      09-23-2013, 03:01 PM   #45
flzrider
Drives: AW 1M
Can anyone who has done this mod do me a favor and measure the width of the gear selector rod joint (picture below) with some calipers? I'm looking for the overall width of that joint, including the width that the inner plastic bushing adds to it. The original or the short shift version should be the same, so either of them would work.
      11-20-2013, 02:47 AM   #46
Daniu9394
China
20
Drives: BMW E90 335i /BMW 1M Coupe
Originally Posted by Ian///M View Post
Here you go, not the best photos, but shows before(left) and after(right)
- Height
- 1st
- 2nd
Hi, Ian:
I'm Dack's friend from China. I'm also trying to change my 1M's shift kit into a SSK, because I think the 1M's shift lever takes quite long distance to change gears.
Last week, I bought the RE Short Shift Kit and installed in my 1M, but I had some problems with the RE SSK. The problems are:
1. The shift lever is littile forward than the bmw original one (it is not locating centrally in N Gear),causing the Gaiter(cover) stretch straight when in R gear; And I can't get used to it because the gear postions has changed a lot.
2. The shift lever is a little higher than the before, also causing the Gaiter(cover) stretch straight when in R gear;
3. The biggest problem is that the R gear is hard to push in the right position. when installing, I found that the bottom of the shift lever was blocked by the holder underneath. Sometimes, the R gear will even come out by itselft.This is a big problem,which makes the R gear hard to put in.
Now, I don't want the RE SSK. I want to use the BMWP as well. Yes, if I only replace the shift lever into the BMWP shift lever, the distance of changing gear is definitely short than before.
1. But I wonder, as the pic you shown,the BMWP shift lever is about 2-cm higher than before, will this cause the gaiter stretch too straght when in R gear?
2. Is the BMWP shift lever still locating in center and straight when in N gear as before?
3. will the bottom of the shift lever touch anything of the shifting arm?
4. how about the force of changing gear comparing with the original?
thank you so much.
Daniel
      04-06-2014, 11:06 AM   #47
lazyd0c
lazyd0c's Avatar
Drives: '22 G06/ '17 f87 6MT
@Daniu9394
Has anyone tried this in a n55 135 yet?
IG - hype_md
'17 f87
'13 e82 (retired)
      04-10-2014, 12:05 AM   #48
Tiny Chainsaw
Tiny Chainsaw's Avatar
15
Drives: 135i
Originally Posted by lazyd0c View Post
@Daniu9394
a number of people have tried it, just search it up..
      04-11-2014, 12:46 AM   #49
Zuzu
Zuzu's Avatar
Australia
2816
Drives: M2C HS 6MT
Just ordered from Turner..To hard to resist this mod after all the positive feedback.
      04-11-2014, 02:36 AM   #50
Dackelone
European Editor
Dackelone's Avatar
Germany
10589
Drives: N54 e82
@Daniu9394
The 1M and the N55 135i's use the SAME transmission. So yes, it works. You only need the shift lever from the N54 Perf SSK or someone else's SSK.
Shifter Throws
N54 = 80mm's
Perf SSK = 55mm's
N55 & 1M = 70mm's
While that doesn't look like a huge difference... it is! The Perf SSK is so nice to use. I really love mine.
      04-26-2014, 11:26 PM   #51
lazyd0c
lazyd0c's Avatar
1 more question before I pull the trigger. How long does the process take from start to finish? I'm gonna have a shop do the install and trying to figure out the going labor costs.
IG - hype_md
'17 f87
'13 e82 (retired)
      04-27-2014, 07:13 AM   #52
Dackelone
European Editor
Dackelone's Avatar
Germany
10589
Drives: N54 e82
Real A to Z time is about one hour. IF the guy is really slow maybe longer.
On my car they charged me one hours labor even though they needed to drop the mid pipe, center drive shaft and THEN replace the shift linkage and arm. On a N55 you only need to replace that shift arm... so you might not even need to drop all that stuff... provided the tech has some LONG needle nose pliers in his tool box.
here is what BMW says it should charge.... 1.0 hour's labor rate.
