      03-03-2017, 09:00 PM   #45
CarJunkie
CarJunkie's Avatar
Drives: e82 1M, f87 M2cs
2020 M2cs  [0.00]
2011 BMW 1M  [0.00]
The clutch slave cylinder pushrod had popped out and jammed. They inspected inside the housing with a camera and there was no evidence of any metal grinding. Clutch disk, pressure plate and throw out bearing all looked normal. They put everything back together and the car drove normally. They have ordered a new slave cylinder and will compare them side by side before installing the new one.
He mentioned that our slave cylinder has a plastic housing and may not have been able to handle the stronger pressure plate. I haven't heard of anyone else having this problem even with aftermarket clutches.
1M track toy mods: BMS chargepipe, BMS OCC, ADE FMIC, ADE motor mounts, MadDad/Lightweight Ti exhaust, ADE custom oil thermostat/cooler, custom MHD tune, F10 550i clutch, Ohlins R+T, Vorschlag camber plates, M3 'vert FSB with Turner endlinks, Stoptech Trophy BBK.
ayao643.00
      03-03-2017, 09:35 PM   #46
hot-j
98
Drives: 1M
That's the best possible outcome. Glad it was minor.
CarJunkie2616.50
      03-03-2017, 10:06 PM   #47
martymil
Australia
389
Drives: Garage is to big to list.
my 550i clutch has done 5k with no slave cylinder issues so a new one should solve the problem
CarJunkie2616.50
      03-07-2017, 07:23 PM   #48
CarJunkie
CarJunkie's Avatar
2020 M2cs  [0.00]
2011 BMW 1M  [0.00]
New slave cylinder installed. It now feels perfect. Something was definitely wrong with the original, either damaged during install or was already going bad. Pedal movement felt choppy and is now light and smooth. Problem solved. I paid $108 for the part. They didn't charge me any labor. I'm happy with that.
ayao643.00
Bimmer TV125.00
      03-07-2017, 08:40 PM   #49
ayao
Thread killer
643
Drives: 1M
Was the choppy feel there before things went south?
      03-07-2017, 09:25 PM   #50
CarJunkie
CarJunkie's Avatar
2020 M2cs  [0.00]
2011 BMW 1M  [0.00]
Yes, but variably, and seemed to be getting better. I didn't feel the choppiness before the clutch was changed, but now in hindsight I do think the pedal felt more firm than it does now, so it may have already been failing.
ayao643.00
      03-13-2017, 03:43 AM   #51
lightning
Singapore
69
Drives: 1M Pure S2
Sorry to thread jack, but since we're on the transmission topic now, i would like to ask if anyone have gear engagement issues?
Occasionally when my car is cold in the morning, i have some difficulty engaging into gear. it goes away as the car is being driven.
Anyone would like to chip in as to what might be wrong?
      03-13-2017, 08:45 AM   #52
CarJunkie
CarJunkie's Avatar
2020 M2cs  [0.00]
2011 BMW 1M  [0.00]
If its only happening when cold, it may be the fluid. That's an easy fix. I'd start with new fluid if you haven't done that yet.
How many miles on your car? Did your fluid get changed at 1200 miles and 30k miles?
      03-13-2017, 11:51 AM   #53
hot-j
98
Drives: 1M
If you haven't changed the fluid, do it.
If you have a fluid cocktail in there (thicker) for a single mass flywheel and gear chatter like I do, more D4 ATF would thin it out and slick it up.
      03-13-2017, 12:05 PM   #54
lightning
Singapore
69
Drives: 1M Pure S2
yup i had my fluids changed quite regularly, around 10,000kms per fluid change. used original BMW fluids, but to no avail.. i still get trouble engaging sometimes.
      03-13-2017, 12:59 PM   #55
martymil
Australia
389
Looks like you might have air in the system, it's actually a little tricky to bleed the clutch as it shares the same fluid as the brakes And you have to keep the fluid tank Filled to the top for it not to suck air while bleeding
Get it checked
      03-14-2017, 01:24 AM   #56
lightning
Singapore
69
Drives: 1M Pure S2
Get it checked
mechanics checked my car and couldn't find anything wrong with it.. sigh.
      03-14-2017, 04:33 AM   #57
martymil
Australia
389
Then it could be the slave cylinder going bad slowly
      03-16-2017, 06:51 PM   #58
MDORPHN
292
Drives: AW 1M
That'd also be my best guess. However, the slave can be a bitch to bleed fully, so I'd first have a tech (perhaps a different one?) do it again just in case there's still some air in the system.
Neil
      03-16-2017, 10:00 PM   #59
hot-j
98
Drives: 1M
Do you have a clutchmasters clutch?
      05-26-2017, 10:29 PM   #60
Ewok
16
Drives: AW 1M
2011 1M  [0.00]
I had similar issues - particularly 2nd --> 3rd. Worst in morning .. sometimes even mid day. Recently installed a brake kit and after bleeding of brake fluid, noticed it was smoother. Still get some rough shifting occasionally but definitely much better now.
Wonder if it's really related to brake / clutch fluid?
      05-28-2017, 01:32 AM   #61
martymil
Australia
389
the brakes share the same fluid as the clutch from the same reservoir, so when bleeding the brakes you should bleed the clutch so you get some nice fresh oil in there and not mix the old with the new especially when changing brands of fluid
      06-12-2017, 10:38 PM   #62
hot-j
98
Drives: 1M
I am thinking of going the f10 550 clutch route. How do you think this will pair up with my aluminium flywheel?
      06-13-2017, 10:19 AM   #63
CarJunkie
CarJunkie's Avatar
2020 M2cs  [0.00]
2011 BMW 1M  [0.00]
Is it a dual mass flywheel with the same thickness as stock?
      06-13-2017, 07:14 PM   #64
hot-j
98
Drives: 1M
Yeah, but one of the things I think is wrong with the clutch masters is the thermal expansion of aluminium is 7x that of steel.... and I think its messing with the sac mechanism of the pressure plate. Maybe I just answered my own question.
      06-13-2017, 07:18 PM   #65
martymil
Australia
389
Well most of us aussies are going down the dual mass flywheel and 550i clutch it is holding quite well on street and track
You wont be able to do any 4000rpm launches but it lasted twice as long my twin plate did
and still going strong
      06-13-2017, 08:57 PM   #66
hot-j
98
Drives: 1M
What kind of tq are you making?
