BMW M3 Forum (E90 E92)
      04-30-2012, 01:23 PM   #45
austonwerner4
Drives: B5S4
Why not print at the dealer?
Bx Tpr122.50
      07-11-2014, 04:48 PM   #46
HapaM3
22
Drives: E92 M3
Question: Is the rear lower control arm eccentric fastener mainly to adjust the alignment of the wheel, or shall I say, wheel position. It is NOT specifically there to give you camber adjustability although playing with it does affect camber? Has anyone rotated it completely to see what the affects are with alignment settings always correcting toe before the measurement of course?
The reason why I am asking is because my right rear wheel is forward about 4-5mm compared to the left. I really hope I can get it back to where it should be just by playing with these two eccentric fasteners.
      07-29-2017, 12:40 PM   #47
Razif
Malaysia
29
Drives: Bmw e92 m3
I dont understand half of what that paper says.
When I go to the alignment shop that uses lazer alignment, this is the numbers that pop out.
Front left camber, Front right camber. degrees
rear left canber , rear right camber.
front left toe , front right toe, then the total of the toe added (cause one side can be negative) Its all in Millimeters. Not sure its toe or something else, but its in millimeter.
rear left toe, rear right toe, then the total of both added.
Can someone help me to read what that paper on the first page says about the stock number on all of these? (total 8 numbers)
      01-02-2018, 11:13 AM   #48
mosleekeh5524
Drives: Full new
I want say Nice, where did u do it? and cry on
m3post
