Avatar
Romania
194
I don't have right now. But there is no connector, just two wires , not so thin like the 2 for sensors, but thick wires. I will take a photo with trim removed.
      01-31-2017, 05:57 PM   #48
sds0918
sds0918's Avatar
Drives: M235 2015
I really want to do this retrofit but I really feel like the guides are lacking in clarity, from the eyes of a noob.
      02-01-2017, 04:03 PM   #49
obert
obert's Avatar
Drives: 2013 328i
I am hoping to put together the parts needed to do this soon. Thanks for all the info so far.
What is this vibration part I keep reading about ? Do all heated wheels have this or need this to work ?
How do you know what column number you have ?
      02-02-2017, 12:52 AM   #50
larry_bml
larry_bml's Avatar
Romania
194
So, for the moment I'm using an sport steering wheel heated, I can say it's a nice future, but heating time is a little bit long, and is not heating entire surface. I hope that the M steering wheel will be better, but for the moment it is at a leather workshop to replace leather with heated and 4 wire conector one.
      02-02-2017, 10:01 AM   #51
LittleBlackHawk
41
Drives: F30 --> E89
Here is a picture of the steering wheel with trim removed for your reference.
      02-02-2017, 11:06 AM   #52
roxxor
roxxor's Avatar
1148
Drives: 2024 iX50
Not sure if anyone had seen this as it didn't get any responses, but I did a write-up DIY on retrofitting the Heated Steering Wheel in the F30 about a year ago. Just thought I'd link it here in case it would help anyone out.
http://f30.bimmerpost.com/forums/sho....php?t=1231186
      02-02-2017, 02:08 PM   #53
larry_bml
larry_bml's Avatar
Romania
194
roxxor Verry nice write up. One question, why you have to code CIC/NBT? Is there anything that you can set from CIC/NBT?
      02-02-2017, 02:16 PM   #54
roxxor
roxxor's Avatar
1148
Drives: 2024 iX50
Probably not, that write-up was before my understanding that the FA is how the car determines the owners manual versus coding in the headunit. The Headunit does not have any actual functionality with the Steering Wheel Heating.
      02-02-2017, 02:18 PM   #55
larry_bml
larry_bml's Avatar
Romania
194
OK, thank you for your answer.
      04-09-2017, 05:58 AM   #56
gotomoto
gotomoto's Avatar
41
Drives: F30 3.20ied
Hey David.
Am I missing the cables for + and - ?
Originally Posted by david51 View Post
hello
Before buying the next room (Switch unit steering column)
just use the unused connectors of the airbag:
+ slot 1 (red/Black)
- Slot 3 (brown)
must displacement connectors power and ground to the heated steering wheel
      04-09-2017, 08:08 PM   #57
david51
david51's Avatar
France
538
Drives: bmw M3 F80
Originally Posted by gotomoto View Post
Hey David.
Hello
See next link for the + and the mass
http://f30.bimmerpost.com/forums/sho....php?t=1146335
      04-10-2017, 04:49 AM   #58
gotomoto
gotomoto's Avatar
41
Drives: F30 3.20ied
Hello
i already checked. can i connect + - to anywhere? like lighter socket for example? (I already have a power cable around that area from lighter socket for trunk switch i retrofitted a couple of months ago)
      04-10-2017, 06:14 PM   #59
david51
david51's Avatar
France
538
Drives: bmw M3 F80
Yes you can take any power +
      04-19-2017, 09:18 AM   #60
gotomoto
gotomoto's Avatar
41
Drives: F30 3.20ied
I got this button: 61319201736 but it is used and doesn't have the cable. Can you give me the pin out for this cable so I can make my own cable for it please?
      04-20-2017, 11:55 PM   #61
david51
david51's Avatar
France
538
Drives: bmw M3 F80
8377236
      04-21-2017, 08:04 AM   #62
gotomoto
gotomoto's Avatar
41
Drives: F30 3.20ied
8377236
Thanks a lot!
      06-02-2017, 03:34 AM   #63
gotomoto
gotomoto's Avatar
41
Drives: F30 3.20ied
I did everything as instructed and got + - from the lighter socket and connected it thru airbag connectors. The heater button light doesn't light up and on ISTA it says the heater button is not connected. I got the button brand new and tried with another button too. anybody has an idea?
      06-02-2017, 04:17 AM   #64
doughboy
doughboy's Avatar
1546
On my car (F06 M6) I had to code the SZL module (that the button connects to) to enable heating function first.
Not sure if F30 has SZL though.
      08-07-2017, 03:51 PM   #65
Kannu
Drives: F20 120d M sport
Is it possible to install a wheel with heating to a car without the option? I mean do the other functions still work normally? I´m not interested in the heating just want to update the steering wheel look...
      08-07-2017, 03:57 PM   #66
larry_bml
larry_bml's Avatar
Romania
194
It will work.
f30, heated, heating, steering, wheel
