04-03-2019, 02:16 PM | #67 |
201
Rep 167
Matt installed the Karbonius carbon fiber Airbox on his Sparkling Graphite E90 M3!
InnerBlueSkies1092.50 JTO245276.00 |
04-04-2019, 10:40 AM | #68 |
201
Rep 167
Equipped this track-focused E92 M3 with a plethora of AiM Sport Line goodies! From the EVO5, to the GPS08, even linear potentiometers. Some custom fabrication was completed to keep an OEM look. Here's the link to this build's dedicated thread! https://www.m3post.com/forums/showthread.php?t=1439508
04-04-2019, 12:14 PM | #70 |
201
Rep 167
Took care of Mike from IND's M3 with a rod bearing service during their last visit Had to snap some proper photos of the cars together of course!
JTO245276.00 |
04-04-2019, 01:09 PM | #71 |
201
Rep 167
This 2008 E90 is a little different than the others that we've documented here. Disassembling some of the lower components on the lift while on our way to performing the rod bearing service, we discovered that there was a crack behind the alternator that was bandaged up. The damage does not appear as though it was from a front end collision, but perhaps an error while that engine was being installed back into the car....not quite sure. Regardless, instead of investing in that engine, he said he would bring us another one.
These are the bearing pulled out of the customer supplied long block, which according to the yard he got it from is a 2008 with 37,xxx miles. The bearings tell a different story. With no scoring done to the crank, we upgraded the rod bearings and did a bunch of maintenance items such as oil filter stand gasket, belts and tensioners, valve cover gaskets, cooling system overhaul, cleaned out the secondary air passages with the manifolds off, and spark plugs. |
04-04-2019, 05:16 PM | #72 |
Rep 950
Glad I left Union County when I did, you guys would bankrupt me.
Loving this project.....hulking |
04-05-2019, 10:44 AM | #73 |
201
Rep 167
When this customer first came by the shop, he loved everything about the E92 platform, but desired more performance overall. He didn't want to just change the car for the sake of it, but rather improve all the areas of performance while staying remotely subtle. We started off the services with upgraded rod bearing replacement and full CSF cooling kit. An ESS VT2-650 kit followed along with a yellow StopTech big brake kit and Ohlins R/T coil overs. We sized up new Michelin PS4S tires from the factory ZCP specs, which sat perfectly under the fenders and allow some extra traction out back. Minimal carbon aero front and rear along with retaining the stock kidney grills and side gills keep the car's appearance somewhat low key. GTS software, M Performance steering wheel and Awron gauge, provide him with an improved driving experience and feedback from the driver's seat.
JTO245276.00 |
04-05-2019, 11:08 AM | #74 |
126
Rep 288
Awesome build, lots of 'subtle' improvements and I am sure it moves. Great spec too with the AW/FR.
04-08-2019, 02:27 PM | #75 |
201
Rep 167
04-09-2019, 03:01 PM | #76 |
3359
Rep 2,165
ACM cars almost look too pretty to drive, my goodness. Beautiful.
Justin@autocouture200.50 Matt@AUTOcouture4167.50 |
04-12-2019, 01:53 PM | #79 |
201
Rep 167
reidetailing611.00 |
08-31-2019, 01:08 PM | #87 |
124
Rep 83
There are some beautiful cars here, serious work, congratulations!
Justin@autocouture200.50 |
