Coby Wheel
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > DIY Guides > DIY: Downpipe (DP) installation for E90 335i (1/3)
      04-11-2012, 02:08 PM   #67
hiter202
Drives: BMW
does anyone have a guide for the N55 downpipe install/swap?
      04-13-2012, 09:07 AM   #68
revmybimmer
Drives: Light Blue 335i
Great Post. Thank helps alot.
      04-14-2012, 11:37 AM   #69
TOS_335i
bs_335i
TOS_335i's Avatar
Drives: 2009 335i
2009 BMW 335i  [0.00]
Any advice for getting the rear dp v-band on? Nevermind... Persistence got it done.
Cobb Stage 2+FMIC | CP-e DPs | CP-e DCI | ETS 5" FMIC
      04-15-2012, 10:54 PM   #70
robc1976
DIYER
robc1976's Avatar
614
Drives: E90 335i
I did this 2 weeks ago and want to know how tight you guys get the V band clamp on the turbo to down pipes...do the tips touch, mine arn't touching. I had one clamp put on upside down ( my buddy did this) but it is in the same place it needs to be just upside down. One other problem is there is a bolt on the flange in the rear that I can not get a wrench on to fully tighten it...I have 3" AR and there is not a Way I can see to get that last bolt that is farthest on the passenger side on the flange. I was luck enough to get a socket on one side of the flange on this bolt and tighten it a bit but holding it in place with a wrench/socket from the other side I can not? Anyone have this problem/problems lol!
I think mine may have a small leak.
GREAT TUTORIAL!!!!
JB4 G5, Stage 3 LPFP, Stage 2 MOTIV PI, VM 6466 ST, Custom OCC W/ SS lines, ER FMIC, ER CP W/HKS BOV, M3 control arms, M3 guide rods, M3 upper links, M3 front & rear sway-bars, HPA rear toe arms, Wavetrac LSD, HPF Gen 2, DEFIV kit, KW clubsport, Delrin solid SF bushings, stoptech rotors, Rogue Tranny Mounts, 1M bumper, M3 CF hood, M3 fenders, M3 OEM sideskirts, Mtech rear bumper, CSL trunk, MORR VS8.2 rims 245/295
      04-20-2012, 11:30 AM   #71
abee20
Drives: 2016 F30 340i
Originally Posted by Swoosh69 View Post
i'm scared shitless to do this install (thou i've installed all the mods on my car, including lowering springs)
the one part that scares me the most is the steering rack part...... would be perfect if there was some more details and pictures on that part... or maybe i just need to read this DIY 50 more times
have also looked at this video 20 times...
catless DP install
Extremely helpful video!
      04-20-2012, 01:14 PM   #72
SpartanGA
SpartanGA's Avatar
Drives: 2018 BMW M4 Comp F83
great video. If I had access to a lift, I would be all over this. But to do it on ramps.....I have a N55 which is apparently easier given there is one large downpipe vs. 2. Still they show you unbolting the steering rack, but not why or if/how you move it for access.
It appeared the clearance for the clamps and mount to turbo and front o2 sensors are the really difficult tight spots. The rear setup seems easy.
      04-20-2012, 01:24 PM   #73
robc1976
DIYER
robc1976's Avatar
614
Drives: E90 335i
I just did this on ramps and I am 6'4 270 lbs lol!! The steering rack is just 2 bolts, hex and a 16mm end wrench...and it will move back a inch to give you the very small room you need....I have big hands and arms and I got access. The heat shield I just removed all but one bolt and slid out of the way. This was on the N54.
      04-20-2012, 01:39 PM   #74
SpartanGA
SpartanGA's Avatar
ahhhhh...so tempting.
      04-29-2012, 01:03 PM   #75
BADS335
Drives: Montego 335i E90
How did you guys loosen the front O2s? I can not get the wrench on it to a point that I can turn them.
      04-29-2012, 01:06 PM   #76
robc1976
DIYER
robc1976's Avatar
614
Drives: E90 335i
Go to a autozone or advanced autoparts & get a O2 señor socket....you rent it, bring it back and you get your money back
      04-29-2012, 02:11 PM   #77
BADS335
Thanks for the response. I have one and it will not fit. It won't clear the bend between the "wall" and the cat. And I can not wire into the socket any other area.
