Official e90post 60-130 Times List!
10-17-2011, 03:14 AM | #133 |
Rep 1,041
dzenno that is really crazy fast. My best 100-200 km/h is 8.79s and that is really not slow by any means.....
I will have to upgrade to RB's in the spring. Winter is coming and I will not be able to get proper traction for months now unfortunately.... You guys inspire me, but it's also friggin' expensive to keep at it.... Oh well, it's all great fun as well
E92 335i 2008 Space Grey 6MT | Pure Stage 2 turbos | Motiv PI | Trueform Tech Intake | Quaife LSD | M3 Suspension kit | Öhlins Road & Track Coilover | DEFIVfab N54 diff lockdown kit | COBB PTF E85 Map | Fuel-It Stage 3 LPFP | NGK 5992 plugs | Wagner FMIC | Wagner 3" DP | Milltek exhaust | Tial BOV | SPEC Stage 3+ clutch | SPEC Steel SM Flywheel |
10-17-2011, 11:54 AM | #135 |
Sees the world the way it could be
49
Rep 761
Someone needs to wake Mr. 5 up, much has been happening around these parts! I am almost done running the DI system cleaner through my tank, once that's done I'm going to load up on 93 and do some runs, maybe it'll be a bit quicker!
10-17-2011, 12:12 PM | #136 |
Rep 1,041
Absolutely. However we tend to get a lot of snow along with the cold temps and that, in my experience, is rather counterproductive for good acceleration times....
10-23-2011, 02:11 PM | #137 |
829
Rep 3,982
Did a 8.89 run this morning in the 2008 335i sedan to replace my previous 9.07run. This is currently the record for a stock turbo non nitrous car. DBN File sent. Two back to back runs, one 8.94 and then the 8.89 run within minutes of each other.
This is good stuff. Any of these cars close to 9 flat are 120+ mph trap cars!
2011 Alpine 335d M-Sport 12.34 @ 110.48mph
2019 i3s Terra, 2008 Black 335i Sedan. 11.11@ 129.47 mph 2008 Monaco Blue JB3 2.0 335i Coupe. 11.33 @ 132.77 mph, 60-130mph: 6.95 seconds 2023 i4 M50 11.48 @ 121.56mph, 3.43 0-60 (dragy) |
10-23-2011, 11:06 PM | #138 |
49
Rep 761
Looks like today was an awfully good day for runs! Nice runs Hotrod! I had a good one of my own...8.84 I think that gives me the title for stock turbo, no-nitrous record... That said, I fully acknowledge the fact that Warren got his with fewer mods than I did.
Car/Conditions/Mods: '09 E92 335i 6MT, fully optioned, ZSP, full weight, 1/4 tank of 93 octane. OEM 19" 230s, 235/265 Michelin Pilot Supersport, 12mm spacers F/R 45 degrees, 75% humidity 1 shift Procede V5 Rev 2A, 7-29 maps, 17psi boost setting, 0% IC Homebrew K&N DCI cp-e FMIC/oil cooler CMGS trunkmount, 8psi full spray, CM10, 70/30 VP M1/Water ACT Street Macht Schnell 3" DPs cp-e CL exhaust
10-24-2011, 11:25 PM | #141 | |
829
Rep 3,982
Have you done a qtr mile run on the Vbox on a level road yet? Bet you will be trapping around 124mph.
10-25-2011, 09:31 AM | #142 | |
49
Rep 761
I really want to do a level 1/4 mile run, and will probably have the chance to do so on Friday...I would be thrilled with 124mph traps! Thing is, I really do have to go to a strip if I want to do 1/4 mile runs, as the topography of the area where I live is simply too hilly and wooded to find somewhere that I can safely go from 0-130. I will bring my Vbox with me to the track, and I will probably stay in it until 130 so I can get 60-130 times.
10-25-2011, 09:42 AM | #143 | |
Rep 1,041
Don't mind the metric screenshot, it's 117.83 mph according to the log. The lousy time (considering the end speed) is because it's 10F here and the runflats really don't grip too well and I launched like an old lady (2.4 sec 60'....)
