09-18-2015, 06:51 AM | #1 |
125
Rep 3,515
BMW Attacked by Wild Turkeys! - 335i Paint Correction - 22ple VX3 Paint Coating
This vehicle belongs to a repeat customer of ours. You might remember this vehicle from a previous thread when we did a major overhaul on the paint for this owner shortly after he purchased the car (click here to see the write up from last year). If you didn't see that post, here is a little summary...
... well this year it returns to us due to an unlikely event that left scratches all along the sides of the vehicle (again). The car was attacked by wild turkeys. Yep. Turkeys. They apparently saw their crystal clear reflection and decided to try to show that 'other turkey' who was boss. Long story short, the customer wanted us to correct the sides of the vehicle to remove as much of the damage as we could while still being conservative. We also polished the rest of the vehicle to remove some water spotting, dullness, and swirls that had been introduced over the last year. I've been told the vehicle will now be parked in the garage at all times, so I hope we don't see this one in for correction for many years. It turned out great when it was all said and done... I really like this color! Process Tires: Tuf Shine Tire Cleaner & Tire Brush Wheels: Sonax Full Effect Wheel Cleaner & Various Brushes Pre-Wash: CG Citrus Wash via Foam Lance then pressure rinse Wash: CG Citrus Wash Chemical Decontamination: CarPro IronX & Stoner Tarminator Paint Decontamination: Medium Grade Speedy Prep Towel with Nanoskin Glide as Lubrication Tape trim and other areas of concern Paint Thickness Readings Taken Compound/Cutting (sides only): Griot's Fast Cutting Creme on Fast Cutting MF Pads via Griot's G21, Rupes LHR21ES and Rupes LHR75e Polishing (entire car): Griot's Correction Creme & Correcting Pad via Griot's G21, Rupes LHR21ES and Rupes LHR75e Coating Prep/Polishing Oil Removal: 50% IPA Ceramic Paint Coating: 22ple VX3 Signature Glass Coating Glass: Meguiar's D120 Tire Dressing: CarPro PERL Upon in initial inspection, it was clear that the paint needed some correction to enhance its appearance. There were some deeper defects that would also need to be addressed. We began with an extensive exterior cleaning and decontamination process. The vehicle was then brought inside for further inspection. The paint had a fair amount of water staining, swirls, and scratches. We were not after 100% defect removal as the paint was quite thin, and the majority of the vehicle had been repainted so caution is always used. I was able to make a considerable improvement to the color and depth of the paint. Hood before Hood after Checking my work in the sun Trunk before Trunk after 50/50 on door after compounding quarter panel before quarter panel after compounding bumper before bumper after compounding The paint was then coated with a thick layer of 22ple VX3 paint coating This was allowed to flash, and then was wiped away to a mirror finish The car looked great afterwards. The paint was extremely glossy! The majority of defects were removed leaving clear reflections and vibrant metallic flake. Hopefully this car will remain in this amazing shape for a couple more years before we get to get our pads dirty on it again. Links to all products used are provided at the beginning of this article. As always, thanks for reading, and let me know if you have any questions! Zach McGovern Detailed Image Ask-A-Pro Blog Author www.AttentiontoDetailingPeoria.com |
09-18-2015, 12:13 PM | #3 |
Rep 12,570
Drives: Z4 M, X5, GX460
Garage List F15 X5 xDrive35i [8.75]
E86 Z4 M [10.00] F10 550i (Retired) [9.17] F25 X3 xDrive35i (R ... [9.43] E82 135is (Retired) [9.50] E85 Z4 M (Retired) [9.41] E90 328i xDrive (Re ... [9.25] E86 Z4 3.0si (Retired) [9.26] |
Are you located in IL of NY?
09-18-2015, 01:16 PM | #4 |
125
Rep 3,515
I personally am located in central Illinois.
My name is Zach McGovern, I am a professional detailer, and I work for Detailed Image as an author for their Ask-A-Pro Blog and help with supporting the many forums that they sponsor (such as this one). Detailed Image is located in New York. Hope that clears it up Let me know if you have any other questions. Zach McGovern Detailed Image Ask-A-Pro Blog Author www.AttentiontoDetailingPeoria.com |
09-21-2015, 10:57 AM | #6 | |
125
Rep 3,515
The 22ple VX3 took it up a notch though as it adds further depth to the paint and gives it that glassy look. Zach McGovern Detailed Image Ask-A-Pro Blog Author www.AttentiontoDetailingPeoria.com |
