03-23-2024, 04:11 PM | #1 |
Rep 556
Bilstein B12
Anyone running this (Bilstein B8's + Eibach Pro Kit)? Couldn't seem to find much on this particular combo.
Non-EDC E90. Considering a suspension refresh and wondering how this will fair on Chicago streets. Currently stock and it's terrible on slow speed bumps, and pretty harsh on high speed. Pretty sure worn out at 81k. |
03-24-2024, 01:21 PM | #2 |
Rep 933
Drives: E90 M3
I’ve had the B8s paired with a different lowering spring for about 40k miles. You feel every road imperfection in a muted manner. Nothing is super jarring unless it’s a decent pot hole. If Chicago streets are anything like Buffalo streets I’d say it’s a losing battle regardless.
Performance wise they’re very racey and I’ve been satisfied with my daily use. |
a5m614.00 |
03-25-2024, 07:08 PM | #3 |
Rep 556
Thanks for the reply.
What springs are you running? This isn't the feedback I was hoping for lol but I appreciate the honesty. I feel it'd still be an improvement over what's on there currently. I reached out to Bilstein regarding the difference between B6 vs B8. There's a .6" travel advantage to the B6. Perhaps that's why I've found more favorable reviews for those, or maybe because more cars are EDC and that's the only compatible option. There's also the shaved front top mounts, which I'm not sure apply to inverted struts. Racking my brain trying to understand how that whole setup works/benefits. |
03-26-2024, 05:58 AM | #4 |
Rep 933
Drives: E90 M3
No prob, I have B&G lowering springs I bought from EAS when I got the car in 2018. I don’t think they’re widely used or available anymore.
You do get a lot of road feel through the steering wheel but it’s still a compliment ride, just firm. Bilstein says they’re 20% stiffer than B6 with less travel so it does have its limits with bad roads, bumps, and potholes. It was definitely an improvement from my 130k suspension I replaced - I did have EDC but didn’t feel like waiting on the B6 back order at the time, and I also didn’t really get the bump stop thing either so I just went for the strut designed for lowering springs with the built in bump stops to keep it easy. |
a5m614.00 |
03-26-2024, 09:37 AM | #5 | |
Rep 5,548
Shaved top mounts and e36 M3 bump stops are needed when lowering springs are used on stock front struts. These changes increase the travel by more than 8 mm. The B8’s are designed to work with Eibach lowering springs so you do not need to use shaved mounts and e36 M3 bump stops (can’t use these anyway because of the inverted strut design). |
a5m614.00 |
03-26-2024, 05:20 PM | #6 | ||
Rep 556
Did you ask them about being 20% stiffer? Been talking with them and their claim is they're essentially the same aside from the physical dimensions. Even the bump stops are the same according to them but can't be if the compressed height is identical. Yes I think I may have to go the B8 route due to availability. Plus like you said it's a much simpler plug and play setup. Perhaps with the softer Eibach springs it'll be quite nice. Not sure on the B&G rates and drop. Quote:
I want to go with the B6 for the added travel, since apparently these cars don't have much to begin with. But my understanding on the topic is changing day by day so I may just come to realize there isn't much benefit in going with the B6. Let's see what tomorrow brings |
03-26-2024, 10:43 PM | #7 |
Rep 5,548
a5m
So you’re looking to refresh your stock non-edc dampers with either B6 dampers or B8 dampers with lowering springs? B4 is another option if you just want to replace oem dampers. It seems like every B6 and B8 review I’ve read has said the B6/B! BimmerWorld offers the B8 paired with H&R lowering springs. Have you considered this option? I have no idea how this compares with the B8 with Eibach springs. I believe it said the H&R combo lowered the F by 1.0” and the R by 0.6”. Considering any other options? |
03-27-2024, 12:00 AM | #8 |
Rep 556
Yes correct, refresh stock non-EDC dampers. Don't want to go the coil over route so that leaves me with only Bilstein since nobody else makes struts for these.
B4 are on the bottom of the list, if at all. Figured I'd 'upgrade' while I'm at it, but more importantly a more durable shock will be preferable with lowering springs. I have seen the B8+H&R combo at BW. Issue is the H&R springs lower too much. The Eibach's have the least drop (aside from Dinan and OEM ZCP). Combined with their soft, close to stock rates, they'll probably give the best chance at a comfortable setup. That's why I'm leaning towards the B6 for their increased travel combined with the soft, mild drop Eibach springs. Should give me what I'm looking for. Would love to hear from those who are running this exact setup. |
04-09-2024, 10:10 PM | #9 |
Rep 556
Anyone else out there running B6's with lowering springs? Reading conflicting reports. It seems with Eibach springs the ride is a bit on the firm and harsh side. But those running Swift Springs say it's amazing and comfortable? Swifts are lower and higher rate, so confused how that works.
On the other hand I've read praise of the B12 Kit (B8 + Eibach) but not so great reviews when B8 paired with Swift Springs, which kinda makes sense. Getting close to deciding on a suspension setup and want to save a few bucks if I can (Ohlins). So any more feedback on B6 or B8 with various lowering springs would be appreciated. Haven't come across B8 and ZCP Springs. Anyone running that combo? |
04-19-2024, 01:00 PM | #10 |
96
Rep 243
a5m - a lot of what I read is also subjective as far as comfort goes.
My understanding is the B6 and B8 are similar in performance, but B6 is designed for stock ride height and B8 is designed for cars with lowering springs. Both of those being more "sporty" than the B4s which are an OE replacement. Again, this is what I have heard on the Bilstein line as a whole. It could be different on this platform.
-Thumbie
2011 Jerez E90 M3 6-speed Competition Package |
a5m614.00 |
04-19-2024, 05:37 PM | #11 |
Rep 586
I run b12 prokit on E92.. but I did not come from stock suspension (more like from a worn kw). paired with volshlag camber/caster plate so there is not a lot of rubber damper in the system. generally speaking it is sporty but also prong to pick up noise and harshness.
it should get better if you pair it with stock front strut top mount. it's an upgrade to replace the broken OE suspension set for daily and casual track days if you want to push hard on track, B12 prokit is def on the soft side. you will feel the "i should have gone to some track oriented suspension instead of this." |
a5m614.00 |
04-20-2024, 01:09 PM | #12 |
Rep 556
Thanks for the replies guys. Yes I'm set on running stock top hats to retain comfort as opposed to camber plates.
As far as B6 vs B8 I'm leaning towards B6 for added travel and more OE like replacement. Just unsure of their durability as I've read their quality has gone downhill as of late. Hoping someone who's run the above setups can chime in. Leaning towards Ohlins or KW right now. |
04-20-2024, 04:59 PM | #13 | |
Rep 5,548
a5m614.00 |
04-21-2024, 01:27 PM | #15 |
Rep 556
True there is that. I may just chicken out and go with new strut replacements only with the Bilsteins. I'm sure overall it'll still be better with my stock setup. Paired with Eibachs it should be a good enough choice.
b12, bilstein, e90, eibach |