10-25-2011, 09:48 AM | #144 | |
49
Rep 761
10-25-2011, 10:02 AM | #145 | |
Rep 1,041
I didn't log the run, but it was on map 5 (auto tuning), so probably it was very likely targeting around 14.5-15.0 psi. Now I want to find that hill I discovered a month or 2 ago with the 2.4% slope, that ought to put me just in the 9.xx range (probably like 9.9x but hey, it's in the 9's) Of course it won't actually make the car any faster, so trust me, I'm going to be looking into this meth thing very soon....
10-30-2011, 02:12 PM | #146 |
829
Rep 3,982
Okay, new record for the day. Did back to back runs of 8.69 seconds. Tried short shifting the 2nd run, same exact time. Would it of been faster if I tried short shifting on the 1st run instead of the 2nd run? I have no idea. Built a little boost in 3rd right before hitting 60mph. Not sure if that helped either. I also ran 91-93 octane Shell this time, instead of 97 octane. Could that be better with lower octane??
Then...after all this done, I went straight to a qtr mile test. 11.7 at 124.8 mph! Car is running pretty strong!
2019 i3s Terra, 2008 Black 335i Sedan. 11.11@ 129.47 mph 2008 Monaco Blue JB3 2.0 335i Coupe. 11.33 @ 132.77 mph, 60-130mph: 6.95 seconds 2023 i4 M50 11.48 @ 121.56mph, 3.43 0-60 (dragy) Last edited by hotrod182; 11-03-2011 at 01:48 AM.. |
10-30-2011, 11:49 PM | #147 |
Modder Raider
758
Rep 8,633
Drives: M3
List is updated.
e36 M3 Coupe, e36 325i Sedan
e90 335i--SOLD Best 60-130-------------9.15 Seconds------------------WWW.MR5RACING.COM |
10-31-2011, 04:39 PM | #148 | |
Rep 395
COBB S2+ - Mr.5 CAI, Catless DP, Catless MP, AMS FMIC. |
11-07-2011, 11:28 PM | #150 |
Modder Raider
758
Rep 8,633
Drives: M3
I just got an email from Dzenno.
He just ran a 7.59 with the following mods. Cobb Stage 3 race map (alpha), jb4 only used for gauges, passenger and rear seats out, pump+meth...cobb stage 3 race alpha map runs 21psi down to 17psi at redline with about 6-8deg timing less than stock down low and about 2-3 deg less up top than stock...
11-08-2011, 12:16 PM | #152 | |
Rep 1,041
Only one thing to do about it as I see it, we will HAVE TO get some RB's ourselves... I won't take my seats out though, but probably dzenno is in the process of trying to replicate HR's results. Wonder what'll come off/out next.....
11-09-2011, 02:49 PM | #153 |
Rep 1,041
I recently changed my Steinbauer tune to a JB4, and I've been running map 5 for a few weeks. Sunday I upgraded the firmware and started logging map 5 and map 2 and found that I am boosting a consistent 1.2-1.4 psi more on map 2. Vbox readins suggested I was quite a bit faster also.
Well, that needed some testing, so I was out doing some 100-200 kmh tests and was so impressed with the times I got, that I just let go of the accelerator a split second too fast to get a good 60-130 mph time (I stopped accelerating @ 129.47 mph LOL), but just to give you an idea of how fast this litle sucker is now here's the Vbox results of a 59-129 mph (should be VERY close to what would have been the 60-130 mph time). This is a full bolt on car, NO meth, and tested at the same place where I got a 11.33 time with the Steinbauer tune I will try again at a later time, I had 3/4 tank of fuel so I should be able to cut a it off with less fuel, so I'm not sending anything to Mr.5 just yet, but I will. I know I'm nowhere near the RB/meth/N2O cars, but hey, I think it's pretty good for a FBO, stock turbos, no meth and no weight reduction car
11-09-2011, 04:49 PM | #154 | |
49
Rep 761
