The Tire Rack
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Powertrain and Drivetrain Discussions > N55 Turbo Engine Tuning and Exhaust Modifications - 335i Tuning > N55 Drag Times
      04-18-2019, 01:14 PM   #463
Turbod
Turbod's Avatar
Drives: 2014 E84 X1 35i M Sport
Originally Posted by xxMike61 View Post
Oops yeah I meant to add that later on I did fully disable it for my last 2-3 runs. It seemed to hook pretty well but my 60' was still 2.2~ and I ran the 12.9s. Should I launch at a higher RPM? Maybe idling in the long lines created a lot of heat soak too
If you're not spinning then you should launch harder. If you are spinning then you just need to throttle it the best you can. If the outside temps were 70F then you're probably starting your run with about 100F IATs. This is a huge reason why I added methanol. During the burning, I had drag radials, I would be able to spray a little methanol to cool things down. As soon as the run would start temps would drop down near ambient and stay very close to that the entire run. Without methanol I would start at 100F+ and would get up to as high as 145F.
2011 E92 335i | 11.7@125 SOLD
2017 Camaro SS | 12.7@114 SOLD
2019 Audi TT RS | 10.5@130 SOLD
2020 F97 X3M | 11.0@123
2023 G80 M3 xDrive
      06-16-2019, 02:32 AM   #464
Turbod
Turbod's Avatar
So I hit the track with the X1 on Friday and put down about 7 runs. Best run was a 12.96 @ 106mph. On this run I was trying a second gear launch and accidentally hit the kick down switch which brought me back to first gear. I was limited by heat and a little bit by octane.
JB4 @ 16 psi
E20 in the tank
VRSF 7inch intercooler
2023 G80 M3 xDrive
      09-26-2019, 01:53 PM   #465
E84seX1
Drives: 2014 X1 35
2014 X1 n55 vrsf downpipe burger intake jb4 and intercooler e30 mix xhp trans tune
12.7 is my best
      09-26-2019, 05:03 PM   #466
E84seX1
Drives: 2014 X1 35
      09-27-2019, 02:39 PM   #467
Turbod
Turbod's Avatar
These photos are massive. Honestly I was a little disappointed with my time and even what you ran. The last time I went to the track I had added methanol and still only trapped 107 with the ET around 12.8. Traction is starting to become an issue on the Michelin Pilot Sport AS/3+. My turbo is at Pure right now but should be installed in a month or so. I originally was hoping for lower 12's on the stock turbo and high 11's on the PS2 but I am thinking this will probably be a low 12's car with the upgrade hybrid.
2023 G80 M3 xDrive
      10-10-2019, 03:34 PM   #468
yas_e92
Drives: F82 m4 E92 335
Had an F series n55 out here in chicago run a 10.917 at 124.22mph 1/4 not bad at all!
mods are FBO n55 xdi60 hpfp and pure stage 2 turbo.
satinred_335i on IG
      10-12-2019, 01:51 PM   #469
victorg95
victorg95's Avatar
70
Drives: 2011 BMW E92 335xi ///M Sport
satinred_335i on IG
satinred_335i on IG
Yeah he's my buddy Edin, that was amazing lol
2020 BMW M340i
Black Kidney Grilles | M-Performance Spoiler | M-Performance Side Extension | CF Interior Trim | MHD Tuned