      04-27-2014, 07:05 PM   #53
rad doc
Drives: 1M AW loaded
My dealer quotes 3 hrs and told me they would not warranty an "aftermarket part" even though I explained it was bmw made. Guess i will find an indy shop or do it myself.
      04-27-2014, 07:29 PM   #54
JWC
JWC's Avatar
Drives: 2014 F10 M5
I thought the performance SSK won't fit the 1M. Thats why I bought the Rouge Engineering one. It is coming in tomorrow.
Should I return it, and get the BMW performance one?
      04-28-2014, 02:41 AM   #55
Dackelone
European Editor
Dackelone's Avatar
Germany
10589
Drives: N54 e82
It is not the full N54 BMW SSK, just the lever part. Will work on any MT N55 E8x (incl 1M)
+1. Best thing is.... that shift lever is less than $120. You should also order a new bushing and some C-clips, but those are cheap.
      04-28-2014, 02:51 AM   #56
Zuzu
Zuzu's Avatar
Australia
2816
Drives: M2C HS 6MT
Actually with clips and bushing, was about $85US plus delivery from Turner, genuine BMW parts..
Ordered last week..
      04-28-2014, 03:36 AM   #57
Zuzu
Zuzu's Avatar
Australia
2816
Drives: M2C HS 6MT
When's it go in Joe?
Hopefully this week if I have some time to get to Advan Performance.
Rang Peter today to give him an advance warning..
      04-28-2014, 11:20 AM   #58
eeghie
Kind of a big deal
300
Drives: an 1M not often enough
Shifter Throws
N54 = 80mm's
Perf SSK = 55mm's
N55 & 1M = 70mm's
Let me see if I understand this correctly. If one would have either a stock N54 or N55/1M transmission, when mounting the SSK lever, you'd end up with a 55mm throw, correct?
      04-28-2014, 04:15 PM   #59
Dackelone
European Editor
Dackelone's Avatar
Germany
10589
Drives: N54 e82
Yes, I think so. Definitely on a N54. No one with a 1M has taken any measurements. They just have said taht the N54 Perf SSK lever works on a N55/1M - and it feels good. I would like to know the throw in mm's though, for a 1M with a Perf SSK lever.
      04-28-2014, 04:58 PM   #60
eeghie
Kind of a big deal
300
THX, as my question suggests, the PSSK lever just made my mod list. That list is not in a hurry, but once I get to it, i'll take some apple2apple before/after measurements of the 1M PSSK difference in throw (and height).
      04-28-2014, 06:48 PM   #61
Zuzu
Zuzu's Avatar
Australia
2816
Drives: M2C HS 6MT
All my bits arrived from Turner..$84.85US
      04-28-2014, 07:00 PM   #62
Zuzu
Zuzu's Avatar
Australia
2816
Drives: M2C HS 6MT
Nice, you will wish you did it 2 years ago
True... Hopefully get to Advan in the next few days for install.
      04-28-2014, 07:54 PM   #63
questionable
S50B32
Australia
41
Drives: E30 318is
does anyone have the n54 specific part numbers ?
      04-28-2014, 09:12 PM   #64
JWC
JWC's Avatar
Drives: 2014 F10 M5
1x shift arm lever 25110434217
1x bearing for lever 25111220600 (optional)
2 x clips 25117571899 (optional)
      04-30-2014, 03:30 PM   #65
rad doc
Just had the short shift lever installed on my 1m. Absolutely fantastic, cheap mod! 80 in parts and 200 for install. Shift is great. Short and direct. Not overly notchy. Ian is right, should have dont it sooner.
      04-30-2014, 04:42 PM   #66
Sebilad
Drives: BMW 1 series m sport coupe
I fitted the ssk to my coupe 2 weeks ago in about 15 minutes. It can be fitted from the top just removing the gaiter and rubber grommet then a pair of pliers to remove the bush and a screwdriver for the clip!
