Alpine Hifi upgrade
01-06-2009, 02:57 PM | #45 |
Rep 55
Thanks for that Robbie99.
Does anyone know what the score is with the BMW warranty? After doing a bit of research, am I right in thinking that the worst-case is that it could invalidate a warranty claim only if it relates to the Audio system? |
01-06-2009, 06:13 PM | #46 | |
9
Rep 296
Drives: E92 330d M Sport
If they fit it cant invalidate warranty! |
01-07-2009, 02:12 AM | #47 |
Rep 55
Very true - but I'm not keen on paying them £300-£400 to do that when it doesn't look too hard. I've had door panels off before on other cars so I'm willing to give it a go!
01-07-2009, 01:59 PM | #48 |
9
Rep 296
Well I will get my done by my mate who is a BMW Techy, So no probs for me and he does all servicing and warranty claims so no isssue. I think you would have to be unlucky if you have a problem with stereo after fitting this.
01-18-2009, 01:10 PM | #49 |
Rep 71
hi all,
i have just completed my install following all the instructions on the pdf, its more like 5 hours, its sdound much better than the stock system , subs kick harder and louder , it definately does not amplify the rear speakers! my only problem is that i have an electrical whining sound on the speakers when the car is on it also changes higher and lower with accelaration, anybody know how to fix this ? yunus |
01-18-2009, 03:45 PM | #50 | |
31
Rep 113
1. What radio does your car have and did you set the switch on the amplifier accordingly? SA 662 - BMW Business CD radio - Switch Position 1 SA 663 - BMW Professional radio - Switch Position 2 SA 606 - Business Navigation system - Switch Position 2 SA 609 - Professional Navigation system - Switch Position 2 2. When you connected the tweeters to the crossover did you plug them into the correct sockets? There's a choice of two yellow wired sockets for the tweeters. One would have been labeled for "Radio Headunit SA 662". The other labeled for "Radio Headunit SA 606, SA 609, SA 663". 3. If you play with the fader and the balance on the headunit, does the whining sound come through to the rear speakers? Does the whining sound come through both left and right speakers? |
01-19-2009, 06:34 AM | #52 |
Dimmer than a dim thing
80
Rep 1,291
Drives: M4 GTS, EQC, X5 40d, simrig
01-19-2009, 08:15 AM | #53 |
Rep 1,269
Drives: A Rental
Had the same issues with mine when I first upgraded the stereo. It was because they run the wires to the amp in the boot along the same route as the car electrical wires (can't remember if it was left or right), but they had to take out the wires and run them down the other side.
01-19-2009, 08:22 AM | #54 | |
80
Rep 1,291
01-19-2009, 12:34 PM | #55 |
13
Rep 351
I've ordered my kit today and I'm expecting to pick it up at the weekend.
Does anyone have any pictures of where you put the amp in the boot and where you routed the cables through the rear bulkhead? Thanks Miopyk |
01-19-2009, 12:48 PM | #56 | |
Rep 1,269
Drives: A Rental
They still couldn't power the subs seperately though as it caused serious feedback... I'd love to get a real professional to look at it and see what's wrong (i'm not running the subs at full potential obviously) |
01-19-2009, 02:03 PM | #57 |
Rep 71
i have grounded it at the recommended ground on the left rear wheel arch,
i am going to try zeroing the amp gains , and boosting the input signals on the loc. will let u know ! |
01-19-2009, 02:52 PM | #58 |
31
Rep 113
01-20-2009, 02:53 AM | #59 |
80
Rep 1,291
I've read the Alpine install guide and it shows where to put the amp and where to run the cables matie... The amp sits under the boot floor at the back left. On mine there is a metal frame with space for it, sure it'll be the same on yours. On the right hand side you'll have your Bluetooth and DAB tuner modules (if installed)
01-20-2009, 02:57 AM | #60 |
Rep 71
01-20-2009, 01:48 PM | #61 | |
Rep 3,022
M2 Arrived!
Family 5er |
01-20-2009, 02:01 PM | #62 |
20
Rep 185
Just in case it helps, i've installed it in my E87. The cables (-Ve and +ve) were both wrapped together so i connected them both directly to the battery terminals and I don't have any whining noise so you could try that.
01-21-2009, 01:26 PM | #63 | |
13
Rep 351
There is a black plastic cover which is roughly the width of the boot towards the front of the car with some screws in it. Does it go under here? By the way I don't have Nav, Bluetooth or DAB so unfortunately I can't use these as a point of reference. Thanks Miopyk |
01-21-2009, 05:32 PM | #64 |
Rep 564
Drives: Corvette & Jeep Commander
01-22-2009, 03:24 AM | #65 |
Rep 1,672
Ive been quoted £100 to have it fitted by an audio specialist - means it will be about £350 all in ... once my expenses come in i think its a done deal!
Been there, done that, driven the 'Ring
01-22-2009, 03:38 AM | #66 | |
80
Rep 1,291
alpine |
