BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > 2012-2019 BMW 3 and 4-Series Forums > Regional Forums > UK > Apple CarPlay Full Screen mode
Extreme Powerhouse
      05-13-2021, 04:53 PM   #1
beerglass007
Drives: G20 M340i
Has any paid for the mod to enable Apple CarPlay full screen mode ?
I currently have CarPlay enabled with a lifetime license which came with the car but currently its only 2/3 of the screen
There is mod/coders on the forum to enable full screen which seems pretty cool but wonder if BMW will get upset with a warranty issue or any further upgrades
Also when I checked my car details online the picture of Applecarplay on the BMW web site shows a full screen mode...How can they show this when they don't support it ???
      05-13-2021, 07:52 PM   #2
TensorFlow
Drives: F36 430i GC
You can get it coded to full screen. Pretty sure BMW doesn't care and it won't void your warranty. I had mine coded to full screen along with other options. Mine is a 430i. Any reputable providers (I had mine done at Codemybimmer) should be able to do it within 30 mins remotely.
      05-13-2021, 11:07 PM   #3
Localmotion
Localmotion's Avatar
Drives: 2018 BMW 430i M Sport
If you have a NBTevo_N or newer you can enable full screen in Bimmercode app, expert mode yourself. That's what I did on my 430i
      05-13-2021, 11:39 PM   #4
Ace555
Ace555's Avatar
Drives: G21 M340d Touring
I am in the same boat with this. I have the lifetime sub but only get 2/3's of the screen in my 3 series (F30). Yet my wife's 1 series (F40) has the full screen. It's irritating to say the least.
I asked about this on a Facebook group and had people offer to remote code it but wanted over £100 to do so. My opinion was that was pretty pricey for something that's so basic. So I plan to get bimmercode and make a number of changes myself when my warranty is up.
His and Her's BMW household...
BMW 3 Series 320d F30
BMW 1 Series 118i F40
      05-14-2021, 03:09 AM   #5
Wibbles
Coding ECU's remotely
Wibbles's Avatar
449
Drives: M3LR
You have to have NBTevo_N or newer to enable Full screen.
Yiu may need to have the idrive updated first.
      05-14-2021, 03:44 PM   #6
badgerbrock72
badgerbrock72's Avatar
112
Drives: 340i M-Sport
Hi wibbles
I have the lifetime subscription to car play from factory, but only the 2/3 display
I have NBTevo_P
Could this be coded via bimmercode or remotely?
Thanks in advance
Garry
kitster542.00
      05-15-2021, 12:14 PM   #7
Wibbles
Wibbles's Avatar
449
Drives: M3LR
Originally Posted by badgerbrock72 View Post
Hi wibbles
I have NBTevo_P
Thanks in advance
Garry
Bimmercode won't help with this but it can be activated with an ENET cable and the right software.
      05-15-2021, 03:23 PM   #8
beerglass007
Drives: G20 M340i
Did mine today with eNet cable
Just the full screen cost me £35
      05-15-2021, 07:09 PM   #9
Localmotion
Curious as to why you say this?
I enabled CarPlay fullscreen with Bimmercode in expert mode. took 2 minutes.
      05-15-2021, 07:35 PM   #10
Localmotion
Here's the screenshots from Bimmercode
moonshine850.50
      05-16-2021, 03:30 AM   #11
Wibbles
Wibbles's Avatar
449
Drives: M3LR
Well, there are 2 possibilities here, if you are running NBTevo_X then you you can just enable full screen with coding.
The other possibility is that Bimmercode have a level5 password for enabling SSH in order to modify the carplay.ini file in the headunit - highly unlikely but not impossible.
So, which version of firmware are you running on your hedunit?
      05-16-2021, 10:14 AM   #12
bobbba
Drives: BMW 320D M Sport (E90)
I have nbtevo_q and tried this in bimmercode but it didn’t work. It just resulted in a white square on the unused part of the carplay screen.
      05-16-2021, 01:45 PM   #13
Wibbles
Wibbles's Avatar
449
Drives: M3LR
This is the expected result, it means that Bimmercode does not have the ability to enable full screen carplay unless your headunit is running the latest firmware.
      05-17-2021, 01:34 AM   #14
Localmotion
I upgraded mine to X
      05-17-2021, 03:47 AM   #15
Wibbles
Wibbles's Avatar
449
Drives: M3LR
As I suspected.
      05-17-2021, 04:55 AM   #16
APJ
APJ's Avatar
245
Drives: F36 435d M Sport Plus
Wibbles is there a simple coding way to get CarPlay on a ID4
      05-17-2021, 06:31 AM   #17
RatPC
RatPC's Avatar
14
Drives: F31 LCI
No i dont believe so...
I'm looking at picking up an ID5/6 HU and swapping that out to add Car Play for me
APJ245.00
      05-17-2021, 08:36 AM   #18
Wibbles
Wibbles's Avatar
449
Drives: M3LR
No - ID4 hardware can run ID5 firmware but it does not play nicely - anyone that tells you it does and you won't get rebooting issues is bullshitting you.
You have 2 options:
New headunit running 18-03 firmware - you can retain your existing screen and get full screen carplay.
MMI device/Android Screen - both are inferior to the option above.
APJ245.00
      05-17-2021, 01:00 PM   #19
ian332isport
ian332isport's Avatar
705
Drives: F31 340i Shadow Edition
Any idea how much BMW charge to update to the latest firmware?
      05-17-2021, 04:35 PM   #20
bobbba
What version were you on before you upgraded? How did you upgrade?
      05-18-2021, 04:07 AM   #21
Wibbles
Wibbles's Avatar
449
Drives: M3LR
proabably a few hundred pounds - you can do it yourself:
https://mega.nz/file/sMYDkA6C#tau7oT...Nv9WhRUp0PJVic
drdino138.00
      05-18-2021, 03:25 PM   #22
Localmotion
I was on K
I have a friend that has ISTA and a ICOM, we did it that way.
