03-25-2024, 01:41 PM | #1 |
206
Rep 179
Drives: BMW 535i F10
Headlights not working
Hey, i had my car (2012 model) parked for 2 weeks in winter and apparently a moisture went into both headlights. On the right one a low beam stopped working but DRL still works, on the left one its vice versa - DRL stopped working but low beam works. I took both headlights off and dried them, then swapped TMS modules thinking they were faulty but it didn’t change anything. Checked a DRL modules and they also look fine. Any idea what could cause this problem? Does these cars have a fuse for headlights that might be blown?
03-25-2024, 07:56 PM | #2 |
51
Rep 229
What type of headlight do you have? Adaptive Xenon?
2011 535i xDrive Black/Black, Michelin PS AS 4
2014 435i RWD Convertible Service Manual: www.newtis.info Part: http://www.realoem.com |
03-26-2024, 12:25 AM | #3 |
206
Rep 179
03-26-2024, 12:53 PM | #5 |
206
Rep 179
Checked with scanner and is says that there is a short circuit with footwell module, will check the FRM module tomorrow to see if it really is the issue. Have your both headlights stopped working or is it single?
03-26-2024, 09:25 PM | #7 |
51
Rep 229
To replace TMS, you need to recode or reinitialize.
