      08-20-2013, 07:57 AM   #1
saurabh_turingMS
saurabh_turingMS's Avatar
Australia
19
Drives: 1M AW (F10 520D MSport - gone)
Arrow BMWP Short Shift
Thanks to some advice from friends in Singapore, I had just the shift lever from the BMWP SSK installed in my car i.e. part#25110434217
The shift action is definitely shorter and much more direct. It took me a week to get used to it, but once I had CDV it felt perfect. I think it suits the character of the car better than stock, plus peace of mind of genuine BMW part.
It's not tricky, just a bit involved with mid-pipe & driveshaft needing to come out. Pete@Advan (Skycat) is across the install detail and can help anyone else out.
Here are some pics...
      08-20-2013, 09:27 AM   #2
bmw13
bmw13's Avatar
Drives: 1M - GIAC:S2
my shift knob is always sliding up/ out of place just enough to make a difference for me to notice. I think I may go this route! Very cool and thanks for sharing!
Follow my car/ life via Instagram @rdauito
2011 E82 1M #215 of 740
http://www.1addicts.com/forums/showthread.php?t=877009
      08-20-2013, 10:16 AM   #3
bdaddylo
bdaddylo's Avatar
Drives: 2017 F80 M3
FWIW most like the UUC over the BMW performance SSK.
_______________________
1991 E30 M3/Brilliantrot
2017 F80 M3/AW
      08-20-2013, 11:41 AM   #4
yemski
yemski's Avatar
Drives: 2011 1M
2011 1M Coupe  [0.00]
are the shifts a lot less smooth (or more notchy) with either the BMWP or UUC? Any comments from owners?
      08-20-2013, 04:25 PM   #5
saurabh_turingMS
Australia
19
BMWP is slightly notchier, but not ridiculously so.
      08-20-2013, 05:02 PM   #6
Dackelone
European Editor
Dackelone's Avatar
Germany
10589
Drives: N54 e82
At first yes, but after a few thousand miles the shifter breaks in very nicely. I have had my Perf SSK on my 135i for 50K kms and I really love it. BMW should have built the car with it.
      08-20-2013, 09:39 PM   #7
oystero
Australia
17
Drives: AW 1M, E90 320d
Thanks for sharing Saurabh.. Looks great
      08-21-2013, 11:47 PM   #8
yemski
yemski's Avatar
Drives: 2011 1M
nice thanks for the feedback! I'll probably be looking into the BMWP short shift kit
      08-22-2013, 12:24 AM   #9
lightning
Singapore
69
Drives: 1M Pure S2
Glad to see you sharing about this in the forum!
      08-29-2013, 03:30 PM   #10
saurabh_turingMS
Australia
19
No, no...Thank you for sharing
      08-29-2013, 04:49 PM   #11
Dackelone
European Editor
Dackelone's Avatar
Germany
10589
Drives: N54 e82
Btw... maybe you could measure your shifter throws now with the Perf shifter...
Here is what I found out in past threads...
MT shifter throws...
N54 = 80 mm's
N54 w/Perf SSK = 55 mm's
N55 = 70 mm's
I don't think anyone has measured the throws on a 1M before. But since the 1M uses the same trans(and linkage) as a N55 it should be 70 mm's stock.
I am curious how short your throws are now with the Perf shifter on your 1M.
Thanks,
Dackel
      08-29-2013, 04:59 PM   #12
Dackelone
European Editor
Dackelone's Avatar
Germany
10589
Drives: N54 e82
Originally Posted by Ian///M View Post
Mine is fitted next week and will take photos of before and after measurements
      08-29-2013, 05:15 PM   #13
ayao
Thread killer
643
Drives: 1M
Please report back with impressions with regard to notchiness and shift effort...
      09-01-2013, 08:27 PM   #14
Piets94
Piets94's Avatar
677
Drives: 94 M3, AW 1M, M2 CS
Thanks Saurabh. Ordered mine yesterday after seeing yours over the weekend. Great OEM mod. Can't wait to get this installed as I have always felt the throw is just a bit too long for the 1M, however still nowhere as long as an E9x M3 MT.
I actually also ordered a new plastic bearing and 2 clips upon recommendation from other sources when fitting
Ian, where did you source your shift arm from? The dealer doesn't list that part number in OZ. Cheers
      09-01-2013, 11:56 PM   #15
Piets94
Piets94's Avatar
677
Thanks Ian. Will be good to hear what your thoughts are on the shift feel. The standard shift is perfectly weighted in my opinion - wouldn't want to mess with that. The SSK in the 135i was perfect
      09-02-2013, 04:36 AM   #16
Dackelone
European Editor
Dackelone's Avatar
Germany
10589
Drives: N54 e82
ANY bmw dealer should be able to order the Perf SSK lever... it IS a bmw part after all.
#5 in this link... p/n 25110434217
http://realoem.com/bmw/showparts.do?...=25&fg=95&hl=9
      09-03-2013, 11:29 AM   #17
Piets94
Piets94's Avatar
677
Fitted mine today. It is really short and firm, but good fun on gear changes. I will post up some pics soon with before and after measurements. It does sit about 1" higher. Even the dealer gave big thumbs up
How does it sit 1" higher? That seems a lot. You mean the actual gear knob sits higher? Do you think that might annoy you? Looking forward to seeing the pics
      09-04-2013, 08:03 PM   #18
Dackelone
European Editor
Dackelone's Avatar
Germany
10589
Drives: N54 e82
Here you go, not the best photos, but shows before(left) and after(right)
- Height
- 1st
- 2nd
^^Very nice!
So how long are your shifter throws now?
      09-05-2013, 06:28 AM   #19
Jay-K
Jay-K's Avatar
Indonesia
384
Drives: Slow
i thought this was only available for the BMW 135i..
      09-05-2013, 11:37 AM   #20
Dackelone
European Editor
Dackelone's Avatar
Germany
10589
Drives: N54 e82
Yes, it is officially. BMW says only the Performance SSK will fit N54, 135i's. The N55 and 1M's share a new transmission that has different shift linkage.
I said all along I thought just the Perf shift lever would give you 80% of the SSK feel and would definitely fit N55's trans. I just took some ballsy guys to go ahead and "test fit" it to their 1M's.
So we know it works and its a cheap solution for a SSK.
      09-11-2013, 12:24 PM   #21
Dackelone
European Editor
Dackelone's Avatar
Germany
10589
Drives: N54 e82
Video shows it better...
Thanks for taking the time to make that video Ian.
PS: your wrist watch needs orange stitching(on the strap) to match your 1M's (VO)accents.
      09-13-2013, 12:29 PM   #22
bluecat
bluecat's Avatar
30
Drives: z4
I'm really picky about my shifter, but I want to try this because I want that extra height. Does anyone know if I need to buy the whole kit sold by Turner: http://www.turnermotorsport.com/p-15...2008-2010.aspx
Or can I just get away with the part number listed in the first post?
For my N54 135i btw.
Thanks
