Studio RSR
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Powertrain and Drivetrain Discussions > N55 Turbo Engine Tuning and Exhaust Modifications - 335i Tuning > Howling noise coming from engine on idle
      03-08-2020, 10:05 AM   #1
megaocher
Drives: 2018 340i
Recently, my car has been making a strange howling/whining noise from the rear driver's side of the engine, and I'm getting 2BDE and 2BF0 codes. It almost sounds like an intake leak, so I'm questioning if it might be that? I've had a MAP sensor code (28A0) in the past.
https://vimeo.com/396280104
      03-08-2020, 01:03 PM   #2
TheGoodTheBadTheUgly
Drives: 2011 E90 335i xDrive
My broken blower fan sounds just like that. Are you sure it was off?
TOTALED | 2011 E90 335i xDrive - BMS Cold Air Intake - ETS Charge Pipe - ETS 7" FMIC - MHD Stage 2+ - GFB DV+ - PE Mod - VRSF Catless Downpipe - xDelete - xHP Stage 3
2015 E84 X1 35i M-Sport
      03-08-2020, 06:19 PM   #3
megaocher
Drives: 2018 340i
Just tried that, no luck. The car started giving a 2775- air mass too low code just now, though. Hopefully it's not something too major
      03-08-2020, 09:15 PM   #4
Hmmm this is weird, I don't see at idle how such a sound could be produced even by a leaking intake system.
If you are a bit handy, you can make sure that the accordion section of the intake system is still well clamped, but other than that I can't see what it could be base on the info I have.
Maybe PCV system?
      03-08-2020, 09:39 PM   #5
ky0u
ky0u's Avatar
Drives: e92 335i, f22 m235i, e30 325is
2015 BMW M235i  [0.00]
1988 BMW 325IS  [0.00]
2007 BMW 335i  [0.00]
Valve cover okay?
      03-09-2020, 08:53 AM   #6
megaocher
Drives: 2018 340i
Yeah, I checked the inlet pipe and the airbox clamps and they all seem to be tight. The noise seems to be coming from the valve cover, underneath the second engine cover in the back. I'll remove it later to check.
Also, there's a faint smell of gas, leading me to believe I might have an injector leak back there? Could that be the source of my HPFP codes? The noise is definitely something on or in the rear of the valve cover, though it didn't stop when I took off the oil cap to see if it was from the PCV.
Last edited by megaocher; 03-09-2020 at 08:54 AM.. Reason: Forgot to add some stuff
      03-09-2020, 10:08 AM   #7
megaocher
Drives: 2018 340i
Okay, I checked the PCV valve and it's blowing out air, so that's not the issue. What else could be causing this? I've tried searching everywhere to no avail.
      03-10-2020, 09:20 AM   #8
megaocher
Drives: 2018 340i
Is it possible for the valve cover to make a noise that doesn't go away when I remove the oil cap? I feel like that's what's causing the problem.
      03-10-2020, 10:03 AM   #9
Welcome to NBA Jam
Is it the shoes!?
Welcome to NBA Jam's Avatar
3884
Drives: (Sold) 2011 E92 335i ZMP 6MT
It's possible for the CCV membrane inside the valve cover to be ruptured and cause a howling noise. There's a repair kit out there for it, but it requires a dremel and jb weld or glue.
http://vanos-bmw.com/product/membran...er-11127570292
      03-13-2020, 09:53 AM   #10
megaocher
Drives: 2018 340i
I tested the pcv valve, it's fine. There's no suction from the barb and the noise doesn't go away when I open the oil cap, which has plenty of suction.
      03-19-2020, 05:11 AM   #11
juld0zer
Australia
480
Drives: Prev 135i 7DCT, Now 130i 6sp
Rear main seal?
      03-19-2020, 08:53 AM   #12
megaocher
Drives: 2018 340i
No, there's no PCV issue to cause that.
Actually, I figured it out. Once I took off the rear engine cover, the noise stopped, so it has to be coming from there. I'm not too worried, as it doesn't seem to affect things. I was able to fix all the codes by cleaning the MAF and the chargepipe MAP.
      03-21-2020, 09:30 AM   #13
Jeef
Drives: AW E92 335i
oil cap has plenty of suction? that's not good
      03-23-2020, 11:11 AM   #14
megaocher
Drives: 2018 340i
Not a lot, but a normal amount I think. I didn't get any sucking from the barb, so I think what I'm seeing is normal? I didn't think a broken PCV valve meant a lot of suction.
EDIT: Just went outside and checked again, the noise doesn't change when I take off the oil cap. So I assume my pressure is normal/the noise is unrelated? I'm hoping my PCV valve isn't messed up despite my testing
      12-31-2023, 07:19 PM   #15
shitbox
Drives: 2011 e92 335i x drive (PWG N55
I have this same noise after replacing valve cover with no pcv issues or anything. Did it really just end up being the rear engine cover??
      02-11-2024, 12:39 AM   #16
megaocher
Drives: 2018 340i
Not really. I think it's just a normal noise these cars make, as it came and went somewhat intermittently throughout my ownership and didn't change when i replaced the valve cover 6 months after the original post. I will say that if you hear the dolphin/chipmunk noises, especially under braking, that's a better sign of PCV failure in my experience. A shop actually damaged my (replaced) valve cover during an incorrectly-performed walnut blasting and I got those noises. Fortunately FCP covered it. I sold the car last April after putting 30k miles on it. Feel free to ask me any other questions you may have.
      02-29-2024, 04:51 PM   #17
jkline398
Drives: 2010 e90 335i
Are you happy it's gone? I'm less than a year into my first ever bmw and I would not be surprised whatever your answer is. I love this car. I hate how it was put together lol
      03-07-2024, 03:54 PM   #18
megaocher
Drives: 2018 340i
Honestly, I miss it a lot sometimes but I’m glad I let it go. The rust on my particular car was problematic and the synchros on a couple gears started to go. Otherwise the engine was totally healthy, a shop did damage my valve cover during an incorrectly done walnut blast so I had to replace it again. It still had the original water pump and thermostat when I sold it at 95k somehow. After I did some suspension mods (for $150 tension strut bushings are a must do) the car was a blast in a way that my 340i doesn’t really replicate. I think if I did it again, I would choose a slightly different spec, though. What don’t you like about how your car was put together? Is it xDrive?
