2010 2011 BMW 5 Series Forum F10 2016 535 wanders on highway - still a problem |
02-19-2024, 05:16 PM | #1 |
36
Rep 73
So I bought a new to me 2016 535i RWD non m sport with 90k miles on it. It needs constant steering input at highway speed, feels like it wants to wander back and forth, and sometimes it feels like it catches a groove in the pavement and wants to go that direction hard. Sort of feels like some sort of play in the steering wheel. The car feels more planted in a turn than going straight. Local Indy says the control arms look good but im not totally confident in the tech. I took it and had it aligned today, still same behavior. Any ideas? Could the control arms be just starting to go bad but not totally shot so the tech says they’re fine?
2016 BMW 535i, MHD stage 2+, XHP stage 3, VRSF charge pipe, VRSF down pipe, VRSF intercooler, ECS turbo inlet pipe
02-19-2024, 05:33 PM | #2 |
Rep 5,365
How are the tires? All the same tread pattern?
ChiltiCoatl891769.00 |
02-19-2024, 05:41 PM | #3 |
36
Rep 73
All 4 seem to be about the same, all about 5/32” tread. 245/40/19 Michelin pilot sport 4 all seasons. Manufactured end of 2021 but not all the exact same date code. (5121,5121,5021,1022) Last edited by smokinu454; 02-19-2024 at 05:46 PM.. |
02-19-2024, 05:47 PM | #4 |
79
Rep 264
I had 2 different full sets of Michelin Pilot Sport tires. Excellent tire but back wore out well before the front both times. When was the last time a road force tire balance was done?
02-19-2024, 06:19 PM | #5 |
36
Rep 73
Ive had good luck with them in the past as well. Im not honestly sure. I bought the car about two weeks ago. I dont feel any kind of vibration like you normally do when a tire is out of balance.
02-19-2024, 06:41 PM | #6 |
186
Rep 127
Check item #5 where is connected to item #1 (front axle support) there is no leaking or rubber inside sign of deterioration on both side.
02-19-2024, 07:06 PM | #7 | |
36
Rep 73
It’s very hard to tell because the forward arms are so far recessed at that point but I don’t think I see any damage or any signs of leakage. I did notice on the rear control arms, where they meet the subframe, when the wheels are turned all the way to the limit, it seems to shove the arm all the way to one side sort of compressing the bushing down and making the bolt closer to one side of the eye of the control arm if that makes any sense. Are the rear bushings supposed to have that much give? When I jack the car up and try to shove the wheel around I can’t find any play but I’m not a huge guy 😂 |
02-19-2024, 07:45 PM | #8 |
186
Rep 127
You should jack up the front safely and inspect those tension struts closely. Friend of mine was complaining about similar symptoms up front and after inspection find out one the tension struts was leaking. Replaced both and issue is gone.
ChiltiCoatl891769.00 StradaRedlands4940.50 |
02-19-2024, 07:57 PM | #9 |
36
Rep 73
Whats the typical lifespan of these arms/struts?
02-19-2024, 08:13 PM | #11 |
186
Rep 127
I say depends on driving habits and road conditions. In the scenario explain above was 60K mile. Don't change anything. Just get underneath do visual inspect and secondly with helper turning steering wheel side to side you can find out a lot.
02-19-2024, 08:21 PM | #12 | |
36
Rep 73
I will certainly give this a shot and see what I can find! Just need to enlist the wife as a helper to turn the wheel lol. |
02-19-2024, 08:57 PM | #13 | |
186
Rep 127
Or ask your neighbor. Give him a beer and proceed with inspection. Last edited by Conserve; 02-19-2024 at 08:58 PM.. Reason: . |
02-20-2024, 11:46 AM | #14 |
36
Rep 73
Here is what they look like. I do see a few cracks in the drivers side. Nothing I would consider a lot but they are there. Is this much play excessive or normal?
https://youtube.com/shorts/uuzFxj1mEqI?si=6Y7moVl3mjhXwKjQ https://youtube.com/shorts/DhT4qVTZt2U?si=_XZbvhaMM8pzsVaH |
ChiltiCoatl891769.00 Conserve186.00 |
02-20-2024, 12:15 PM | #15 |
Rep 435
Yeah, Worn Suspension parts is what I also suspect, I recently went over some rough stuff on my car and I am going to inspect the suspension pretty soon due to some rough handling (Mexican Potholes are very unfriendly) and a few ones here in Nevada caught me too. Can Definately affect your handling, all you need is one bad bump or pothole and can affect the ride quality. Especially after an alignment. I would replace the tires when they are ready to go, (5/32 is close to replace) and once those are replaced, see if there is a difference, and if not, Definately consider preparing for replacement suspension parts.
Conserve186.00 |
02-20-2024, 03:57 PM | #16 |
36
Rep 73
in addition to the videos, I forgot to post these pictures. The only tear I could see is this on the drivers side. Does it look like it is bad enough to cause poor handling?
02-20-2024, 05:13 PM | #17 |
24
Rep 38
That is more than enough to cause the symptom you describe. That one is shot, and way before it gets this kind of cracks the handling is allready compromised.
Also check your diff bushings. Many start looking at the front of the car when it handles badly, but the front wheels are alligned to the back so if there is a problem in the rear that car won't track straight. My rear diff bushing is kinda shot, made the car wander a bit. Placed the Bimmerhaus upgrade in it for now until I replace with the new part and since then the handling is back to normal. |
Conserve186.00 StradaRedlands4940.50 |
02-20-2024, 06:16 PM | #18 | |
36
Rep 73
I will take a look at this as well! |
02-21-2024, 05:32 PM | #19 |
24
Rep 38
Replace them with the F01 7-series arms, then you get the oil filled bushings. Makes the handling + comfort better.
02-22-2024, 06:22 AM | #21 |
36
Rep 73
02-24-2024, 04:45 PM | #22 |
252
Rep 332
Drives: F10 535i xDrive, F25 xDrive35i
Mine would wander until I did an alignment.