2008-BMW-335i-E90-6MT-Sport-Montego Blue
      04-29-2012, 03:46 PM   #78
robc1976
DIYER
robc1976's Avatar
614
Drives: E90 335i
Have you loosened he steering rack for more room..it was easy for me to get o the front O2 sensors.
      04-29-2012, 05:36 PM   #79
BADS335
I did. Got them out. What I did was gave slack to the O2s from up top, then lowered the DPs which gave me room to get the wrench on it, and after a soak in WD40 came right off.
      04-29-2012, 05:47 PM   #80
robc1976
DIYER
robc1976's Avatar
614
Drives: E90 335i
Awesome! When putting them back in the wire will twist and I took mine completely loose so this didn't happen.
      05-08-2012, 03:36 AM   #81
johej
Sweden
Drives: BMW 335i Coupé
Thank you
Thank you very much for this DIY
I did this using your DIY.
I have very limited experience of this type of jobs, but it went well.
Total work time 4+4+2 hours.
4h first install. (The right downpipe was rubbing against the frame of the car.)
4h attempt to make clearance between the DP and the frame of the car.
2 h second attempt. Success.
/Magnus, Uppsala, Sweden
      05-08-2012, 05:06 AM   #82
Mischa335i
Germany
Drives: E90 335i
Hey magnus can you give some tips how i can avoid this rubbing of the downpipe on the frame of the car?
I going to install the VRSF Downpipes bext week and never did this types of job.
Thanks
Mischa
      08-07-2012, 12:17 PM   #83
jacobniell
jacobniell's Avatar
Denmark
15
Drives: BMW 335i
2007 335i  [0.00]
Any additional pictures are appreciated to help with the job. I am also about to do this swap and would of cause love to get as many tips and tricks as possible before the actual work ;o)
Great DIY!!
      09-29-2012, 08:26 AM   #84
LeMansBMW335i
Based on a true story
LeMansBMW335i's Avatar
Drives: 2009 335i
Great DIY. The V-bands were the hardest part for me. Such a PITA.
I removed the sway bar. By far worth doing for the couple minutes it takes. It gives you a lot more room.
2009 335i M-Sport: BMW Performance SSK/pedals/ spoiler/suspension/rear diffuser, 650i clutch, 35% tint, JB4, AFE DCI, Meth Injection, Ceramic coated VRSF Downpipes, ER Chargepipe, DTEC Angle Eyes, LED Interior and Reverse Lighting, Shift Light & Low Meth Light inside Rear View Mirror Clown Nose
      09-30-2012, 07:00 PM   #85
soontobe
Drives: '24 X5 xDrive50e M Sport
Very well written and thorough review. Might be taking a stab at installing my pipes very soon. Glad I came across this. Props to the op!
      03-19-2013, 12:12 PM   #86
BabyZ
BabyZ's Avatar
Drives: 335 -- M3
thank yoU!!
      09-15-2013, 10:52 AM   #87
F80Mmm
Drives: 18 F80 M3 ZCP, 09 E90 335i 6MT
I used this for my VRSF DP install yesterday and it worked out perfect, no major issues minus some bolts just being a PITA and tight space. I don't have much wrenching experience so its definitely doable if u have the right tools and extensions...it was a full day commitment for me and it feels like I got my a** kicked yesterday, but definitely worth it for the experience. VRSF fitment was definitely SPOT ON! I was shocked at how perfectly they fit after hearing downpipe horror stories and rattling/pipes touching. After the downpipes were bolted on I did double check to make sure there was no exhaust leaks before putting everything back on, my front O2 sensor that connected to the rear was steaming a bit and looked like there was a lil pressure coming out. I managed to get the wrench back on it and gave it one more strong tighten and we were good to go!
      09-16-2013, 09:24 AM   #88
Danface88
Drives: 2008 335Xi e92
Nice, pics, thanks for taking the time to make an awesome DIY!
