05-23-2016, 04:12 PM | #1 |
Rep 465
Fitting MICHELIN PILOT SUPER SPORT (245/40-R18 / 97Y) on F30 335 Xdrive
Hey Guys,
I have a stock 2015 F30 335 Xdrive with stock rims and tires. Sport line. Wondering if there will be any problems fitting MICHELIN PILOT SUPER SPORT 245/40-R18 tires on 18x8.5 all around square setup wheels. My car is leased so I don't want to mess anything up. Photos would be great also. |
05-23-2016, 04:17 PM | #3 |
Rep 465
05-23-2016, 07:31 PM | #4 |
Rep 503
I am putting the same size 245/40 on a new set of 18x8.5 wheels this week. This is very similar to the stock setup of 225/45 on 18x8 wheels. They are slightly shorter in diameter but highly unlikely to cause any issue.
05-24-2016, 04:59 AM | #5 | |
2006 TIME Person Of The Year
9720
Rep 6,445
05-24-2016, 06:28 AM | #6 |
Infidel
122
Rep 1,102
What about it, you fear the profile is too low? That would be really funny considering what most here run. I have a square 8.5" setup with 245/35R20´s, MPSS and no problem at all.
Dec. 2022: Fully loaded Carbon Black G08 iX3 LCI M Sport Pro
Former: Glacier Ag. F31 328iA RWD M Sport oct. 2012, sold July 2022 | Sport Automatic | Adap. M Susp. | Pano. Moonroof | 20" ATS Racelight Grey w. Michelin PSS| M Sport brakes | Harman Kardon | Elec. Seats | PDC F&R | ACC Stop&Go | 335i MPE | Perf. Parts | |
05-24-2016, 09:30 AM | #7 |
Rep 465
That sounds great. May you upload some pics so I can see how it looks when your finished ?
05-24-2016, 09:32 AM | #8 |
Rep 465
05-24-2016, 09:33 AM | #9 | |
Rep 465
Don't want to effect of decrease my performance. |
05-24-2016, 12:45 PM | #10 |
Rep 752
There won't be any issue with those tires. On my F31 xDrive I run 245/40/18 Michelin PSS's on the stock 400M 18" wheels without any rubbing at all, not even close. The tires are very similar in size to the stock 225/45/18 Conti ProContact SSRs.
05-24-2016, 01:02 PM | #11 |
9720
Rep 6,445
My comment is related to your original post where you mention having 8.5" rims. I guess that was an oversight?
05-24-2016, 01:33 PM | #12 |
Rep 465
05-24-2016, 01:34 PM | #13 |
Rep 465
Yeah well thats a relief, I just feel the 8 inch stock look too slim and want a Beefer square stance for my car.
05-24-2016, 07:35 PM | #14 |
Rep 842
Your tire and wheel size 18"x8" are what Tirerack used in testing high performance all season run flats. They used a 2012 F30 328. So as the others have said, you're fine.
Plus quite a bit difference in choice with the 245/40, thanks. |
05-25-2016, 04:05 AM | #15 | |
Infidel
122
Rep 1,102
So performance/comfort wise there doesnt have to be any con at all, if the weight is kept down (at the cost, of the cost). So it´s basically down to how much u are willing to spend
05-25-2016, 04:16 PM | #16 |
Rep 749
Drives: 2016 528i Executive Edition
I'm running 235/40/18 square as one of my setups on 18x8.5 Apex Arc 8 wheels. Also a 335 xdrive.
That was the main recommended size by Apex. 245/40/18 was a secondary option they recommended. I didn't do the math myself, but I'm assuming 235 wide is probably a little closer to stock spec than 245, but both are within the 3% threshold? |
05-25-2016, 05:30 PM | #17 | |
90
Rep 205
05-26-2016, 06:44 PM | #18 | |
Rep 749
235/40/18 is far from "seriously" undersized. It is still within the 3% threshold so is still well within acceptable size. 235/40/18 is approximately 2.4% smaller than 255/40/18. Naturally the 245 width will be even closer to the OEM 18" sizing and a better option. This does make me wonder why APEX would recommend a 235 width tire over a 245 width if the 245 is even closer to stock spec. Maybe the 235 wide works better with an 8.5" wide wheel? I'm going to ask! |
05-26-2016, 07:13 PM | #19 | |
Rep 503
05-26-2016, 07:30 PM | #20 | |
Rep 749
I think he recommended the 235 as a better fit for a 8.5" wheel seeing both 235 and 245 are both within spec (within 3% threshold). I still haven't had the chance to send them a message to clarify. Will see what they say. |
05-29-2016, 01:17 PM | #22 | |
Rep 465
335, rims, sedan, wheels, xdrive f30 |
