BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > Suspension | Brakes | Chassis > Suspension for street and track
      12-11-2011, 04:13 PM   #1
neilvosko
neilvosko's Avatar
Drives: 335i e92 FBO
What are the best suspension upgrades for street and limited track (NO LSD).
was thinking eibach pro-system plus , all in one solution.
any one running the kit??
      12-12-2011, 07:10 PM   #2
CALWATERBOY
CALWATERBOY's Avatar
146
Drives: 2009 E93 N54
No LSD is no way to run. But to answer to your question: Ground Control's Street/School package - ~$2100
Take to heart their recommendation to add M3 sways. You're smart to run the whole M3 parts package - ~$2400
Toe adj'rs for rear ~$250
Bite the bullet. Get a LSD - $2000+ depending on the mfg. Really.
      12-12-2011, 07:53 PM   #3
CJ421
CJ421's Avatar
1559
Drives: BMW M3
+1 LSD and a good set of tires ... gotta put power to the ground first.
2024 BMW M3 Sedan Frozen Pure Grey II/Fjord Blue, 6MT
Past: 2021 Z4 M40i Frozen Grey II/Black Alcantara | 2017 F30 340i Mineral Gray/Coral Red, 6MT | 2011 E92 335i Le Mans Blue/Black, 6MT
      12-12-2011, 09:19 PM   #4
The HACK
Midlife Crises Racing Silent but Deadly Class
The HACK's Avatar
1821
Drives: 2006 MZ4C, 2021 Tesla Model 3
What's so wrong with the factory sport suspension? I've found BMW's sport suspension is about the best compromise between street and track. It's already more can capable enough for 99% of the actual track attendees I see on a weekly basis, and for that 1% that can out-drive the BMW factory sport suspension, they'll already know what to do to maximize its potential on the track, that the gains there does not outweigh the detriment to its street manner.
Heck I drove on my factory stock suspension for 3.5 years on the track until I upgraded to GC Coil overs, and that was mainly for the ability to fine-tune the dampers, the added camber, and the ability to corner balance.
Sitting on a beat-up office chair in front of a 5 year old computer in a basement floor, sipping on stale coffee watching a bunch of meaningless numbers scrolling aimlessly on a dimly lit 19” monitor.
      12-12-2011, 09:25 PM   #5
neilvosko
neilvosko's Avatar
hack, how do you compare the sport to coilovers
      12-13-2011, 10:39 AM   #6
cvc 22349a
cvc 22349a's Avatar
Drives: 335i
I've seen you pose this question a couple times now so I'm going to answer it. The E9X suspension was engineered for rft's. Take away the rft's and add torque (which is easy to do w/a turbo motor) and you've got one mushy and unpredictable handling car (no, I have not taken my car to the track). So, to get handling close to my previous E46, I've had to change out most control arms and bushings to M3 parts and add stiffer dampers. Your car's suspension was engineered around traditional tires. Have you driven an E9X with the added grip of +1 size go flat tires?
2007 E90 335i, TiAg, 6AT, ZPP, ZSP, ZCW, 6FL, HD
Quaife lsd, ETS fmic, GIAC s/w, Dinan intake/exhaust/oc, Koni/M3 susp, Apex Arc 8, Mich PSS
      12-13-2011, 11:10 AM   #7
e90pilot
Freight Dawg
e90pilot's Avatar
Drives: E90 325i
I never really liked the ZSP in my. I preferred the non-sport in terms of balance. Sure it was soft but it had low limits do the fun factor is good. The sport suspension adds a ton of grip but also more safety. I've hear they've changed the settings since though.
--Marcelo
'06 Arctic Metallic 325i | Sport Package | 6MT | Dinan Stage III suspension | Dinan exhaust | 330i manifold swap! Click here! | Active Autowerke tune | 135i Brake Calipers | Deiselboost caliper brackets | E46 M3 front rotors
      12-13-2011, 11:23 AM   #8
mike-y
just another bmw douche bag
Drives: 1.9L of fury
for someone's car that is only going to see "limited" track time, I'd probably just say upgrade the dampers, and save your money for other things.
Unless you want coilovers for other reasons, but don't design your upgrades around the track if you are only going to spend limited amounts of time there.
      12-13-2011, 05:43 PM   #9
The HACK
The HACK's Avatar
1821
I've driven my wife's E92 with the run-flats on. And it is still far more capable than 90% of the populace can handle on any given track day.
And as far as the E9X suspension being specifically engineered for RFTs? There's no magic to the geometry of the E9X suspension. All it has is softer springs and dampers than cars from a generation ago. To be honest? A sport suspension equipped E9X is still about the best compromise for a car that's driven on a daily basis and taken to the track occasionally.
My old Z4 was "built" with shocks and springs tuned for RFTs too, and I've taken that car to the track with and without RFTs, and really? The main difference was the RFTs responded better and quicker to turn-in, but the traditional soft-sidewall tires braked better. Don't ask me why since I myself don't really know, but it was done back to back with the RE050A RFT and RE050A non-RFT.
The whole "we engineered the suspension specifically for RFTs" was just a marketing spiel from BMW to get you guys to buy into the RFT implementation. Frankly, running an E9X with sport suspension and compliant, non-run-flats is like running an E46 with sport suspension springs and non-run-flats with standard, non-sport dampers (and yes I have driven that combination back to back). It's not THAT much different...Especially not for track purpose.
      12-13-2011, 10:20 PM   #10
cvc 22349a
cvc 22349a's Avatar
Drives: 335i
Wow. That GC kit looks like a good value Do you have that kit on your car?
      12-15-2011, 09:57 AM   #11
CALWATERBOY
146
Rear subframe bushings. Pointlessly vague, subtracts feel and ability. Replacement w/M3 bushings a big plus.
Inherently bouncy. Handles bumps & dips poorly, aftermarket matched shocks & springs make big gains.
Pothole explosions. Good Lord, what possessed BMW to put such miserable performance in production? Big black eye for Munich.
Understeer. I hate sloth; 'sport' suspension has some.
Precision. BMW's 'sport' suspension arms are made to deflect. M3 arms are not. Hey....that's planned inferiority. Also check the front tower brace. Weird.
E-differential. A miserable, accelerated rear tire wear device w/so-so result. Wavetrac and Quaife have hopelessly outclassed this kludge with performance and feel.
Sway bars. M3 bars good juju. 'Sport' bars pencil thin. Effect commensurate.
Those are the obvious lows - fixing 'em results in huge improvement.
I like the car yet detest what BMW delivered as a 'sport' suspension as well as RFT's, which I replaced w/PS2's. At the end of this tunnel is a gratifying sports car - Cayman w/PASM is better, but I require the larger living space of my 3 and love the retractable hard top. Like its looks inside & out and BMW creature comforts, which is more than I can say for Porsche!
      12-15-2011, 10:05 AM   #12
CALWATERBOY
146
Should have by now, but experiencing continuing delays from Ground Control. Now saying Koni's will be in on the 23rd.
Have other items. It's all good! LSD a heavenly improvement.
eibach, eibach pro-kit, lsd
