TNT Racewerks
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > AUDIO/VIDEO + BLUETOOTH + Electronics/Alarm/Software > Installing subwoofer and amp help?
      03-23-2014, 09:40 AM   #1
Damion0097
Drives: BMW E90 328xi
I have a 2007 e90 328xi sedan. It has the hifi system and the CCC Idrive. How would I hook the amp up. Someone told me to buy a line out converter and tap into the rear speakers. Should I do that, and if so how would I. I'm just having trouble getting an RCA connection to the amp and finding a remote wire.
      03-23-2014, 09:59 AM   #2
rowingone
Drives: 2006 330 xi
There is a sticky on this forum with all the info you need . .under DIY section.
      03-23-2014, 10:44 AM   #3
ctuna
Drives: 325xi 06 wagon MT
No you should not do that.
subwoofer threads
http://www.e90post.com/forums/showpo...2&postcount=66
http://www.e90post.com/forums/showth...t=Ultimate+Sub
http://www.e90post.com/forums/showth...ight=subwoofer
subwoofers are not the solutions for a weak system
fixing the weak system is.
      03-23-2014, 11:20 AM   #4
kaigoss69
kaigoss69's Avatar
Drives: '08 335i
You can certainly tap into the OEM amp output wires, but not the rear ones as they carry no bass signals. The wires for the underseat "subs" is what you want to tap. Make sure you get a high-quality LOC as the signal from the OEM amp is very strong. This is not the most elegant solution but it works, assuming you have no problems messing with the OEM wiring. People who are still under warranty shy away from doing that since BMW would probably refuse to fix anything if you just looked at the OEM wiring funny. But with your 07 you don't have to worry about that.
If you want to improve the mids and highs of the system as well then you should go another route. Look at the links Ctuna provided.
Mobridge DA2 > JBL MS-8 > ARC XDi 600/4 > JBL Gti 408 Mids & Vifa OT19 Tweeters; PG Ti2 1600.5 > Morel HCW-10 & IDMax 15
      03-23-2014, 12:00 PM   #5
Damion0097
I'm fine with the system just looking for more bass. I already have the subwoofer and amp. It was a gift and it's exactly what I need to give me the extra bass.
amp, amplifier, e90, sound, upgrade
